Question about HP (153147-001) Sound Card
Hp laptop, Sound not working. Sound just left. Volume at full.
It has not been muted.
The volume is at full.
No need for wires because they are built in?
Why would they just stop working?
  • 362 Answers
You could have lostthe drivers go to hp. com and up date the sound drivers.
Posted on Dec 13, 2008
No sound from my HP laptop
Check if volume is muted in Windows. Check the bottom right hand corner and double-click on the speaker symbol. If not muted, turn the volume up from there.
Jul 04, 2014 | Microsoft Windows XP Home Edition Service...
Troubleshooting Laptop Sound Problems - No Audio Output
Can't hear any sound out of my laptop.
Diagnosis & Solution:
If you can't get any sound out of your laptop, the most likely cause is the volume being turned down or muted. Newer laptops monitor the external sound control so when the volume is turned up or down manually, the volume control in the operating system tracks right along with it. But with some laptops, especially those with external dial volume controls rather than toggles, the volume dials are independent of the software volume control and can't be monitored in software. In this case, if the volume dial is turned down on the outside of the laptop, the sound is turned off and nothing can be done in the operating system to change that. The only way to get the sound back is to turn up the external volume dial control.
If you have checked the external volume control on the laptop and the standard laptop volume slider in the operating system (the little speaker icon in Windows system tray) & you still can't get any sound out of the laptop, then the next step would be to check for any other software volume controls. Depending on the software installed and what you are trying to do, there may still be multiple volume controls and mixer panels scattered about the operating system. If the wrong channel is muted or turned down all the way in one of these independent controls, the laptop will not produce sound.
Most of the time, the first sign most laptop users get that their audio isn't working is the absence of operating system sounds, like the Windows rush on start up, or chimes with e-mail activity. Of course, these sounds can be turned off by design as well, through the Sounds option in Windows Control Panel. So, before looking at hardware problems, make sure these sounds are not turned off.
If you try to play an audio CD and the media player shows that the song is progressing but you can't get any sound out of the laptop speakers, odds are that the volume is turned down or muted. But it could also be due to an onboard sound hardware failure. If you are confident the volume is turned on in all possible locations and you've checked Windows Device Manager for a report of a hardware failure, try listening through headphones. If the headphones work, the wiring to the internal speakers has broken or come loose. Wiring failure is only likely if the speakers are in the lid and therefore wired through the hinges.
If you don't get any sound out of the headphones & you haven't missed a "mute" being checked off somewhere in software controls, then it really is a hardware failure. If the problem is with all sounds, including Windows chimes, internet radio, etc, then the problem is that the integrated sound processor has failed. In this case, unless the sound system is on a daughter card, it means the fix would require replacing the motherboard. But if the only thing you can't do is play audio CD's, then the problem is that the output from the DVD/CD player is muted or not getting to the amplification stage.
In modern laptops the DVD/CD players feature Digital Audio Extraction (DAE) which means that music CDs can be read digitally & the data passed to the built-in sound card or an external sound card replacement for processing, amplification then output. If there's a problem with the DVD/CD connector or if the wiring has been damaged, the music CD may get spun around without the sound making it to the sound card. The DAE output chip rarely fails on the CD/DVD drive, but the connector can fail. Make sure that digital playback is enabled in the properties tab of the drive in Device Manager.
You can replace your built-in laptop sound card with a PC card, with a USB sound card or USB speakers. These replacements make good workarounds if the integrated audio system fails. They also bring with them a whole new level of software with more volume controls, which are integrated with the existing operating system software. When shopping for replacement sound cards, keep in mind that USB solutions are much cheaper than PC cards. Also, when purchasing USB speakers to replace the laptop's sound system, don't buy speakers advertised as "USB powered". The "USB powered" speakers only draw their power from the USB port, they still need to be plugged into a regular audio jack to output any sound.
Please Vote for this Tip if you found it helpful.
M. Omran
on Nov 03, 2010 | Computers & Internet
I am having problems adjusting volume
What type of laptop HP , ASUS , COMPAQ , ACER ?..........
Up the Volume on My HP Laptop
Open the "Start" menu and click on the "Control Panel" icon.
Locate and open the icon that deals with sound.
Depending on your version of Windows, it will say either "Sounds and Audio Devices" or "Adjust System Volume."
