Question about Sony STR-DE675 Receiver
Sony str-de675 cuts out in dts mode
Cuts out in dts mode when in opt mode ..plays fine in analog mode with just normal dolby digital
    Genius:
  • 1,199 Answers
Your optcal line may have a break in it ! try another opt cable or try useing the digital cable out!
Posted on Dec 13, 2008
5.1 sound system (blue light) does not come on. sound comes and goes, sometimes quiet, sometimes lound. dolby does not seem to work .
what is your source? (DVD, Cable, Blueray, etc.) My guess is that you have your source set to output PCM instead of bitstream. Check this in the menu of your output source. If it is PCM, it will only output 2 channels unless you are using an HDMI cable. If you are using an HDMI cable, the sound should be the same, but it is sent directly to the speakers using your receiver as a pass-thru. Your receiver will not detect it as dolby or dts as it is not actually doing any processing. When you check the menu, bitstream may also be listed as "digital". Hope this works for you.
May 23, 2010 | Sony STR-DE675 Receiver
Hi i have problems with SOny STR-DE958 and DTS. I use Win7 and optic cable. When i test for DTS my Sony didn`t make any noice. Only work Dolby. I test with normal cables in Multi in all work. And optic...
What's connected to what? And which way are you going? Is a PC part of this scenario (you mention Win7)? Maybe you should start there.
The Sony knows DTS. The PC, who can say?
DTS is a bitstream-audio function and many sources need to be told to send it to their digital outputs because without decoding it will only sound like high volume static noise. The DTS-compatible receiver decodes it to its analog multiple channels. It doesn't suk. Look it up on Wiki.
Feb 10, 2010 | Sony STR-DE598 Receiver
How can i get the dts sound field to work. Shouldn't it automatically switch to that sound field. I have a samsung bluray dvd that hooked up to it.  The dolby pro logic and pro logic 2 indicator...
If you are playing media that has both dolby digital audio and dts audio, your player and your receiver will decode the first audio codec listed first by default unless you select it otherwise yourself. If your remote or receiver has an A.F.D. (auto format decode) button, press it until your display shows that the sound source is dolby digital or DTS, whichever sound mode it was you wanted when you started your DVD.
Dec 12, 2009 | Sony STR-DE597 Receiver
Airport extreme
Try this in this order:
  1. Verify your aux on the DE675 is working with another analog audio source.
  2. Unplug the G5 -> optical -> DE675 and try playing itunes through the Extreme only into the DE675's aux.
  3. Optical digital audio output on the Mac is VERY fussy, so I'd stay off of the optical unless it's absolutely necessary.
  4. If you're finding that the Extreme is not putting out any sound at all, try this: Reset and update the firmware on the Extreme. Also, make sure your Mac is very updated with the latest iTunes, operating system updates, etc.
Mar 19, 2009 | Sony Audio Players & Recorders
Preamp/Processor missing menus/options for DTS
Solved the recognition of DTS signal issue but the DTS options/settings in the menus are still not appearing - believe the previous owner may have upgraded the software. The solution for the DTS signal recognition was an output setting on the DVD (blu-ray) player - digital output vs analog.
Jan 27, 2009 | NAD Audio Players & Recorders
Samsung DVD-R155 will not play in Dolby Digital surround sound
You need to buy a digital coax cable Just 1 run out of player and into amp!
Dec 06, 2008 | Samsung DVD-R155
Is it worth it
the reciever you have is a dolby prolodgic system. the rear channel is monoral, that is that both rear speackers have the same infomation to it (and not much of it). the new suround sound systems are dolby digital/DTS suround sound. there is a major differance to the sound and the information presented. all channels are discreat and information provided by you digital outputs of your equipment provide the channel info (tv via optical digital out, DVD also optial or coaxal digital out, cable box also optical.)
May 11, 2008 | Sony STR-DE525
NO SURROUND SOUND WHEN PLAYING BLU-RAY
Your amplifier should "downgrade" the signal to 5.1, even if the disc isn't using it. It is most likely a setting on your amp that may need adjusting for "types" of digital to accept on its input. If you can, set your optical input on your amp to "auto". This way it will automatically detect and switch for the proper incoming audio feed
Jan 01, 2008 | Sony Playstation 3 (PS3) Console
Problem with Dolby Digital mode
If it is a new DVD that may be a problem, as signal changes may be frustrating this old machine... but it is likely the cabling from the DVD player to the reciever. Are you on the right channels/settings? is the optical cable and digital cable recieving digital output from your DVD player? Try changing those settings and you should be in good shape Thanks! good luck!
Jul 22, 2007 | Yamaha RX-V3300 Receiver
Sony STR-DE675 Receiver Logo
143 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
