XPS no power problem
I read in a previous problem/solution about replacing the motherboard to fix no power (w/good ac and batt) on the dell xps. I have the same problem, on a first gen XPS. Now, is this THE only possible cause for this or are there other things that could be the root problem? Also, where would I get a new motherboard--through dell? I couldn't find it listed on their website. What's one of those going to cost, about? Is it something that I could replace easily by myself (I have a little experience switching out things, but never a laptop motherboard!)?
Thanks, Ryan
  • 3 Answers
Before you go out and replacing the actual motherboard, you can make sure of a few things... besides the motherboard costs around $500so make sure that is the actual problem.
I have sort of the same problem, but in my case the battery does not charge, so if your battery started to die and you have made sure the charger was good, then it could be that the DC jack board is cracked or just the weld came loose.
Try the Dell support page first for a step by step check if you like, once there look up the problem, it may ask for a tag number on the computer.
  • http://support.dell.com/support/index.aspx?c=us&l=en&s=gen&~ck=mn
Once there you can even find the manual for how to take apart the laptop...but it's kind of hard to find; maybe you can do an engine search and find it quicker.
If you want to check out the DC Jack boards, here are a couple of sites that may help you out on what you are looking for...just make sure of the model you have.
  • http://www.laptoprepairparts.com/partpicture_LRP.asp?ref=604&category=dcjack
  • http://www.laptoprepairco.com/partpicture_LRCO.asp?ref=881&category=dcjack
There are some computer places that can do this for you and depending if you live near one it can run from $89 to $150, at least that's what I found.
I still can use it directly from the charger, and I may open it up to see if it's the weld only. According to the pictures in the manual I downloaded, it's pretty straight forward.
Best of luck, and make sure it's the motherboard before you order it... $$$
Gabe
Posted on Dec 28, 2008
Alert. previous attempts at booting this systemhave failed at checkpoint [0032]
XPS 8500 Desktop booting fails - General Hardware - Desktop - Dell ...
en.community.dell.com/support-forums/desktop/f/3514/.../19452875
Dell
Jun 13, 2012 - 16 posts - ‎9 authors
I am sorry to know the concern with the computer. As you .... I have the identical problem on a 3 week old XPS 8500 desktop machine. It seems ... Dell XPS 8500 - Will Not Boot At All - Motherboard ...
Aug 13, 2014
Dell XPS 8500 Unable To Boot
Jun 25, 2013
New Dell XPS 8500 won't boot
Dec 5, 2012
XPS 8500 UEFI boot
Oct 29, 2012
More results from en.community.dell.com
How to Use and Troubleshoot the XPS 8500 ' Dell US
Dec 15, 2015 | Dell XPS 8500 Desktop Computer; Intel Core...
Both fans stopped
Hi
make sure the funs are working in another machine or using a battery if it works the problem is the motherboard.
May 05, 2014 | Dell XPS M1730 Laptop Power AC Adapter /...
My Dell XPS 200 will not turn on.
Have you checked to see if your power supply is still good, or the power supply connection to the motherboard is good?
Sep 14, 2012 | Dell XPS 200 PC Desktop
My Studio XPS laptop does not stay powered without being plugged in. Replaced the power adapter in case it was not allowing the battery to charge. Ran dianostics on the battery and no problems with it. ...
Yes. If the battery is still ok and the ac adapter had been replaced, then it could already be a problem with the motherboard.
You may try to flash the BIOS of the motherboard first, here's the link:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=STUDIOXPS13&os=WLH&osl=en&catid=&impid=
Select your operating system and download the driver under BIOS, saved on your computer and run it.
If that does not fix the problem, call Dell to have them check the motherboard.
Jan 05, 2011 | Dell Studio XPS 13 Laptop AC Power Adapter...
Won't power up.
Try power drain by removing the battery and ac adapter then press the power button for 10 seconds. Plug the ac adapter back in and set aside the battery. Turn the system on.
If it doesn't power up, run the diagnostics utility by pressing the Fn+Power button at the same time.
If it still doesn't power on, motherboard needs replacement.
Note: Your XPS M1530 might still be under warranty. Dell can replace your motherboard for free.
^_^
Jun 09, 2010 | Dell XPS M1530 Notebook
Dell XPS 1530 wont power on at all..
Troubleshooting is pretty simple.
  1. Try a different Dell 90W or larger D/E-Series AC adapter and see if the system gets power. If no known good AC adapter is available, then check output voltage of AC adapter (Should be about 19VDC or so) If you can't do either, then the AC adapter is still the cheapest item to replace for a no power issue.
  2. If system will not power on with a known good AC adapter or new one, then the motherboard is the likely failure point. Roughly $150 on Ebay
Feb 24, 2010 | Dell Computers & Internet
Dell xps m1210 won't power up with new battery. Check notes.
If it is working fine with a fresh battery then it is not a motherboard problem. It is either a bad ac adapter jack on the motherboard or the actual ac adapter cord is not working. Try cables2go.com as they have replacement ac adapters for almost everything under the sun. Hope this helps.
Jul 10, 2009 | Computers & Internet
Xps m1210 is dead and no power even with a new ac adapter
The M1210 suffers from the same die packaging problem with its Nvidia GeForce Go7400 chip as many dell laptops do. However dell does not admit this, and has only extended the warranties for recently manufactured laptops.
To get Dell to fix your laptop, despite it not being covered by the extended warranty, follow the instructions I have posted here: http://forum.notebookreview.com/showthread.php?p=4611553#post4611553
Dell is trying to cover up a critical flaw in what is supposed to be a high performance gaming laptop. It is my goal to make Dell come clean about this issue. Lets all let them know that they cannot get away with screwing over their customers like this.
Nov 25, 2008 | Dell XPS M1210 Notebook
Dell XPS 400 no power to usb or pci slots
I have had the same problem with my dell xps 400. What I did was purchased a usb power hub and that solved the problem for me. SAved me from buying a new mother board.
Sep 09, 2008 | Dell (002TR) Motherboard
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
