Question about Amana NAV5800A Top Load Washer
Amana washing machine grease inside
I think my motor is blown and should trash my washer. I have grease on the inside of my washing machine. What could that mean.? I did a load of wash and noticed a little bit of black in the bottom, I put old towels in did another load and the black stuff was much more and it was like spider web all over the inside, when I touched it it felt like grease.
  • Anonymous Mar 04, 2009
    yeah i always have all these little dark brown or black spots all over my clothes it is so annoying... help!
I have a agtag and it squeak at the end of the cycle as it is stopping. Is there a way to grease the brake?
Posted on Dec 27, 2010
    Novelist:
  • 116 Answers
What you are describing appears to be a transmission leak. Some of these machines have a 5 or 10 year warranty on the transmission your machine's use and care manual should tell you if yours is covered, it is usually on the last page of the manual.
Posted on Mar 11, 2007
Gunk gets on clothes-stains them,i pulled agitator out and cleaned it off ran bleach thru-its better but still getting on clothes
The problem may be the seal on the transmission failing. If this happens, grease from the transmission (necessary for it to function) will leak and float (recall from science class that oil is less dense that water) up into the washer. As the grease enters the tub, it stains your clothes.
Washer Transmission Replacement Whirlpool Kenmore Top Load Washing Machine...
Washer Leaks Water GE Top Load Washer Tub Seal Replacement Part WH02X10383
Jan 21, 2016 | Amana 3.2 cu. ft. Top-Load Washer
I have Amana # W10192130 washer ..it fills with water..then nothing..stops com pletely
Your motor needs replaced try setting the water level to its lowest setting and slow speed. A light load should wash if not check belt inside
Feb 19, 2013 | Amana Washing Machines
Amana washing machine banging
Since this is a brand new washer I would recommend that you MUST get free warranty support before you even try to do a do it yourself job.
Please Call up support, possible that the suspension or the dampers or the bearing/motor support has failed and if so you must get free replacement.
Jul 29, 2012 | Amana Washing Machines
Amana ALW880QAW doesn't spin and agitation is slow
winephan,
I could be the pump slowly ceazing causing the belt to slip which would give a burning smell.
Motors in those units, are well build...have a service guy in but DON"t say anything about the motor.. because they will say it because you mentioned it
I sounds like you pump
Jul 22, 2010 | Amana ALW880WH Top Load Washer
My washer keeps leaking grease onto my clothes!
the problem that you have is the bearings have badly worn,a lot of companys will just replace the entire drum rather than mess about with the bearings as this does not always solve the problem.sorry to give this bad news.
Jul 15, 2009 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
How to change drive belt on Amana washer
remove the 4 bolts holding motor to tub and frame remove wire harness from motor remove pump hoses turn assembly upside down 3 torx screws hold pump to motor note routing of old belt around idler pulley and pump studs reinstall in reverse
Apr 23, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Amana top load washing machine will not stop cycling through or shut of. Just keeps going through all the cycles.
Try this for you timer.
That is if you are handy and can open the washer to work on it.
UNPLUG FIRST!
Just carefully clean all the contacts and put contact grease on them.
Feb 16, 2008 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Water wont stop
With these symptoms, there is only one culprit, the inlet valve is stuck or there is trash inside the valve body holding the seals open. You have removed all other possible culprits by unplugging the machine.
You have two options:
1) Replace the inlet valve.
2) Sometimes you can take the valve apart carefully and clean it out and put it back together and it will solve the problem.
The valve is not hard to take apart, you just have to observe and remember where everything goes.
Jan 27, 2008 | Amana DLW330RA Top Load Washer
ALW480DAW Washer Doesn't spin
had same problem grab agitator and rotate it clock wise and you should hear a clinging noise and try again to wash, it should be fine
cost free for now
Jan 20, 2008 | Amana ALW480DA Top Load Washer
Amana NAV5800A Top Load Washer Logo
504 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
