Question about Jensen 8.5'' Overhead DVD Player Package (MVB85) Car Video Player
DVDS stuck in overhead DVD player
Hello I am looking for help! I have on overhead DVD player.. my son accidentally put two DVDs in at the same time... I can't seem to get them out! One of them plays, but they will not eject. How do I get these discs out!!???? HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!
  • Anonymous Apr 27, 2009
    I have an Audiovox that came with our used vehicle & it had a disc in & I insterted another one.
  • francisfam1 May 17, 2009
    we brought our truck 2 days ago.. kids wanted to try out the overhead dvd player. dvd began to freeze and now it won't eject. :- ( HELP!!!!!
  • 71 Answers
The motor will not be strong enough to eject. you can try the emergency eject hole with a paper clip . just push straight in and the gears will began to turn so push straight in a couple of times and it should began to eject.
Posted on Dec 13, 2008
Dvd player is jammed and wont open can you help
try taking the outside cover off then you might be able to manually open it .
Jan 28, 2015 | Philips DVDR3440H DVD Recorder/HDD...
DVD will not Eject
answer - had the same issue turned out to be 3 dvds in it, Remove the 4 screws holding the dvd player to the roof. wire harness will hold it up. There is an fm transmitter on top held on by three screws. remove the little screws and push the transmitter to the side. you winn now see the stuck dvds. push the extras out with a small screw driver. once they are out the eject button will eject the last dvd.
just worked for me hope this helps.
Jul 04, 2009 | Jensen 8.5'' Overhead DVD Player Package...
Have a Polaroid TDA-03211C tv with dvd player. Won't play DVDs
As long as you know a disc is not stuck inside I recommend taking it to your local svc center to be looked at.
Feb 28, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Our Sony DVD player will not playimported DVDs from the UStates
1) those DVDs are coded in Region 1(Canada, United States; U.S. territories; Bermuda)
you will have to change the region code on the dvd-rom to region 1
2) if you bought the stand alone DVD player in the U.S. it will play region 1 dvds and nothing else(some dvd players will play region code 1-6)
3) to change the code in windows vista you'll have to go under the drive property's in the device manager go to the dvd region tab and set it to what ever the number on the back of the dvd is WARNING you only get 4 changes before the drive locks you out permanently then your stuck with what ever number you put in on the 4th try you've been warned
windows xp/2000/98/me
you'll have to change the region code from your software player again your limited on how many times you can change the region code before you have to reinstall the dvd player software
Feb 02, 2009 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
DVD player won't eject dvds
I am not a pro...did this process early today.
1.Remove 5 screws from bottom center dash. This peice has the cubby with change slots. There are 2 on the left side, 2 in front and 1 on the right. Pull out of the way.
2.Pull cup holder all the way out and depress tab on the very back of the top. Slide out and remove.
3.Pry small peice of plastic out of the way carefully with screwdriver. Remove.
4.Revove 2 screws that where hidden by this small part. Begin prying the dvd and radio surround off from the bottom, there are no more screws. Either let dangle to the side or unplug and revome from car.
5.Remove 2 screws to release dvd player. Unplug 2 seperate connections and remove. If you have change in it, shake upside down a little while slightly depressing the top to give room for $ to fall out. For 2 dvd just work out carefully while trying to line up the dvd with the opening.
Hope this helps someone! Kris
Aug 31, 2008 | 2005 Dodge Caravan
DVD player not working
Hello riceclan_dad
It could be a compatibility issue w/ the media you are using. To that end, ...
(01) Do you get this error msg. w/ original DVDs?
(02) Or are you trying to play DVDs created at home?
If your answer is YES to (01), then it is unlikely the issue is media incompatibility.
If the answer is YES to (02) (and NO to (01)), try using DVD-R dvds (media) rather than DVD+R (DVD+R is a newer standard that older players do not recognize).
There is another FixYa post (similar issue) w/ one solution HERE. The expert suggests having the lense (on the DVD player) checked and possibly replaced.
Please, let us know if this helps.
Thank you,
Apr 02, 2008 | Durabrand PDV-709
Jensen MVB85 A8.5 dvd player
Problem: All DVDs would not play in Jensen MVB85A overhead 8.5 DVD player. Error code: "Incorrect Region Code"
1. Use the remote to power on DVD player
2. Ensure there are NO DVDs in the drive
3. When you see the DVD logo screen, press 9653 on the remote
4. A hidden menu will open stating the region code. My region code was set to 0 and my I was receiving the error.
5. Press the "OK" button to change the Region Code to "1".
Once the region code was set to 1 all DVDs were playing.
Key words: Jensen Audiovox MVB85 incorrect region code
Nov 13, 2007 | Jensen 8.5'' Overhead DVD Player Package...
Mi dvd-burner doesnt recognize blank DVDs and doesnt burn them
try downloading thier Dvd player play and burns everything and you can do a trail run for 20 days or so lala linda
Oct 03, 2007 | NEC ND-3540A DVD RW Dual Layer Burner
DVD not loading
you have to look on the back of your dvd player to see what region your player is then you will have to check the dvds that you have from colombia and warner bros and see what are thier dont have to purchase a new dvd just dont buy or rent dvds from the above mention place.if the region on the dvds of both place do not match your dvd player you will be wasting your time.good luck.
Apr 18, 2007 | Mitsubishi DD-8020 DVD Player
My dvd always shows "system error" and won't play commercial copyright dvds, only recorded ones.
I had the same problem with my recorder except that it wouldnt play any discs at all.. I finally unplugged the recorder and left it unplugged for 16 hours. Now it is fine. I am not getting any error messages.
Nov 23, 2006 | Toshiba D-VR4 DVD Recorder/VCR
Car Audio & Video Logo
1,481 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
