Question about Cyberhome SonicVoom CH-SRD600R Consumer Headphones
I have a Cyberhome sonic voom headphone. I am trying to connect it with digital cable reeciver but its not working
The blue light does not blink,it is a steady light that will not turn off and it wont pair up with my phone
The only way to reset your headphones is by charging them and pressing the call button and volume up and it will work like new.
Mar 26, 2014 | AUVIO Bluetooth Headphones
I can hear only from right headphone of my sony bluetooth
Either the left headphone is shot or the headphone jack is messed up. Try a different set of head phones if its same result see about replacing the jack.
Jan 23, 2014 | Sony Walkman Audio Players & Recorders
Iphone 4 music plays via bluetooth but not via dedicated cable connection
It would seem that the headphone jack is damaged. Double check that the wired headphones do work.
May 08, 2011 | Cell Phones
Whatdo i do if my skullcandy headphones dont charge?
Are these amplifing headphones or ? Most headphones use the devices power source to make the headphones work, they use very low voltage and various ohlms to make the earpieces vibrate and make sound. If they are not working try pushing the connection in all the way, or try another set of headphones to see if the problem is with the device. Sometimes we get defective headphones right out of the box, Skull Candy is usually very reliable and quality checked before shipping, but it can happen with all manufactures. Gool Luck.
Mar 15, 2011 | Audio Players & Recorders
Where can I purchase the Audio Video Connection for my dvd player I want to hook it up to my TV but can't find the correct cable Thank you Sandy
For the COBY TF-DVD7500, the video is carried on a single RCA plug cable. You can make due with a composite video cable (with three RCA plugs on each end) or get an RCA cable. The audio output can either be digital audio (which uses a special coax cable) or a headphone connector (analog audio).I believe the headphone jack is a 3.5 mm connector. If you use a composite video cable to your TV, you can connect the red and white plugs to an adapter (3.5 mm M to 2 RCA F). Then the TV speakers will get the audio track; otherwise you can use the DVD player speakers or the digital audio out.
I hope this helps.
Jan 24, 2011 | Coby TF-DVD7500 Portable DVD Player with...
No music playing in headphones
Hello.
Try to adjust the headphone.
Check if it is connected properly.
If it still doesn't work, try to check the headphone on other devices.
If the headphone is working on other devices, your MP3 headphone jack has some problem.
But if the headphone is not working on other devices, you should get new headphone or you can try other headphone (besides your current one) on your MP3.
hope it helps.
Jun 09, 2010 | Coby MP-610 MP3 Player
Just bought the brookstone wireless tv headphones. I have a Westinghouse 40 inch lcd tv. I plugged in the rca red/white into the audio out and I don't get any sound into the headphones?
I had the same problem with Brookstone wireless headset the only solution I found was plug in the red and white connectors to your cable box it works perfectly that way. Just make sure the red cable connector from the transmitter is connected to right red input connector on the box. I have a Comcast cable box. Now I need a solution for them on my PS3?
May 09, 2010 | Brookstone Surround Sound Earbuds...
I connected data cable from usb to my i pod,there is no reaction
Ur IPod must have been hanged ...check whether the dispay is still on....if yes...then press and hold the menu and select utton simultaneously for 10seconds,or else select and pause button make sure the hold button at the bottom is towards the headphone.
Aug 05, 2009 | Transcend T.sonic 850 Digital Media Player
Can't record from tv to dvd
I think you would have to run your sat line through the DVR-1600 first (Line In) then connect directly from the DVR to one of your TV Line-Ins (Audio R, Audio-L, S-Cable Video).
And then use the Cyberhome TV Tuner to record off your sat.
Jan 24, 2009 | Cyberhome DVR 1600 DVD Recorder
Hi can i connect my transcend mp3 player directly to my home theatre so that i can get the music output in my home theatre speakers , if i can please suggest how?
easy, just find the AUX port on the home theatre system then turn the system to AUX and hook a cable that has 2 male ends (the ends that go into your mp3 players headphone jack) to your ipod and to your home theatre, you will have to buy this cable seperatly
Jan 03, 2009 | Transcend T-Sonic 840 MP3 Player
Cyberhome SonicVoom CH-SRD600R Consumer Headphones Logo
158 people viewed this question
Top Cyberhome Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Cyberhome Audio Player and Recorder Expert? Answer questions, earn points and help others
