Question about Microwave Ovens
Microwave runs 3 sec then shuts off.
I tried to heat up some water, the microwave ran about 3 to 4 sec then shut off, tried 4 times with same results.Manfg date is May 2004. It is a Panasonic Inverter Model NN T 994SF
  • ddmdavid Dec 13, 2008
    STARTED WITH THE TURNTABLE KEPT TURNING WHEN YOU OPEN THE DOOR, NOW WHEN YOU PUSH START THE TIMER QUITS
  • Microwave Ovens Master
  • 9,098 Answers
Mtystufquit - We've already discussed this by chat & e-mail, and if and when you need further help, please let me know.
"If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle."
ddmdavid - you probably have a bad door switch or door switch mount. Please see these links.
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
If you still need help, please create a new post with your brand and model number.
Posted on Dec 15, 2008
Solution-GE spacemakerXL microwave oven model:JVM16505H01 mfg.date:feb.2005
Sounds like you have a bad smart board, you can try unplugging the unit for five minutes and then back in, if you are lucky this may correct the problem...good luck
Feb 18, 2014 | GE Microwave Ovens
Will only run for 23 sec, then shuts down. hit reset and it will run for 23 sec again. THis happened after it was exposed to a boiling pot of water. The run time is very consistant before stopping,...
mcdevito75 here, Sounds like the timer mechanism which is most likely transistor board is wet or shorted, see any appliance repair shop in your area for help.Or Check the owners manual for repairs.
Jun 28, 2010 | Panasonic NN-S254BF Microwave Oven
Panasonic Model No. NN-S933BF Microwave Oven
No sorry the issue will be with eiher the inverter, the magnetron or the main timer board. There is a tracer signal that comunicates through these components and if it doesnt get to where it is supposed to go it wil just shut off, the big hint at that is the time interval. It is not something like a sensor heating up and causing a fault. it is not running long enough to get any thing hot it is in the electroincs. Too expoensive to repair, im sorry better to get a new one. Good Luck
Jun 17, 2017 | Panasonic NN-S950BA Microwave Oven
Whirlpool over the Stove Microwave
This sounds like the unit is defective and if I were you I would return for replacment!
Dec 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Shuts off
change your electrical wall plug to a diffferent one, do not use extention wire pls, there is insufficient to drive your microwave, thats why it resets and restarts again
cheers
Nov 25, 2008 | GE JVM2070 Microwave Oven
Microwave shut-off within 2-3 minutes
Why don't you return it? I think this is a common problem. We returned ours to Home Depot with no questions asked.
Nov 12, 2008 | Magic Chef CMV1000B Microwave Oven
Power cuts out after about 5 seconds
Hi try unplugging form mains for an hour this will reset any settings back to factory settings let me know what happens after doing this then i can assist you further ok
Mar 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave shuts off after 2-5seconds
The problem is most likely the magtube, it takes aprox 3 sec for the tube to energize and then it kills the microwave. If you drop the control panel away and start the microwave 90% of the time it will cook fine.
Nov 19, 2006 | Emerson MW8102SS 1100 Watts Microwave Oven
Microwave Ovens Logo
178 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
