Question about HP Computers & Internet
HP Laptop There is indication that the laptop is on, however, the screen is black. It appears frozen.
I´m not sure this is the solution but we had the same problem with our old compaq laptop. the button (hard to find, if it has one) that shuts the screen off when it is shut, could be stuck. if so you might need a needle or something to stick in the hole and unstick it
Posted on Dec 13, 2008
HP laptop screen is black
A blacked-out screen doesn't necessarily indicate a broken monitor.
If the computer has run out of charge or is in hibernation or sleep mode,
if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on. To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power.
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard. Press the power button if the screen remains black.
Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue. Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue. Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases.
Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop.
Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Slide the battery latch to eject the battery. Pull the battery out of its compartment. Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard. Wedge the edge of the keyboard bezel off of the top cover.
Work your way along the edge of the keyboard bezel to loosen it.
Pull the bezel off the laptop.
Trace the cable coming from the laptop screen to the connector found beneath the bezel. Reconnect the display cable to the motherboard if the cable has come loose from the connector. Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place. Turn the computer back on. If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective. If the external monitor works, the LCD screen could be broken. If the monitor doesn't work, the motherboard or video card might need to be replaced. Hope this helps
Jan 08, 2013 | HP VM114UA notebook
HP Pavillion Laptop 1/3 Bottom Screen intermittently inaccessible
Sub out the ram memory one at a time and to see if this will make the difference.
Apr 22, 2012 | HP Computers & Internet
Hp g6 531nr laptop black screen
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Mar 08, 2012 | HP Computers & Internet
Why does my hp laptop screen black?
Mar 06, 2012 | HP Computers & Internet
Hp 550 laptop; frozen screen then when re started blank screen
1. Can you get to any screen in the BIOS?
If so, your screen is ok. This may sound silly, but, power OFF and remove & re-seat the memory modules. Video uses some of that.
=== OR ===
2. Connect a monitor to the VGA connector on the back and use the laptop that way and so you can further debug the system
Sep 21, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Laptop screen flickering in hp laptop. had it for 1 year. screen stays on but flickers black very quickly
You most likely have a faulty CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Aug 05, 2009 | HP Computers & Internet
Hp pavilion turns on but i have a black screen. can't get on internet to download anything to help can you help?
The HP model you are talking about has graphic card issues. Usually when you see a black screen when the laptop turns on, it indicates a graphic issue.
If you search in the HP forums about black screens on start up it shows a bad graphic card.
If the laptop is still under warranty contact their support techs online with a different computer and let them know whats going on and they should have you send it to them for a replacement card.
Jul 08, 2009 | HP Pavilion dv6000z Notebook
Compaq presario v3000 (v3322tu) turns on but appears dead
According to your question ,there is a problem with RAM of laptop ,bring it out again install it properly.
if it not work you to replace it with new one.
Apr 06, 2009 | HP Pavilion dv6000z Notebook
HP Pavilion Dv6700 black screen after booting up
Go to the following HP website to view the problem and how to fix it:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01443366&lc=en&dlc=en&cc=us&product=3636595&rule=21826
Hope you see what you are your looking for! Good Luck!
If you have any more problems let me know.
Thank you for using Fix Ya!
Don't forget to rate the overall satisfaction of this answer!
Jan 30, 2009 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
44 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
