Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
My light works but the motor won't kick on, Frigidair top freezer
I keep it in the garage as a beermeister and I'm in Pennsylvania so the garage temp can go from 20 degrees in February to 80 degrees in August. The fridge is only 5 years old. My beer is getting warm, can anybody help?
Posted on Dec 20, 2008
Freezer not working when its cold in the garage.
Where do you keep the fridge? If you keep it outside then most likely the condensor coils in the freezer may be freezing over and the only way to fix that is to keep it above 40 degrees outside the fridge.
Jan 18, 2017 | Refrigerators
Inhave just reurned from a short holiday and found My Miele f1313s freezer has the alarm light flashing. Thoughts?
Make sure you have enough amps in the outlet its plugged into. The kitchen outlet might of had more amps than the garage outlet. Also, try unplugging it for a few seconds then plug it back it which might reset it.
Sep 20, 2014 | Miele 3.7 cu. ft. / 105 liter Upright...
I have a Kenmore refrig./freezer (top freezer, bottom refrig.) that stays in my garage all year long. After this very cold winter, it has stopped working. The light goes on, but no sound of motor, and...
-Possibly no more Freon.
Try this:
-Turn the control switch all the way to 0. Let it stay for 10 minutes or more then turn it up to number 5 to see it kick the motor or not.
If not then possibly the relay is bad.
But if there is power there then the motor is bad.
Good luck and do not store any food in until it had fixed
Dec 12, 2017 | Kenmore 61282 / 61284 / 61289 Top Freezer...
Frigidaire refrigerator with a broken freezer
He is correct. The temp in the refrig controls how often and for how long the refrig runs. Lets say the temp in your garage is 34 degrees, and you have your refrig set to 36 degrees: The refrig will never run, the fresh foods section will cool to 34, and the freezer will warm to 34. Even if the temp is 45 in the garage and you set the fresh foods to be 33, the refrig will not need to run long enough and often enough to keep the freezer temp cold enough. You will most likely need to have the ambient room temp at least 55 degrees to get satisfactory refrigerator performance. Insulating the refrig will not help. (by the way, outdoor beverage vending machines use an internal heater in cold weather to prevent liquid beverages inside from freezing,..... so using that info, you could put a low wattage heater in your refrig to make your refrig run enough to make the freezer section work. The %&#* with that, just move it into the house!)
Feb 06, 2010 | Frigidaire FRT17B3A Top Freezer...
I recently had to throw away some questionable food that had partially thawed in the freezer cabinet of my kenmoore, model# 253.67882508 fridge with freezer on top. i keep this fridge in my garage and in...
probably,there is a garage kit available that willallow it to work at colder temps,listed in owners manule under accessories the thermostat senses refrig compartment temps.soif garage temp is below 40 or so the thermostat just doen't turn the unit on enough or not at all
Jan 17, 2010 | Refrigerators
Freezer compartment on refrigerator not cold enough
depending on the temp it could
if the ambient temp get below 32
you freezer wont come on and actually begin to get warm (insulation factor)
but the refer will seem cold because of the low ambiant temp is the temp inside
we go in the refer alot more than the freezer
Mar 28, 2009 | Frigidaire FRT21S6A Top Freezer...
Top mounted freezer on refrigerator not working
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
Jan 22, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
I have a refrigerator in my unheated garage. How do I keep it working in sub freezing weather?
it will not work in sub freezing temps, the thermastat will not kick on if the temp is below 34 thus the freezer coil will thaw and anything is the freezer will melt, anything in the fresh food section below 32 will freeze 60 or below not recomended
Apr 15, 2008 | Refrigerators
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
98 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
