Question about Lexmark Z65 InkJet Printer
Printing does not have correct repeat spacing after breakdown and reassembly
When printing labels, one got stuck to the feed roll. the printer had to be broken down to access the roll and remove the "stuck" label. after reassembling, when printing, there is a error in the vertical alignment of the print. the repeat is approximately every 2.75" (inches). I tried adjusting the gears within the printer and could achieve a repeating white gap of approximately .03" or an overprint of two lines repeating every 2.75". is it wise to print label sheets on this machine and are there any limitations?
3 Suggested Answers
SOURCE:
  • 85 Answers
SOURCE: Lexmark T640 won't print on label sheet a SECOND time...
try changing feed rollers. For a quick fix, remove the rubber rollers and flip them inside out. It should work
Posted on Feb 15, 2009
  • 286 Answers
Don't put used label sheets through a laser printer. Just because you had it working like that doesn't mean it's a good idea. We've had many laser printers in our shop here where the owners did that and eventually the edge of one of the removed label areas will get stuck on something (usually the fixing unit) and completely ruin the fixing unit requiring it to be replaced. Only use "Laser Printer Labels" and never use used sheets.
Posted on Sep 24, 2012
When I print a label I have to press the feed button to get the label out. How do I get it to push out the entire label without me having to feed and reset the whole time?
Most people I know print addresses from a sheet of labels, which ejects at the end. It sounds like you are printing one address from a continuous roll of labels, and they are so close together that the printer cannot push it out for you without misaligning the next one. I think both systems are designed mainly to print a batch of labels at one time.
If you are printing a batch, it is best to prepare the whole set first and save it as 'data' for printing addresses. For a one off or just a few I would use a sheet of 24 labels (say) with 3 to a row, and 8 rows.
Does this help?
Jan 06, 2014 | Argox OS-214 Label Printer
Paper not feeding
Hi
Open it up and check the installation of the labels.Make sure the roll is correctly fitted.
Turn it off and on.Solved?
Turn the printer off .
Press and hold the power button and then turn printer on.
Release the button.
The printer will print a test page.
Try feeding now.
Mar 01, 2012 | Epson TM U200B Matrix Label Printer
No print out
Hi Bjay,
If the printer cant print at all, you need to calibrate it.This is how you do it.
Make sure the printer is set as the default printer and then:-
  • Turn the printer off.
  • Open the printer and remove the labels roll.
  • Re-load the labels roll again making sure its correctly installed.
  • Press and hold the green feed button and then turn the printer on.
  • Release the button after the first flash of led.
  • Turn the printer off and on again.
  • Now try printing.
Hope this helps.Thanks!
Please rate this answer.
Nov 06, 2011 | Zebra TLP 2844-Z Thermal Label Printer
The machine prints about 12 labels and then prints about 25 empty ones, prints 12 and the pattern repeats. Restarted the computer three times and restarted the printer five times, nothing helped.
Hold in the Feed button for 4-5 seconds, which causes the printer to attempt to "Auto-calibrate." If that doesn't solve it, then slide out the Media Sensor (green plastic bar that sticks out over the labels) about 1 inch from all the way in ("in" = left if looking from front). Then press Feed to clear errors. If still get same error, then look for piece of label or ribbon stuck in that error - ok to blow out with canned air. Then try holding in Feed again for 4-5 seconds to Auto-calibrate again.
Feb 18, 2011 | Datamax DMX-I-4208 Label Printer
I have a Zebra Z4M printer. Just put new roll of labels in and they print one, sometimes two and then skip labels in between.
This is a calibration issue. The labels or ribbon are not loaded correctly. If they are, turn the printer off and then back on and the printer will run a calibrate. This should correct it. Once it is complete, you can verify by pressing the feed button and making sure it feeds one label at a time.
Sep 08, 2009 | Zebra Z4M Printer
Cannot set label length
Performing, Setting, and Troubleshooting Calibration Issues
This solution is useful for
  • Calibration: consistent positioning of the label and the print
Symptoms addressed by this solution include
  • Prints, then skips a label
  • Print is overlapping onto next label
  • Paper out error is occurring
  • Print position is drifting up and down on the labels
  • Labels stopping in random locations
Perform a manual calibration:
http://tinyurl.com/qyb9z3
Z4m + sensors
http://tinyurl.com/qeny9r
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 26, 2009 | Zebra Z4M+ Printer
Printing a label 4x 1 7/16
Try setting the page lenght using the printer panel
To do this, enter MENU mode by pressing SHIFT+MENU
press GROUP button until prints REAR feed or BOTTOM feed ( depend on where you load the forms from )
Press ITEM button until it prints form length
Press SET to change length as required
To exit, repeat SHIFT+MENU
All the best
KM Hoo
Feb 11, 2009 | OKI MICROLINE 590 Matrix Printer
Just tell me how to reset printer into factory settings. I have tried it by LPT1 connection and commands sent from command prompt, but doesn't help. The problem is that printer after print request...
To reset the printer.
1) Turn printer off.
2) Hold down feed button whilst turning printer on.
3) Let go of the feed button as soon as it starts to flash and then wait.
4) Printer will measure out 4 labels then print out a Hex dump ending with a not to "Push Feed to Exit"
5) Push feed
Follow the above instructions, if you mess around tapping the feed button (not following the above) you can change the printer between line mode and page mode. To swap that back is another storey.
David
Jan 28, 2009 | Zebra LP 2844 Thermal Printer
I-class cutting issues
You need to calibrate the printer using the instructions located in the manual. This should be in area 5.2 of the manual. If you don't have the manual you can download them at this address along with software updates and firmware updates.
http://www.datamaxcorp.com/software/i-class/
Label printers are always finicky. I have strtix printers where I work and they give off wacky errors too.
Sep 19, 2008 | Datamax DMX-I-4212 Label Printer
Continual feeding of labels?
the settings of the printer must have been changed
May 20, 2008 | Dymo LabelWriter 400 Thermal Printer
Lexmark Z65 InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
