Question about Onkyo Audio Players & Recorders
Tx-ds595 has no display light everything else works fine
  • rkondos Dec 14, 2008
    replaced lcd display unit still no light-up. lcd unit cost 56.00 dollards at onkyo.
  • rkondos Dec 17, 2008
    i replaced lcd display still no light what voltage should this lcd take to power up pins 1and2 and 65and66 looks like ac volts from power transformer maybe 5.6v ac????
    Genius:
  • 1,199 Answers
Sounds like a bulb or lcd is burned out (no big deal)
Posted on Dec 13, 2008
Hello my name is Ivan.I vant to know is there for this model remote Onkyo TX-DS565.My courier was iv_an_76@abv.bg
I'm not aware of Onkyo having made a receiver model TX-DS565. Perhaps there's a typo in your message? Did you instead mean Onkyo model TX-DS595? Google search and Remotes.com has listings for the remote for TX-DS595.
Dec 25, 2014 | Onkyo Audio Players & Recorders
[TX-DS595] My Video 1 stopped working, no audio, (Right before the super bowl!) yet I get audio on DVD & Tuner. What could be the problem? Thanks, Ira S. Cohen
Well, what's on Video 1 and is IT okay?
You don't say if you're using the analog audio associated with Vid 1 or if you have digital audio coming in and assigned to Vid 1. Check the cables. If using the optical, make sure it has no small-radius bends.
If analog audio, try another input - video 2 or 3.
If you have Cable/SAT TV as the source, what's going on with ITS audio settings?
http://www.retrevo.com/support/Onkyo-TX-DS595-Receivers-manual/id/365dj195/t/2/
You can always run that RCA cable pair from the source to theTV as a test for audio, too.
Feb 05, 2011 | Onkyo TX-DS595 Receiver
Display doesn't light up on Onkyo TX-DS595 reciever
try to connect the receiver to a tv via the monitor out from the receiver to the tv. you may be able to see the OSD (on screen display of your settings) change the function on that to turn on the front display. alternatively look on your remote to see if you can turn up the light of the front display.
if these don't work possible that the light of the display has blown
Dec 04, 2010 | Onkyo TX-DS595 Receiver
The Onyko TX-DS595 receveiver won't respond to remote.
When unit is on hold down vcr button and press standy power button. display will read 'CLEAR". turn back on and see if remote works. note that this will erase any of your settings. Point the remote at any camera and look at the camera display. If you see a white light when you press buttos remote is working. Remove the top cover, remove front cover and resolder connections on remote receiver. If you intend to do this let me know and I can give you more details.
Mar 22, 2010 | Onkyo TX-DS595 Receiver
Display on receiver no longer visible
from display power by ac voltage 5.6vac pins 1and2 and 65and66 should be from power transformer there is no fuse for this display light
Nov 10, 2008 | Onkyo TX-DS595 Receiver
Onkyo tx ds595
Yes, the speakerconns can have bananas, you have to remove the little plasticcovers in the middle of the conns...also you can use thick wire with this connectors...
MfG
Feb 24, 2008 | Onkyo TX-DS595 Receiver
Onkyo TX-DS595 with no display?
Ran my 595 blind for 2 years and finally spent the time to diagnose it this year. Turns out that one of the resistors that is on the power supply went bad. Similar problems have happened with later models so i thought the same may be true for the DS595.
My Receiver has always run fine.. just no display anymore.
Here's the fix. Replace R9501. its on the larger board that is part of the Power Supply. You will have to take the 4 large screws out of the base of the big heavy power supply block to find the resistor. I believe the old resistors is a 1/4 Watt. I replaced it with a 1 Watt so that it can handle the heat of being turned on and off better.
The resistor you will need to buy is 2.0 Ohm. I wouldn't go anything less than a 1/2 Watt and preferably 1 Watt.
My receiver works line new now!
Nov 15, 2007 | Onkyo TX-DS595 Receiver
Microphone
Do you have a mixer or other preamp to connect to your reciever?
Oct 24, 2007 | Onkyo TX-DS595 Receiver
Receiver doesn't respond on remote signals
Low batteries can cause a symptom like this. Have you tried to replace them yet?...accordianman
Oct 04, 2007 | Onkyo TX-DS595 Receiver
91 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
