Question about Whirlpool LTE5243D Top Load Stacked Washer/Dryer
Whirlpool thin Twin Model #LT5000XL
Water runs into the washer and onto the floor. HELP ME
    President:
  • 373 Answers
Check for corrosion or crack on the outer tub. also inspect the hose behind.
Posted on Dec 13, 2008
Whirlpool thin twin LT5000XUWO why water not shutt off overflows
bad water solenoid, underneath that is the unit that the water goes to and there are wires coming from it it is sticking in the on position
Aug 25, 2014 | Whirlpool Thin Twin Washer and Electric...
Overflowing Washing Machine, water does not stop filling, overflows to floor. This is a Whirlpool Thin Twin Stackable
sounds like you have a bad water level pressure switch part 3362987
http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Washer-dryer-combo-Parts/Model-LTE5243DQ6/1198/0152000/W0604125/00001?blt=06&prst=&shdMod=
go her part number 10 in diagram or there could be something in the hose,the hose could have fallen off or could have a hole in it,i can't find a video with a stack machine but this explains your problem
http://www.youtube.com/watch?v=jzKBUI5D0Vs
Mar 30, 2013 | Whirlpool LTE5243DQ Combination...
Thin Twin has a slow water drip when not running
If it drips while the washer is off then you will need to replace the "water inlet valve". Here is the part you need. Here is the service manual to show you how to access the valve and replace it.
Oct 28, 2012 | Whirlpool LTE5243DQ 24" Compact Thin Twin...
Whirlpool thin twin ylte6234dq2 washer/dryer water overflow!
first access the tech sheet and run any diagnostics it shows for the machine and if this passes,then check/change the fill switch on the control panel along with fill tube from the wash tub base if kinked or plugged
May 10, 2010 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool Thin Twin YLTE6234DQ2 washer is leaking water from the bottom. I need to remove the front panel to see what the problem is but can't seem to get it off. I have looked at suggestions to push in...
have you looked near the bottom of the front panel near the floor,there are 2 or 3 screws located at a 45 degree upward angle(to hide them from view) so they dont show,remove these and the front should hinge upward like an auto hood and the clips near the top should let go when its raised far enough upward
Apr 18, 2010 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool Thin Twin WET3300SQ (water stops coming in)
  • We are sorry to hear of the problem with your Whirlpool washer. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Digital@Whirlpool.com with your name, phone number, address and the model and serial number for your washer.
Apr 07, 2017 | Whirlpool LTE6234D Top Load Stacked...
Our Whirlpool Thin Twin model#LT7000XTWO will not start when pressing on the start button.Washer works.Could the problem be the starter button or the timer switch? Thanks, Ernie C.
Hello birddog44,
Happy to help you.
You said, Our Whirlpool Thin Twin model#LT7000XTWO will not start when pressing on the start button.Washer works.Could the problem be the starter button or the timer switch?
If the washer works, I can only assume, you are talking about the dryer not starting when you press on the start button.
I believe that it just might be the start button.
Is it a gas or electric dryer?
You have the Whirlpool Thin Twin model#LT7000XTWO
How old is this appliance?
The model # sounds like an older model.
If the appliance is 10 years old or more you may not be advisable to put good money into bad! New appliances are so much more efficient today that they can save you a lot of money in energy.
Therefore they pay for them selves in only a few years.
You can buy New and save today.
Find the small privately owned and operated appliance store and you will get better service and good treatment! They also will be the best informed!
Bless You,
huuum
Please give me a solved rating for this good advice
Sep 14, 2008 | Dryers
Whirlpool Thin Twin washer won't start, just makes humming sound
The belt is broken and needs to be checked for any other part that has failed causing the belt to burn.
May 26, 2008 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool LTE5243D Top Load Stacked Washer/Dryer Logo
192 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
