Question about Samsung SRS20DTD Side by Side Refrigerator
Vacation button keeps on activated(refrigerator Samsung SRS20NTC)
Vacation button keeps on activated and blinking on average every 30-90 seconds. As a result, the temperature keeps on changing from 9 C to -1 C. The fridge temperature fails to remain constant (normally we set to 6 C). As for now, the fridge keeps on making sounds (alerting us) as if it has been set to vacation mode. I have tried deactivate the vacation mode by pressing the vacation button but it is activated automatically afterwards. Thanks in advance.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Set to regular temp then lock functions.
Freezer temp + fridge temp for 3-8 sec to lock function
Posted on Apr 21, 2009
  • K Webel
    K Webel Feb 15, 2014
    When you lock the function, will the fridge make any noise, etc. to verify that it has been accepted?
The adjust temp numbers on my GE side by side fridge went out
Try this 1. First make sure the machine is turned on and running, both fans and compressor should be running. 2.Then unplug the machine for minimum 2 minutes. 3.Restore power to the refrigerator and wait 2 minutes. 4.Control diagnostics test using the display does not use error codes to identify problems. Instead, the temperature display allows access to components or systems to be checked if a problem is detected. 5.The temperature display must be in an active mode before entering the self-diagnosis test. 6.If the display is blank, press any temperature button once, then release it. The display will show actual temperatures.7. Enter the diagnostic mode by pressing both the freezer temperature (COLDER and WARMER) pads and the refrigerator temperature (COLDER and WARMER) pads simultaneously. All four pads must be held for approximately 3 seconds. Blinking "00"s in both the freezer and refrigerator sections of the display indicates the refrigerator has entered the test mode. 8.Remove fingers within 5 seconds and press any pad to lock-in the test mode. The blinking "00"s will change over to solid (non-blinking) "0"s when the test mode is locked in Failure to lock-in the test mode within 30 seconds will time out the test and return the refrigerator to the normal cooling mode. 9.Use the temperature colder or warmer pads to enter 1 in the freezer display and 5 in the fresh food display and press any button. This will cause a system reset.10. Wait 30 seconds and try to adjust the temperatures again. If the problem still exists, remove the cover over the motherboard behind the machine.11. Measure the voltage between J4-2 and J4-3 You should have 12 VDC (do not disconnect the J4 connector).12.If the voltage is correct confirm the voltage on the display board J3-2 and J3-3 I 13.if the voltage is correct, replace the display board. If not replace the motherboard.
Aug 24, 2017 | GE Refrigerators
I would like to change my ThermoScan from Celsius to Fahrenheit but I am not sure what buttons to push to achieve this
Changing the temperature scale from F to C: - - Turn on the thermometer - If the unit is already on, make sure it is not in the memory mode - Press the ?/MEM button and keep it pressed. Then press and release the activation button to switch over to the "change temperature scale" mode. - By pressing the activation button again, the opposite scale will be activated. Each further pressing of the activation button rotates the measuring scale
May 06, 2011 | Braun IRT3020 Thermoscan Ear Thermometer
Keypad on garage door will only close if i punch in my code it won't close by hitting the enter button the temp here is minus 40 does that effect the keypad chamberlain 3/4 belt drive
Try this procedure to reactivate this feature.
Opener can be closed by pressing only the ENTER button if the One Button Close feature has been activated. This feature has been activated at the factory. To activate or deactivate this feature press and hold buttons 1 and 9 for 10 seconds. The keypad will blink twice when the One Button Close is activated. The keypad will blink 4 times when One Button Close is deactivated.
Dec 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
My wired key pad in the garage opens and closes the door but the buttom keeps blinking fast. My two car remotes stopped working. My remote key pad on the house works. Whats with the fast blinking and...
Press and hold for 3 seconds the button on the wall control that has an icon of a lock. The light should quit blinking and your remotes will once again work. Holding that button for 3 seconds toggles your openers vacation mode.
Nov 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
On my HP Pavilion I set the BIOS to change the boot order from the CD drive first. Then I intalled Fedora 9 and when I tried to reboot the machine will not boot. I have tried booting with the Win XP cd in...
try resetting all the connections and also disconnect the power cable from the back of the computer and hold down the button for 10 seconds and start the system that should work
Feb 01, 2009 | HP Pavilion 753n (P9852AR#ABA) PC Desktop
Remote Control won't work.
How does everything look well? How old is unit? Did you push learn button for 10 seconds. Then pusj for 1 second and activate a remote button. lightbulb on motor should blink. if so, hit learn again for 1 second and push button on other remote. Do you have a LOCK or VACATION button. Make sure it is off . Is light on wall console blinking. you have remotes locked out.
Jan 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door remote won't open the garage door
The little button with a padlock on the wall control is a "vacation" lockout feature that disables the remotes. There should be a small LED on the wall control that is always on steady. When the padlock button is pressed and released the LED should be constantly blinking (indicating the vacation lockout mode is active) and your remotes should be disabled. The wall control will still operate the door. Pushing the padlock button again should make the LED stop blinking and restore the door to normal operation.
Jun 18, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garage door went on "vacation"
Try to remove the power cord. Be careful if you have to climb a ladder! Reinsert.
Here are instructions for vacation mode:
If you have a three buttom wall panel, one of the small buttons should be the lock button, push this button and hold it for a couple of seconds until the LED on the wall panel stops blinking.
Good Luck!
Jan 01, 2008 | Sears Craftsman LiftMaster Chamberlain...
Honeywell oil radiator
Press the *power button* once to start the heater on high power, continuous run. If left at this setting, the unit will run continuously on high power (1500 watts, 12.5 amps) and will not shut off until the unit is manually turned off.
Press the *power button* again, to change to low power, continuous run, (900 watts, 7.5 amps) and will not shut off until the unit is manually turned off.
Set temperature:
Press the temp/timer button until the temperature icon blinks. Use the up and down arrows to set the desired temperature.
The temperature icon will stop blinking and the current room temperature will reappear after the desired temperature is set.
The heater will turn off and on to achieve the desired temperature.
Set timer: (auto off)
Press the timer/timer button until the timer icon blinks. The hour display will appear. The auto off icon will also appear.
Use the up and down arrow buttons to set the heater operation time between 1 and 10 hours. This function will activate once the timer icon stops blinking. The heater will automatically turn off whn the times runs out.
Set timer: (auto on)
Press the temp/timer button until the timer icon blinks. The hour display will appear. The auto on icon will also appear.
Use the up and down arrow buttons to set the heater start time between 1 and 10 hours. This function will activate once the timer icon stops blinking.
The heater will automatically turn on when time expires.
Hope this helps!
Sep 24, 2007 | Honeywell /KAZ HOME ENVIRONME HZ-705 7Fin...
Refrigerators Logo
2,042 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
