Question about iLO (2 GB) MP3 Player
Write protection i cannot read nor save in my flash drive any document...what will i do?
I could not locate the storagedevicepolicies under currentcontrolset or controlset001 or 002 or 003. There is a USBFlag heading, but no writecontrol string. Any advice?
Posted on Apr 03, 2010
OK – after an hour or so of faffing around :knock: , I think that I have found a possible solution write protection - tongue.gif . The problem seems to be something to do with Microsoft’s SP2 dead.gif !
Here’s what worked for me (sorry for the Idiot’s Guide approach, but I used to :hotbounce hate it :hotbounce when I used forums and couldn’t understand what the technobabble meant!):
- Start > Run > type ‘regedit’ (without the speachmarks) > Enter
- Single-click on ‘My Computer’ > File > Export > save it to the Desktop (Always best to have a backup!!)
- Go to the following:
My Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDeviceP olicies
*There seems to be some spaces here in 'StorageDevicePolicies' in the text above, there shouldn't be, OK*
- Double click on the string ‘WriteProtect’ and change the ‘Value Data’ box to ‘0’
- Then: File > Export > save somewhere useful as something like ‘StorageDevicePolicies001.reg’
- You also need to do this for the strings in any folders called ‘ControlSet***’ (* = any Digit, i.e. 001, 002) – for example: Everything is the same, just change ‘CurrentControlSet’ to ‘ControlSet***’
My Computer\HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\StorageDevicePolic ies
- Save these to the same place as before as ‘StorageDevicePolicies00*’
The saves are in case it reverts at a later date, just double click (saying ‘yes’ to importing these to the registry) on all of the files and it will all work again!
Posted on Dec 15, 2008
The disk in write protect
When formatted, the disk is write protected (there is damage to firmware)
Damage to firmware, there are two types
1. Damage to firmware, data can be saved
2. Damage to firmware, data can not be saved
To fix the Transcend flash drives, you can use the JetFlash Online Recovery software, customer support from Transcend. This program can be used to save data, partition table repair Damaged and repair firmware.
JetFlash Online Recovery, you can download here Transcend Customer Support
How to use JetFlash Online Recovery, and analyze damage to the flash drive, can you read in my blog. To find my blog, how:
Write a keyword in Google seach engine "Aplus Computer Fix Transcend Flash Drive". Analysis and how to use the JetFlash Online Recovery can you read in my blog.
Hopefully this information helps
Dec 19, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My transcend 4 gb pendrive is write protected .how can i remove the write protection
When formatted, the disk is write protected (there is damage to the firmware)
Damage to the firmware, there are two types of
1. Damage the firmware, data can be saved
2. Damage the firmware, data can not be saved
To fix the Transcend flash drives, you can use the JetFlash Online Recovery software, customer support from Transcend. This program can be used to save data, partition table repair and repair the firmware.
Nov 07, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
What file format do i save a word doc to my sandisk 2 gb
The USB flash drive is capable of storing any type of file. Save it as a word document (.doc) or anything else. However, if you use the drive on a computer that does not have WORD on it, you may not be able to open it. There are other programs that can read WORD documents: Libre Office, Corel WordPerfect and many other documents viewers.
Aug 27, 2011 | SanDisk 2GB microSD Memory Card
Good day, We have microsoft office 2007 installed, it work perfectly, and suddenly it stopped working and threw out an error box that reads as follow; [ This modification is not allowed because this...
This behavior may occur if the document is protected with an editing restriction of No changes (Read only) or Comments.
Word 2007
* On the Review tab, click New Comment.
Note If you insert your comments in this document, you can save your changes and then return the document to the sender with your comments.
* In the Protect Document task pane, click Unrestricted Access.
Word 2003
* On the Insert menu, click Comments.
OR
* On the Protect Document task pane, click Stop Protection.
Note If the Unprotect Document dialog box appears for you to type a password, the document is password-protected and you cannot stop the protection on this document unless you know the password.
Mar 14, 2011 | Microsoft Computers & Internet
Access issue to my flash drive
The drive is probably password protected by Securlock software.
Hope it helps.
Aug 30, 2009 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
My PC could not save file in my flash drive where as folder can.
Maybe the root of the USB drive is protected. If you got any switch for write protection in the USB drive, unlock it and try saving.
Thank you!
Sabharish
Jun 03, 2009 | Dell Dimension 1100 PC Desktop
PNY Write Protected
Check and see if you can copy and paste that file from it's location and place it on the desktop. Basically seeing if you can move that file within your PC. If this is a work computer, it might have precautions built-in to write protect it's documents. If you can move the file around in your computer then it's probably a problem with your flash drive. Can you copy anything to the drive?, such as a simple text file, music, etc. I'm also assuming that you checked the properties on the drive itself to make sure it wasn't locked. You could also try another flash drive to eliminate the possiblilty of your stick being defective.
Let me know how you do.
Sep 05, 2008 | Computers & Internet
iLO (2 GB) MP3 Player Logo
173 people viewed this question
Top iLO Audio Players & Recorders Experts
Michael Vincent Cruz
Allen Benge
Level 1 Expert
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
