Question about Sony Handycam DCR-HC42 Mini DV Digital Camcorder
No display on lcd screen
I am not able to see anything on lcd screen. But blindly i can press the menu keys and operate. This is very irritating for me to use camcorder without lcd display. please help me regarding this matter. the colour was changing from green to yellow to orange and finally everything vanished. now its totally blank screen waiting for suitable suggestions. srihari
    Problem Solver:
  • 19 Answers
Hai First check other functions, If all the functions ok then LCD ribbon cable may be defective, replace LCD ribbon cable. best of luck udupi Prathiksha Electronics Bangalore
Posted on Mar 12, 2007
I have a taylor ice cream machine thats keeps a constant beep even when ice cream is ready model 339-27
I'm not 100% on this model but here goes....
A "beeping" tone will sound to alert you
of a fault.
To discontinue the tone, access the Operator
Menu and enter Option B. Correct the fault, then press
the OFF (<--) key, and the tone will stop.
FYI Fault Description
(Option B)
This option lists any faults detected by the control and
allows the operator to clear them from the system.
When a fault is detected it will be displayed on the
second line of the LCD. Pressing the MENU/SEL key
will display the next fault found or return the display to
the Operator Menu if no additional faults exist. If the
OFF key is pressed when a fault is displayed, all faults
that have been corrected will be cleared from the LCD
upon returning to the Operator Menu. To return to the
Operator Menu, press the MENU/SEL key.
for 337.....
Screen display.....
The POWER SWITCH OFF screen indicates that the
power switch is in the OFF position.
POWER SWITCH OFF
The normal operating screen will display the current
mode of operation and the level of mix in each mix
hopper. (The power switch is in the ON position.)
MODE: OFF
MIX:
L = OK
Operator Menu
_________________________________
The Operator Menu allows the operator to access
operational information and to set non-critical
functional parameters. The Operator Menu also allows
access to the Service Menu. (Note: Only service
technicians who know the access code may use the
Service Menu.)
Operator Options
A
Exit From Menu
B
Fault Description
C
System Information
D
Current Conditions
E
Service Menu
Pressing the OFF (<--) key will move the cursor one
position to the left. Pressing the STBY (-->) key will
move the cursor one position to the right. Both keys
include the "wraparound" feature. This means that
when the cursor reaches the end of the option, any
further movement in the same direction causes the
cursor to "wraparound" (to be placed at the opposite
end of the option listing)
here's the manual if you don't have it....
http://www.taylorfreezersales.com/op_man/0337op0.pdf
Best to you hope this helps a little
Mar 05, 2018 | Taylor Ice Cream Makers
How to clear bizhub 163v memory
1. Press the Menu/Select key.
2. Press the following keys in this order.
Quick Settings ?< ? ,< ? Quick Settings ? < ? >
3. The SERVICE MODE menu screen will appear.
11.10.2 RAM TEST
A. Use
• Write or read data to/from RAM memory to make sure of normal operation.
• When test finishes and everything is okay, it will display "RAM CHIP IS OK" and automatically clear DRAM.
After DRAM clear finish, LCD will display "DRAM IS CLEAR!."
B. Procedure
• Pressing the Menu/Select key will start the check.
• After approx. 30 seconds, "RAM CHIP IS OK" will appear.
Does not work have a tech come out
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 16, 2016 | Konica Minolta bizhub Office Equipment &...
Operate Bios Blindly
Have you tried holding Fn key and pressing one of the function keys with picture of display on it?
Jul 19, 2013 | Sony Vaio White Pcg-71913l 15" Intel Core...
Olympus Stylus 850 SW LCD screen will not turn on. The camera itself will turn on and take pictures but i must do it blindly. i cannot see the pictures nor can i see through the lens.
If you camera is built with a viewfinder there is usually an option to de-activate the lcd screen. Usually if you press the display or play button on the back it will re-activate. Also try to access any of the menu's by pressing the menu button. If this does not work also then the LCD is probably bad or not making connection. You would have to find a local service center for repairs. www.phototech.com is the local service center in NYC or you would have to send directly to Olympus in Woodbury Long Island.
Good Luck
Paul
Jul 05, 2011 | Olympus Stylus 850SW Digital Camera
How do you reset the lamp timer for a sony Bravia
Turn on the projector
press MENU (as show in picture step by step)
use down arrow key and select SETUP
press ENTER
use down arrow key to select LAMP SETTING
press ENTER
menu screen below will be appeared.
ON SCREEN display
setting for lamp replacement
Has the projection lamp been replaced?
YES NO
Select YES with left arrow key (yes is preselected)
press ENTER
ON SCREEN display
lamp replacement process is now complete
press ENTER
now exit the MENU with menu key and check the lamp timer
Feb 09, 2011 | Sony BRAVIA VPL-AW15 LCD Projector
Sony bravia tv
Press Display button on remote once and on screen dsiplay will disappear.
Sep 12, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Laptop lcd display
sounds like your screen went out, if you need to access whats on your laptop real soon try hooking it up to a desktop monitor via rgb cavble.
Dec 13, 2007 | Computers & Internet
SCREEN MESSAGE - MODE NOT SUPPORTED
You have set a resolution that is too high or incompatible with your monitor. I assume you are using Windows. Turn the computer on and immediately keep pressing F8 on the keyboard until the 'Windows Advanced Options Menu' appears. Use the Up and Down keys to select 'Enable VGA Mode' Press enter and your screen will work again when windows starts. Now go to the display properties and click 'Advanced' then click the 'Monitor' tab and tick 'Hide modes that this monitor cannot display' OK everthing and now you should be able to adjust the resolution without getting a blank screen again! Good luck and come back to comment soon. Regards
Sep 26, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
Change LCD screen back to English
Issue: How do I change the language setting of the LCD?
Solution: Change the display language settings (MP170)
LCD Appears in Japanese (or other foreign language) Upon powering on the machine for the first time, the LCD will prompt to select a display language. If a language other than English is selected, the setting can be changed by following these steps.
  1. Ensure the machine is powered on.
  2. Press the <Menu> button as many times as necessary to display [SYSTEM SETTINGS].
    1. From the Copy mode standby screen, press <Menu> 7 times.
    2. From the Scan mode standby screen, press <Menu> 1 time.
    3. From the Memory card mode standby screen, press <Menu> 6 - 12 times.
  3. Use the right arrow twice to select [OTHERS] and then press the <OK> button.
  4. Use the right arrow three times to select [LANGUAGE SETTING] and then press the <OK> button.
  5. Use the right or left arrow to select the appropriate language and then press <OK>. Choose from the following language settings.
    1. JAPANESE
    2. ENGLISH
    3. GERMAN
    4. FRENCH
    5. ITALIAN
    6. SPANISH
Sep 11, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Lcd viewer is not functioning
Hello, in this case there is a broken flat cable called FP-185 pn:186476111. You should also replace the cover pn: 218843302. Best option for you is to contact the nearest Authorized Sony Service. If you need more info please advice
Mar 10, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Sony Handycam DCR-HC42 Mini DV Digital Camcorder Logo
316 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
