Question about SanDisk Sansa e260 MP3 Player
E260 MP3 player - my PC doesn't see my device
My PC doesn't see my Sansa e260 MP3 player. It doesn't show up under device manager or under My Computer. We've done the Windows troubleshooting for USB devices. Still can't see the player. We've tried this on a desktop PC and a laptop PC. The desktop has Windows MediaPlayer 11; the laptop has Windows Media Player 10. We've tried both MTP and MSC modes. Can anyone suggest a solution? Thanks!
  • danjackson Feb 06, 2008
    I had the problem with my sansa e260 and i tried updating the software off the site and everything but my problem slightly different because i can view and add music to the mp3 player on msc mode but i need mtp mode to work for vids and pics but my computer isn't able to install the "hardware"
    it's frustrating to say the least ... am i doing something wrong?
Refer to the SanDisk site to update your player. Your pc probably isn't the problem.
Posted on Mar 30, 2007
Sansa e260 mp3 not recognised as a device on my computer
An Update: that yellow square means that it is not recognised, I missed it on the first read through. It means you do not have the required driver to run this application. First port of call is Microsoft Support and see if they have any thing, else Google it and try to find a free one that supports your player. Sorry about my previous post.
Jan 01, 2010 | SanDisk Sansa e260 MP3 Player
Sandisk e260 froze after power up.
sounds like a firmware program problem and will have to be replaced. You could download an updated firmware but you will have to get a pc connection.
After your device is plugged in, are you able to go to  "my computer" and see a drive folder that has your device on it.
Mar 01, 2009 | SanDisk Sansa e260 MP3 Player
Sansa E260 - I don't have USB Mode on my settings
Go look under Menu > Settings again. Either go UP two choices or down eleven choices and there it is.
Dec 23, 2008 | SanDisk Sansa e260 MP3 Player
Can't drag and drop to from explorer to mp3 player
Check if the player was detected by the computer..
to check: go to device manager
right click my computer go to hardware tab and click device manager and scan for hardware changes.
a baloon will pop up if the device was already detected by the pc
however if it still not detected you must install the firmware of your device, or its driver so that you can browse its content.
Sep 14, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e-260
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 04, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e260 mp3 won't work
try uninstalling "MTP Device" in your computer's hardware device manager - add/remove hardware in control panel
May 03, 2008 | SanDisk Sansa e260 MP3 Player
Problem with sansa e260 mp3 player
Seems like your windows doesnt recognize your device...In order to solve your problems please make sure you follow the steps below...I would recommend that if you dont windows media player 11 to upgrade to 11...Then go under device manager to see if your device is listed there..to get to the device manager..click on your start menu, right click on my computer and then clikc on properties, hardware and then device manager...device manager will show you all the devices that you have install on your computer....If the device is listed under disk drives uninstall it and then unplug the device and replug it back...Also you want to make sure that you have your device connected on the back of your computer..For further assistance please contact me...
I hope this helps..
Please rate accordingly.
Thank YOu
Computerrep
Mar 18, 2008 | SanDisk Sansa e260 MP3 Player
MY sansa e260 MP3 player
Try to add the device manually.
Plug the player in while it’s set to "MTP" mode. (This selection is in the Settings area)
On your computer, open Device Manager, and select: Add Hardware.
Choose the "already connected the hardware" option.
From list, choose "Add a new hardware device".
Select: "Install the hardware that I manually select from a list."
Select: Portable Devices, then MTP device.
Hope it works for you.
Dec 31, 2007 | SanDisk Sansa e250 MP3 Player
Computer will not recognize
Did you check in Device Manager to see if the device has any errors listed? With the device connected Right Click on Computer>Properties>Hardware Tab>Device Manager button. Check for any red or yellow errors on the Sansa device. If there are errors, right click on it and select uninstall. Disconnect the device and then reconnect it to your computer. If thats not it, do you have Administrator Rights on the PC? If not you will need to switch to Administrator account and follow the steps at the top. You can add to this question for more assistance. Best of Luck.
Oct 01, 2007 | SanDisk Sansa e260 MP3 Player
Memory overload
Are you formatting it thru Windows Media Player or My Computer? If its WMP, try under My Computer, if it was under My Computer, try using Disk Management. Right click on My Computer and select Manage. Then in the next window, select Disk Management on the left side. ON the right side at the top, you should see your device listed, right click and select format. If your device does not show up in Disk Management, change the mode on the device via Settings>Mode or USB Mode. Best of Luck.
Sep 20, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
64 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
