Question about Whirlpool LTE5243D Top Load Stacked Washer/Dryer
Water goes in washer and onto floor
Thats about it. We run the water into the tub and it leaks out on the floor.
There is a plastic tub that surrounds the wash tub it may be cracked or have a hole in it. Mine did the same trhing until it was replaced.
Posted on Dec 16, 2008
Float switch dripping water onto floor while dishwaser running
You will find that the flood switch will be operating due to the leak, it will most likely be from one of 2 places:
1. Around the door seal, Give it a clean and check for splits/damage, and make sure screws on door hinges are tight.
2. Check the rollers that screw onto the inside of the dishwasher cabinet, The screws on these can come loose and cause water to run down into the base, check they are tight.
Hopefully this helps.
Mar 04, 2012 | Dishwashers
My GWL11 top load washer just stopped working and keeps resetting the circuit breaker. Any ideas what is wrong ? How to fix it ? Thank you.
Could be many things,is the machine leaking water on floor,if so water could be leaking onto electrical parts underneath such as the pump or through the motor.The tub seal could be leaking or the pump could be leaking.thats all i can think of given the limited information.
May 25, 2010 | Fisher and Paykel GWL11 Top Load Washer
Replace washer for hose - washer leaks
You have to determine if the water is coming from the hose connections. If not, check that the water supply that feeds into the basket hasn't been moved out of place. Is this a new washer? I have seen cracked outer tubs-they are just plastic.
Nov 08, 2009 | Whirlpool Washing Machines
Water leaked from bottom of washer
Check the pump right where the motor shaft goes into it. The pump seal can leak right there and the water drips directly onto the floor. It will continue to run out after the cycle till the remaining water drains out of the tub and drain hose.
Jun 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machine Emptying
Sure sounds like a hole or crack in the tub.  Unplug power, shut off water, and disconnect the hoses.  Tilt the washer onto its front and look underneath.  Use a light to inspect the tub bottom and sides for a hole or crack. If it is small enough you might be able to plug it with silicone sealant.
May 27, 2009 | Washing Machines
About 1 minute into the cycle water starts running out from underneath of the washer. Checked all the hoses that are connected to the back and none are leaking
this is either the front seal that goes from the outer tub to the front of the washer or a hole in the outer tub itself or one of the hoses underneath the seal and the hoses are easiest to check you can take a cup of water and slowly pour it into the front seal. take care not to overfill it to where it spills into the tub and see if you are getting water on your floor from that. the hoses tip the washer up onto its back and look at them from the bottom for any cracking etc. the tub itself can only rust out on some of the neptune models or on others is plastic and can get punctured. just have to look for damage with a light and a mirror.
May 19, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Whirlpool Cabrio Washer- When draining, water leaks out of hole
probably rubber hose from tub to pump broke, access from back or bottom, (cabrios are open bottom) pump in rear. there is a recent bulletin about tub ring not channeling water from dispenser completely into tub
Mar 07, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
GE top load washer leaks on floor
Check your hoses mostly the small hose going from the side of the tub to the water switch these come off a lot. you need to look and see if the seal is leaking from the center of the tub you do this by putting water in the tub and just looking around the bottom of the tub and transmission
Dec 29, 2007 | Washing Machines
Maytag performa washer
check to see if the tub to pump hose has pulled off
Dec 18, 2007 | Fisher and Paykel GWL11 Top Load Washer
Whirlpool LTE5243D Top Load Stacked Washer/Dryer Logo
98 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
