Question about HP Officejet 5610 All-In-One InkJet Printer
HP Officejet 5610v - Won't print black
Not sure what happened - my black will not print. It looks like it is printing but no black. Cartridge shows 1/2 full on screen - Does this with both black ink cartridges
  • mkbryan Dec 29, 2008
    I've cleaned the copper terminals with multiple Q tips, tried 3 different full black ink cartridges (it's not a cartridge problem), and still no black printing with test page or any other print option including "Use black cartridge" setting in print options. The only workaround is to select all text, select dark blue, and then print.
  • HP Master
  • 990 Answers
Use Q-tip to clean up the copper contact see what happen
Posted on Dec 13, 2008
Cartridge error 5610v
Did you remove the paper protector from the jets? Did you lock the cartridge cassettes in securely. Did you cycle the power off for at least 1 minute?
Jan 02, 2013 | HP Officejet 5610v All-In-One InkJet...
Hp officejet 4255 black colour print not very clear
Select print in grey scales only in printer properties while shooting the print command, printer is using color cartridge instead of mono cartridge..
Jan 11, 2012 | HP OfficeJet 4255 All-In-One InkJet...
Can the printer print with only the black cartridge in or do you have to have both the black and color cartridges for the printer 5610v all-in-one to work?
90% of HP printers require both. I have not personally tried the 5610, but when I worked retail, I remember hearing a lot of complaints about it and HAVING to have both color and black in.
The reasoning behind having both cartridges in:
Ink is a liquid. When a liquid sits, it dries. Inkjet printers use print heads (microchips) to transfer the ink from the tanks to the paper. If these print heads get clogged. Say goodbye printer (or atleast is ends up costing more to fix, than to replace).
Aug 28, 2011 | HP Officejet 5610 All-In-One InkJet...
Black won't print, colo prints fine.
Check the level of black ink. Make sure the black cartridge is not empty. If it is empty, replace it.
May 28, 2011 | HP Officejet 6310 All-In-One InkJet...
Hi i have a hp officejet 4355 all in one printer at my place. i m having problem fixing with the cartridge as it is showing error. pls guide
Problems with Hewlett Packard Officejet 4355 printing can often be due to issues with the cartridges. The printer has two cartridges, one black and white, and one color. Both can be physically inspected for problems. The printer also has a self-test report to determine if there is a non-obvious problem with the cartridge. The report can provide valuable information, including status.
  • 1
    Take the black ink cartridge out of the slot on the right. Be careful not to touch the ink nozzles or the copper contacts.
  • 2
    Look at the cartridge and make sure that the plastic shipping tape isn't still attached. There shouldn't be any tape covering the ink nozzles.
  • 3
    Replace the black cartridge and then perform Steps 1 and 2 on the color cartridge. The color cartridge is the one on the left side.
  • 4
    Print a self-test report. Load paper in the tray and press "Setup." Press "2" and then "4." The HP Officejet 4355 will print a report. Make sure the lines of color extend across the page. Missing, faded or streaky lines can indicate a cartridge failure. If the color bars don't show as black, cyan, magenta and yellow, you should clean the cartridges.
  • 5
    Press "Setup" and then press "6" and then "1." The print cycle will commence. Allow it to complete and then print another test report. If the test still shows errors, replace the cartridges.
  • Feb 01, 2011 | HP Officejet 4355 All-In-One InkJet...
    Black Cartridge HP 27
    Color cartridge HP 22
    Photo cartridge HP 58
    Jan 27, 2010 | HP OfficeJet t45 All-In-One InkJet Printer
    How do you change the ink carterage in an hp officejet 5610v all-in-one?
    Hello !
    To change the ink cartridge(s) in your printer,
    Open the print-carriage access door by pulling it forward.
    The print carriage moves to the far right side of the HP All-in-One.
    Remove the cartridge.
    Take the new cartridge from the package.
    Remove the strip from the cartridge without touching the metal back.
    Insert the cartridge.
    Hope this helps.
    Oct 04, 2009 | HP Officejet 5610 All-In-One InkJet...
    Hp officejet 5610v all in one insallation software for windows vista
    Try this link. It is the full intall file for the all in one being run on a Vista Machine. It worked fine for my installation.
    Muck around on the site for a bit, and you can also find the same install file for Windows XP.
    Good Luck
    Jul 22, 2008 | HP OfficeJet t45 All-In-One InkJet Printer
    HP Officejet 5610 All-In-One InkJet Printer Logo
    331 people viewed this question
    Ben Johnson
