Question about Amana PTH123B25AJ Heat Pump Air Conditioner
Need parts for an Amana PTH123A25AA PTAC
Most especially the heating units.
If there is a parts manual that would be great too!
  • cheks3 Apr 24, 2009
    ptac keeps tripping surge protector, wont reset
  • 142 Answers
The Amana parts line # is 1-800-227-2919, you can also obtain parts numbers and names from their website, www.amana-ptac.com.
Please rate this answer and let me know if this helps.
Posted on Feb 11, 2009
  • Tommy Walker Feb 11, 2009
Amana PTAC unit not cooling right out of the box?
If you was not transported upright, it will need to sit 24 hours before use.
Jun 23, 2017 | Amana Heating & Cooling
Where can I find a troubleshooting manual for the DS01E amana t-sta?
http://www.amana-ptac.com/Portals/3/PTAC/PDF/DigiSmart%20DT%20DS%20DD%20Wireless%20EMS%20Installation%20Instructions%202010.pdf
Feb 19, 2015 | Amana DS01E - DigiStat Thermostat with...
PTC123D35ARDA SERVICE MANUAL
Try this:
http://www.amana-ptac.com/Portals/3/PTAC/PDF/IO-PTAC2.pdf
Dec 02, 2014 | Heating & Cooling
If you unplug an Amana PTAC unit and it freezes what could happen?
If you are not going to run the unit put a large bag over the out door section. The unit will be just fine.
Jun 08, 2017 | Heating & Cooling
My amana ptac is not heating....the code "np" is displayed....how do I correct this...we just installed the unit and know little about operation. Thanks
I don't see this error code in the manual. I do see nP as an error code for Window Switch lockout. I just had this happen to me and they had me reset the control board.
Remove case, flick master switch to OFF for 10 seconds. Press Heat/Cool same time turn switch back on HOLD until off light comes on.
You should be fixed. Just had to do this for my unit. I was playing around with the settings and turned on the window switch option by accident.
Feb 02, 2013 | Amana In Wall Install Kit For Digismart...
I need a manual for a Amana PTAC model PTH123A35AC. I been looking for one & just can't find it. Please any suggestions, thanks.
Here's a good place to start: http://www.h-mac.com/brands/cooling-brands/amana.html
The Amana PTAC PTH123A35AC is obsolete and replaced by the Amana PTH123E35AXXX. The literature is similar. Search out your model # and than visit the "literature" tab to find everything's that available. Everything from service manuals to parts manuals. Good luck!
Aug 27, 2012 | Heating & Cooling
I HAVE A AMANA PTH153B50AE PTACT UNIT. ANOTHER
Do you think you have a heat pump outside ?If so then I would call the installer back and show me how to operate the control.They should have did that when it was install.
Apr 06, 2009 | Amana PTC153B50AJ Electric Heat Air...
Amana PTAC PTC093A35AA won't blow heat
The reset button is located behing a panel on the front of the unit that is labeled Heat Reset. If that label is gone then look around, it is a small hole, small enough for a paper clip to fit through.
That being said, I have 137 of these units in one of my hotels and have not had a single one needing to be reset. You probably are going to need a new control board kit. These can be purchased from Amana. They are $130. Make sure that you have pulled the heater coil out and inspected it first. Also, there was a recall years ago where Amana was supposed to contact and send out new voltage switches. These are the round black things that the Brown heater wires connect to on the upper and lower side of the heating coil. You should also try to replace those if you find the coil in good condition. I have had those resolve heating issues. Most of the heating issues were a result of a bad relay on the control board though.
Please remember to rate this fix.
Jan 23, 2009 | GE Zoneline AZ38H12DAD Split System Air...
Amana PTAC
Sounds like if this is a heat pump, maybe it tripped out on high pressure. Maybe just unplugging the system may reset the control boards. This maybe due to a dirty filter or dirty evaporator coil.
Nov 18, 2007 | Amana PTH123B25AJ Heat Pump Air...
Amana PTH123B25AJ Heat Pump Air Conditioner Logo
910 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