Adjust the volume under the "Speakers" icon.
To do this, click on the slider bar and move it up on the slider.
If you need to decrease the volume, simply move the slider bar down.
Click on "OK" when finished and close the "Control Panel" window.
Click on the speaker icon in the bottom-right corner of the screen for a faster volume adjustment. Simply move the slider bar up to increase the volume and move it back down to decrease the volume.
Volume on an Acer Laptop
Acer laptops are typically sold with pre-installed Windows operating systems that offer sound-adjustment features for increasing the volume on the laptop's built-in stereo speakers.
These same functions can also be used in tandem with external speakers or headphones to increase the volume, as well as mute all sound on the laptop.
If the computer should output an unusually low volume, fixing the problem may be no more involved than sliding a control switch with the computer mouse. Click once on the speaker icon in the taskbar on the lower-right corner to open a rectangular window with a slide control.
Click and hold the left mouse button on the slide control to drag it upward, increasing the volume to the laptop's maximum setting.
Click the "Mixer" button below the slider control to open another window with volume controls for "Speakers" and "Applications," adjusting each slide control upward to increase the volume.
Be sure the speaker icon below each control is not accidentally muted.
Click once on each speaker icon to remove the red circle with a slash through it, which will restore audio.
Click the Microsoft flag or "Start" button in the lower-left corner if the shortcut speaker icon is missing from the taskbar.
Click "Control Panel" to select "Adjust Sounds" from the Hardware and Sounds category.
Aug 10, 2013 | Computers & Internet
HP pavilion dv9005us. When using built in mic receivers say volume is very low. When I move the lid I get a crackling sound in the speakers like the mic wires a lose ..
To fix the low volume problem in mic receiver follow the steps below:
  1. Click Start , Control Panel .
  2. In the left panel, select Classic View .
  3. Select Sound , and then select the Recording tab.
  4. Right-click on Microphone and select Properties .
  5. On the Custom tab, select Microphone Boost .
  6. On the Levels tab, increase the microphone recording volume to the maximum level.
Then please check if it works fine otherwise you need to install the latest sound driver.
Windows VISTA 64bit and 32 bitsound driver:
Windows XP sound driver:
Install the sound driver as per your operating system.
Apr 04, 2010 | HP Computers & Internet
My laptop's built in speakers volume is full but
I am assuming you are using some version of Windows here; in the taskbar (by the clock) you will see the audio control-it looks like a loudspeaker. Left click it and the a volume control will open.
Mar 08, 2010 | Toshiba Satellite Pro A210-EZ2203X...
No sound on my HP Pavilion dv4000 notebook, how do i install sound processor
Sound processor is built in to the machine.
Above the keyboard is a row of buttons - look for the one that has a loudspeaker symbol followed by a circle with a diagonal line through it - that is the mute button. Press it to mute/unmute. There are two other buttons for volume up and volume down.
Mar 05, 2010 | HP Pavilion dv4000 Notebook
Check on the following:
1. Check the Device Manager Window if the sound card is properly installed... If not then you'll need to install its proper drivers.
2. The volume control is not muted or at the lowest volume... there should be no checks on any of the check box under your volume control window.
Keep us posted if still does not work
May 23, 2009 | HP Computers & Internet
HP Pavillion dv 8000 no sound
check the volumes on sound driver.., also check maybe the master is muted ...if any of these won't work ..check wave volume also ...or reinstall the sound driver ....
look that when you double click the volume in trey system ( bottom right ) you get the full volume manager ..
if those would not fix the issue...uninstall the sound driver and reinstall it ..I assume you have the installation cd ..or the driver on disposal
Apr 08, 2009 | HP Pavilion dv6000z Notebook
Volume cannot be changed.Full Volume even if reduced or muted
You need to first find out what chipset your on-board card uses my friend. Check all the documentation to find out. You will need the exact set. Now search the net for an updated set of drivers that matches your operating system (XP SP1/2 etc). Now go to device manager and delete anything which has sound connections (MIDI Interfaces, MICs etc..). Now click the 'scan for changes' icon in device manager. Use the new drivers you downloaded.
Jan 25, 2009 | HP Pavilion dv6000z Notebook
HP (153147-001) Sound Card Logo
67 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
