Question about Campbell Hausfeld 26 - Gallon Air Compressor
No air pressure past 60PSI on a 125PSI Campbell Hausfield WL61110
Campbell Hausefield WL611102AJ 5HP eletric motor with 28 gallon tank. The electric motor runs non-stop, but the PSI in the tank only gets to 60 PSI. The tank oressure is suppose to be 125 PSI. If I turn off the compressor 60 PSI is held for 2 days so far. I don't here any air leaks Any suggestion would be greatly appreciated. The compressor is about a year and a half old
  • Campbell Hau... Master
  • 1,388 Answers
Your comperssor is oilless type and suffers from short cylinder / piston life. When the compressor no longer reaches cycle pressure the cylinder / piston should be replaced. These parts are available at I believe that the part number is wl210300aj. Not expensive, enjoy.
Posted on Dec 13, 2008
Campbell Hausefield air compressor WL660700AJ
IF there is not a lot of condensation in the tank and the unloader valve on the tank is ok, then the issue is the thermal cut off inside the motor. IF it is bad, you will most likely have to order a new motor or have that one rebuilt.
Sep 20, 2016 | Air Tools & Compressors
Pressure asdjustment
open pressure switch an dunscrew main screw/nut inside tthis will reduce the tension on the spring inside and will cause it to cut out earlier
May 06, 2013 | Ingersoll Rand TS4N5 Ir Electric...
My Campbell Haufield compressor does not shut off once it fills up why?
If the motor pumps the tank up to the maximum pressure then keeps on running you have a broken pressure regulator. Replace it, as over filling the tank can be extremely dangerous. The pressure regulator listed by C-H for your compressor is part number CW210100SJ and should cost you $40 to $45.
Feb 02, 2012 | Campbell Hausfeld Air Tools & Compressors
Compressor will build up air pressure to shut off point then will release air pressure for about 30psi
Check Valve in the tank where the air
enters from the tubing leaving the compressor
Call Campbell & get a new one
They are good to talk to on the phone
& you can order parts without all the internet hassle
Sep 20, 2011 | Campbell Hausfeld 5HP 20 Gallon Single...
I have a campbell hausefield vs series air comp and when it reaches full air supply and shuts off air leaks (alot) out of the switch i replaced and nothing changes.
There is a check valve on the tank where the line from the pump goes to. It should also have a smaller line running to the pressure switch. If the valve or spring inside is broke or stuck it will leak as you describe. You need Campbell Hausfeld part number CV221502AJ.
Dec 22, 2010 | Campbell Hausfeld 5HP 26 Gallon Single...
I have a 26 gal 5 hp upright campbell hausfield air compress. it will not buildi up air all of a sudden. it is building some as when i pull the pressure relief some air comes out. Any suggestions.
Hi, my name is John. Welcome to FixYa. check all your air lines for leaks, check the valve at the bottom of tank, check the line coming form the pump to the tank. You may have to remove it to inspect it. I find this one always is over looked. Thanks for choosing FixYa...John
Nov 15, 2010 | Campbell Hausfeld 2 Gallon Air Compressor
Compressor problems when filling tank
There should be a device called an "unloader " connected to the machines own switch. This releases the pressure from the compressor so it can start up without the resistance of the pressure in the tank.There should be a hissing noise when the machine stops, the sound of the air on the compressor side of a non return valve being released.
Jun 03, 2010 | Campbell Hausfeld 13 HP 30Gallon Air...
Wanting to adjust my cut off pressure down...its at 135 now but have in line tank, campbell switch 60 gallon
If I read your problem you would like to decrease your pressure setting on a campbell hausfield compressor, this usually can be done by turning the 3/8" nut (typical) counter clockwise which decreases the spring tension on the pressure plate allowing less pressure to break the points. Hope This Helps Don
Dec 02, 2009 | Campbell Hausfeld Air Tools & Compressors
Husky 17gal 5hp compressor will not cut off when it builds up pressure. Pressure valve will pop open and then I cut it off buy hand
bad pressure switch or it is wired incorrectly replace switch and check the wiring or could be out of adjustment you compressor is made for max 125psi should be a screw to adjust on the pressure switch near where the wires are connected back out counter clockwise to lower and see if that turns it off
Feb 20, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Campbell Hausfeld 26 - Gallon  Air Compressor Logo
994 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
