SOURCE: HOW DO I RESERT TO FACTORY SETTING MY DELL DESK TOP
Dell may have put the restore files on a separate- hidden partion as many OEMS do nowadays. When your computer boots hit alt+f10 this will boot the partition recovery. This will only work if dell have done it.
I know it works with acer laptops and desktops so give it a try and let me know
SOURCE: Where do you plug the speaker wires into the Dell
the green input is for speakers....look for a small green ring gl
SOURCE: Dell Dimension 4600 desk top out of virtual memory
Some computers can be slow or short of hard drive space for quite simple reasons.
Windows and other program hide temporary files in lots of different places
The best option is not always a program or utility and if you want to do as much as you can for FREE like I do then you have a few options.
1. First you need to be in windows explorer.
2. Click TOOLS and FOLDER OPTIONS
3. Now click the VIEW tab
4. Tick the Show Hidden Files And Folders option
Unpick Hide Protected Operating System Files (it may warn you but you can ignore it)
5. Click APPLY then OK
6. NOTE some files may not delete this is OK Also DO NOT DELETE the folder itself where mentioned for cleaning.
7. Using windows explorer go into the WINDOWS folder and look for a directory called TEMP (it is possible there may be more than one)
8. Select all the contents and delete them. Do the same for any other temp folder e.g. temp000
9. Now navigate to Documents and Settings
There are quite a few folders in here that can be cleaned up
10. Look for folders named "Local Settings" In there you will find more TEMP folders that can be cleaned out
11. Now look inside the Temporary Internet Files. Delete anything EXCEPT cookies. Otherwise passwords for some sites you have stored may need you to type the password again.
12. Do this for each user / profile you see.
13. Now check the C: drive itself and see if there are any Temp folders and clean those out too
To prevent accidental deletion of any files windows needs you should go back to step (4) and change the two settings back to their original
Hope this gives you the information you need
Bob
Moderator
It would be very decent of you to consider the quality of our experts answers and judge them accordingly as you pass through FixYa.
Thank you
SOURCE: I have a Dell Inspiron 531s that presently has
yes, the system will accept PC2-6400 RAM
Depending on the processor installed, there may not be any increase in performance.
Reference:
http://www.crucial.com/store/listparts.aspx?model=Inspiron%20531s
SOURCE: My CD will not eject out of my Dell XPS One Desk
Look in front of the CD Drive, there should be a small pin-hole. Straighten out a paperclip and stick it into the pinhole on the drive, it will release the latch and open up.
Try updating windows to latest service pack and all patches. There are some updated CDRom drivers that may get updated to resolve your issue.
