Question about Samsung TX-R2435 TV
TV onscreen Menu is in Korean
If i could get the layou to the tv-remote menu in english hopefuly i could autoprogram cable channels and select 'cable'
    Genius:
  • 1,199 Answers
Menu...display...language...english
This should fix ya!
Posted on Dec 13, 2008
5 Suggested Answers
  • 3 Answers
SOURCE: TV screen on video 2 and remote died
The only way your going to change the video mode is with the original remote. If you need another remote go to http://remotes.com or call 1800 remotes Theres a button on the upper left hand side of the remote called video mode. A universal most of the time will not work this function. You could ask around to your friends and buddies or relitives if anyone has a working Sanyo remote or go to a local retailer that sells Sanyo and see if he would let you borrow one for a little while so you can switch out of the video mode. Good Luck
Posted on Aug 20, 2006
  • 119 Answers
SOURCE: FPA Lock
After doing a little research, it looke like the front panel lock , can only be removed from the parental control menu using your remote. If your universal remote does not get you into the menu, see if you can borrow a friends rca remote long enough to get you into your menu & remove the fpa.
Posted on Nov 03, 2006
  • 84 Answers
SOURCE: ESA ET413E LOST INSTRUCTION MANUAL, NO SELECT KEY!
when picture is displayed on your tv after pressing menu,press the channel up/down button on the remote or tv. there can also be a button that shifts right to left. this may hilight the the settings you want to change. if the up/down button scrolled you thru the settings, then the right/left buttons should change the settings.
hope it works
wg
Posted on Jan 28, 2008
SOURCE: Philips PC7225 hotel TV - can't access the menu to reprogram it.
The code 0621 isn't working for the PC7225 TV on my philips RC19335027 remote. Is there any other code I can try.
Also I purchased an RCA - RCR311BT remote and programmed for the tv and the code 0621 isn't getting me to the setup menu.  Is there any other code I can try or special way to enter the code in to get to that setup menu?
The ultimate goal is to change the default startup station from channel 53 to channel 3. Thanks.
Posted on May 06, 2010
We have not had this tv on since went over to digital freeview built in hopwever just put it on and there are no channels stored how do we get channels?
Hello
Your TV has to be initilized. It should be retuned to get the channels memorized in its memory section. Then only you can get the channels stored. Hopes that you have its remote control hanset with you. Replace two new cells in it and proceed the folloing steps. Connect ariel to its back socket before doing these.
[1] Press power button on the front panel of your tv. The initial setup screen appears.
[2] Press Ch+ on the remote control handset or on the front panel of your TV to start auto program, or Ch_ button to exit.
The initial setup screen will appear each time you switch on the tv until you perform autoprogram.
To perform autoprogram again
[1] Press Menu button.
[2] Press to highlight Channel Menu
[3] Press Pr Dn button to hilight cable. Press [+] to select.
[4] Press Prog Up or Prog Dn to hilight On or Off according to how you connected your TV. Press [+] to select.
[5] Press Prg Dn to hilight autoprogram. Press [+] to search for channels.
[6] After autoprogram finishes, press "Menu" again to exit.
TO RESET THE TV TO FACTORY SETTINGS
[1] Turn TV on.
[2] Press and keep hold the "Reset' button on the remote control hanset.
[3] Press and release the "Power button" on the TV front panel. The TV will turn itsef off.
[4] Release "Reset Button" now from your hanset.
These are the processes to be done to either autoprogram or turn it to factory settings. Ok.
Oct 20, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Channel setup
You will have to run the Autoprogram menu function from the menu. Here are the steps
Press the MENU button on the remote control.
Use the cursor down to select Installation in the Settings menu.
Use the cursor right to enter the Installation menu.
Select Autoprogram in the Installation menu.
Use the cursor right to enter the Autoprogram menu.
Press the OK button.
Select Cable or Antenna in the Installation mode.
When Antenna is selected, the TV will detect antenna signals and will search for antenna TV (NTSC and ATSC) channels available in your local area.
When Cable is selected, the TV will detect cable company supplied signals and will search for cable TV (NTSC,ATSC, QAM modulated) channels available in your area.
Make sure that registration with your cable TV provider and connection of equipment are completed.
Press the green button “Next” on the remote control.
Press the green button “Start” to start autoprogramming.
The menu screen disappears and the progress of autoprogramming is displayed.The progress bar indicates the number of analog and digital TV channels found. (Also digital channels via CableCARD are being programmed.
When Autoprogramming is complete, a message appears confirming the completion and the TV switches to the first installed TV channel.
Mar 16, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
HI MY PHILIPS 25INCH TUBE T.V ONLY GOES FROM CHANNELS 2 TO 42
Either press menu on the Philips remote and go to autoprogram, or (if you have lost the remote), press volume - and channel - at the same time. When menu appears, use channel - to select autoprogram and volume - to select it.
-Tha Mp3 Doctor
Dec 31, 2008 | Philips TS2546C 25" TV
Unable to automatically scan for channels. menu button on remote does not work om my 1992 jc penney tv. No buttons on outside of tv except for the basic channel up/down and volume control. Recently...
To make it easy for you - you should have original remote.
Then through the menu look for channel set up then make sure you select cable or antenna then you do autosearch(sometimes called autoprogram).Unless the tuner is defective,you should be able to program withe the original remote.
Jul 19, 2008 | Televison & Video
Programming
using the menu button on sthe tv; go to setup, select cable, then select autoprogram and let it search for your channels.
May 09, 2008 | Televison & Video
Admiral TV more channels
You will need a menu button to get to setup or channels for you to autoprogram the tv to find ALL the channels. AUTOPROGRAM is the word you need to find. If there is a menu button on the tv, then you can probably do it from there. If not, then you need the original remote from Admiral or at:
http://www.replacementremotes.com/tvcodes/index.html
Mar 25, 2008 | GE RM24912 Universal Remote Control
Can't access channels 3 and 4
Open main menu and select manual program. In this option check skip on/off option is there. Otherwise select autoprogram the channels are automatically stored, after completing autoprogram TV displays program edit option. In that you can choose your needs.
Sep 09, 2007 | Zenith SY2751Y TV
Sanyo DS 31520
make sure your got the right cable mode selected through the remote or autual switch on back of tv. if not it youll only see cable channels up to channel 13 that means in is standard tv mode or air. once you selected cable ...run autoprogram and it find all the channels for you. these newer sets, dont bother with looking for a cable switch, its all done automaticly when you hit that autoprogram button but it would be in the menu under setup.
Sep 06, 2007 | Sanyo DS31520 31" TV
Channels
If you have a menu button on the front of the Tv, you could search for an autoprogram or channel search menu and select that. Otherwise a cheap universal remote might be needed. You also want to make sure it is selected to receive antenna and not cable channels.
Sep 03, 2007 | Sylvania 6427FF TV
Philips TV set PC7225-PC121
JUST GO THE MENU AND PRESS INSTALLATION. SELECT AUTOPROGRAM. AUTOMATICALLY SYSTEM GOES TO DEFAULT MODE.
Aug 04, 2007 | Philips 25PS40S 25" TV
Samsung TX-R2435 TV Logo
123 people viewed this question
Henry  Thomas
Henry Thomas
