Question about Aquacal HeatWave
My Aquacal Heatwave runs about 15 seconds then turns itself off.
It turns itself off when the water is still cold and I turn the heat control knob all the way to heat/hot.
Whenever it turns itself off, the P+ HFF and FLOW LEDs are turned ON.
What is its problem? Can I fit it?
Thanks,
Nghia
  • jbasilico May 11, 2010
    I perhaps am seeing the same issue...Heatwave runs for about 5 minutes, then shuts itself off. It actually trips the circuit breaker. I originally thought is was an overload in the circuit breaker, until I shut off several other breakers, and then witnessed the Heatwave function just until the "heat" red light went on...and then bam...off the unit and breaker went. After running through the test several times...got the same results...unit run for about 5 minutes, and then when the red heat light goes on, the unit and breaker go off. I've concluded that its got to be something internal to the Heatwave unit...so on Monday, the first thing I'm doing is calling the pool and AquaCal companies.
3 Suggested Answers
  • 990 Answers
SOURCE: I have a AquaCal Heatwave H125C-A Pool Heater.
Sounds like your compressor is not running. After your fan goes on in one to five minutes you should hear the compressor kick in. If it does this and then kicks out again it can be something as simple as water flow and you can adjust the valves to get more or less flow to keep it running. If not you probally need a repairman. It is ether your compressor or the capicators that start the compressor and this is all high voltage. Good luck.
Posted on Jan 26, 2010
  • 990 Answers
SOURCE: HEAT PUMP SAYS WATER TEMP IS 99 DEGREES WHEN ITS
This is a bad temp sensor or an open by-pass. You would have to go to your book to find these though. I'm not sure where you would find them.
Posted on Oct 13, 2010
I have an aquacal heatwave 155. The pump runs and red light indicates it is heating, but the water is coming out cold. What's wrong ?
if heater is calling for heat and running is heater lit? if so water is prbably going through heater so fast it isnt heating to your feel you might want to install a bypass valve and only let 50 percent of water through see if that works
Sep 25, 2014 | Pool & Spa
Leak in heatwave aquacal
replace aquacal exchange or where leaking
May 20, 2014 | Jandy LXI 300 PROPANE POOL HEATER -
Error code PO
overheated check gas pressure if not enough it will distort heat exchange
Jan 26, 2014 | Aquacal HeatWave
I HAVE NO DISPLAY PUMP DOES NOT TURN ON I HAVE POWER COMING INTO THE PUMP
I looked up the users manual for this unit and it said if the display was not working then "ensure the main breaker (located at the power supply panel) and the disconnect switch (located near the heat pump) are both turned ON."
If power is truly comming into the pump then the problem is likely either a bad power supply, connector problem or the display board. There could also be a fuse blown but that would likely be caused by a bad power supply.
I am not sure HeaWave will help but I recommend you call the HeatWave technicalsupport at 800-786-7751 and they might be able to help you figure this issueout. I hope this helps.
Please vote on this answer. Thank you.
Aug 24, 2011 | Aquacal HEAT PUMP 120,000 BTU H135 -
AquaCal Model 120 AHDEBNC message on panel wont clear. Message is FLO. There is water flowing thru the heater and the filter is clean
If you have a by-pass, (This will be a pipe that runns in between the in and out pipes on the heater) The valve must be almost closed in order to get enough volume through the heater to get it to run.
Make sure that heater has enough time to respond to this adjustment. It will take up to five minutes to start.
Oct 27, 2010 | Aquacal HeatWave
Have three coleman hws same problem on last weekend. Fully charged batteries 6.45volts. New gas bottles. Turn unit on water starts to run gas ignites for one to two seconds and then goes out water will...
It will probably be one of two issues. Either the waterflow sensor is not working correctly or the propane valve connected to to control knob is stuck shut. The water flow sensor is located on the side of the copper element (grey box) check that it spins easily. The propane valve is attached to the control knob by a long metal wire and should turn freely as you turn the control knob to warm
Jun 21, 2010 | Coleman Hot Water On Demand
I have a AquaCal Heatwave H125C-A Pool Heater. The Heater is working in that the power is going on and the air is blowing- although- the air is usually colder than the outside air and now it is only air...
Jan 25, 2010 | Aquacal HEAT PUMP 120,000 BTU H135 -
Warm water only
You can eliminate the shower control knob possibility by turning on your hot water anywhere else in the house. If you get hot water in other places, then it could be the knob causing it. A substantial lime buildup in the tank can also cause poor heat transfer from the elements to the water.
Sep 16, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Aquacal HeatWave Logo
73 people viewed this question
Top Aquacal Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you an Aquacal Pool and Spa Expert? Answer questions, earn points and help others
