Question about Mitsubishi VS-60707 60" Rear Projection Television
Power turns off automatically
I bought the tv new in 2000 and it's worked with no problems. Recently, when turning on the tv it automatically shuts off about a second later. The power button turns green but within the second it shuts itself off. Power is connected but the tv won't stay on. Mitsubishi recommended unplugging for 15 minutes and pressing A/V Reset but neither worked.
  • 1 more comment
  • 1234qwer Apr 15, 2008
    turn power on, green power light comes on, two seconds later tv power turns off.
  • Anonymous Jun 06, 2008
    prendo la television y a los dos segundos de prender el foquito de encendido que es de color verde, se apaga y la television no prende
  • Anonymous Mar 13, 2014
    mitsubishi dlp tv turns on . only sound then shuts off a minute later
Same w/ mine.  Repairman said they turn off auto to protect the set no matter what is wrong.  Take it to be fixed.  Mine was right at $100.  Works great again.
Posted on Oct 25, 2007
Same problem with ours recently, loose connections in front of the unit....repaired and color adjustments by a local TV service man Charge for labor 85.00 other $45 for complete adjustment of color....it's great now....
Posted on Aug 26, 2007
Happened with my 2002 42" model. they say the convergence circuit.
Posted on Jun 13, 2007
Psp not detecting battery
Sounds like you might need a new power board. I know videogame911 does service PSP's your best bet might be to send it in to someone who can tell you exactly what the problem is, specially if you replaced the battery and still have the same issue.
Apr 23, 2013 | Sony PSP-3000 Black Console
Vizio M470NV just purchased, while watching TV it turns off with the Vizio light blinking between orange and white. Can not turn back on !! I have to just wait for about a minute then tv turns back on by...
I have the same issue on my Vizio M470NV. I called Vizio and they told me it is a self diagnostic test that is shutting down the TV automatically to protect it. They said they are working on fixing the issue with a firmware update that will be pushed out automatically if you are connected to the internet. No ETA given on when that would happen. I called them on the 3/14/11 and my TV is still shutting down randomly.
Mar 18, 2011 | Televison & Video
Built in freeview doesn't work but digibox does
Have you done a channel search on both tv sources(atv and dtv). most new tv's will automatically start will "New Install". If you havent had a digital installed recently then this could the problem. set top boxes and TV's will pick up the signal ok but others wont.
Sep 16, 2009 | Hitachi Televison & Video
Sony kds-r50xbr1 turns itself off and then green light blinks 52
I too have a Sony KDS-R60XBR1 tv and the issue that you are experiencing is due to one of your fans in the rear of the tv is not working.  The tv automatically shuts off in protective mode.  Make sure the POWER/STANDBY light is blinking and not the lamp light below it.  Is the power/standby blinking 4 times in red? If, yes then its a fan that needs to be replaced.  If its the lamp light blinking then you need to replace the lamp.  The lamp is easy to replace by ordering the lamp either from Sony for $250 or find it cheaper for approx. $150 from other DLP sources and replace youself by following your manual.  I hope this helps you.
Apr 22, 2009 | Sony KDS-R50XBR1 50" HDTV
TV turns off after being on for just
I have the same problem and I believe the new problem is the cooling fan is not working properly and the unit is shutting down to protect itself from the heat.
Dec 16, 2008 | Panasonic PT-43LC14 43" Rear Projection...
Westinghouse TV - Issues
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/..
Mar 10, 2017 | Westinghouse LTV-19W3 19 in. LCD...
My TV turns off by itself. How do I correct this? We've had our tv for over a year...and just recently it started turning off by itself...when its turned back on it automatically shuts off again. If we...
If you can find an inexpensive repair shop, I'd try that. For example, we have a place in town with an honest repairman who will fix about any issue with TVs/stereos. If he cannot fix it, he will not charge.
I would think that this problem is on the power supply. Perhaps a cap or transistor on the output side of the PS. I am not a technician though so I can't be sure. This is just a common symptom/solution from what you've described.
May 03, 2008 | Samsung TX-R2735 27" TV
My Mitsubishi turns off automatically...
I had the same problem with an RCA, check your sleep mode settings on it, it may have defaulted to 1 min, so it cuts off when it cuts on
Oct 15, 2007 | Mitsubishi VS-60707 60" Rear Projection...
TV shuts off automatically
I Can Assure You That This Problem Is Associated With 2 Capicators On The Power Supply Board.
Aug 24, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi VS-60707 60" Rear Projection Television Logo
460 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
