Question about Sander Industrial Original Clarke Floor Drum Du-8r
I have a clarke c-5 edger need parts
The sander has a broken disk
  • 2,176 Answers
I checked Clarkes site and they don't show this tool. Suggest you call 1-800-253-0367 and ask for technical support. I deal with this company on a weekly basis at work and they are great in helping. Good Luck
Posted on Dec 25, 2008
I have a Clarke Model 504 floor drum sander. where can i find paper for this?
I would recomment trying a local rental yard. they usually have the paper and machines for rent. If not let me know and I will do some more research with Clarke, give me your general area with zip code and I will try and find a local source.
Jan 09, 2011 | Sander Industrial Original Clarke Floor...
Clarke plate sander vs drum for a floor that only needs
drum sander leaves chatter marks you must plate these out. belt sander is the best way to go, however it will take longer to just plate than to drum and plate. for light sanding i would start with a 60 grit on the drum, then 80, then 100. plate with 100 screen till chatter free, then final with 150 screen. this is if you intend to go to raw wood.
May 13, 2010 | Clarke Floor Sander Floor Sander Orbital...
Removing armature from clarke super 7r edger and how to remove rubber backup plate that supports sanding discs.
The rubber backup plate threads on. You can make up a bracket to insert into the 2 larger holes of the plate. You must keep the fan of the edger from turning to unscrew the plate. I use a hard piece of wood or if you are careful, a large screw driver. The plate unscrews counter-clockwise.
Mar 10, 2010 | Tools & Hardware - Others
I have a Clarke C-5 Edger and need parts
what kind of parts are you looking for. I had Clarke American Sanders send me a copy of the breakdown and I will try and help you.
Nov 15, 2009 | Clarke Tools & Hardware - Others
It seems the sanding table has frozen to the eccentric on my orbital clarke floor sander. Any recommendation on how to get apart. I need to replace the 4 upper bolts with rubber washers. I have tried...
Go to Americansanders.com and under the orbital sander click on it and the manual is 38 pages long, the parts explosion is towards the back of the manual but it should show you how to disassemble this tool so you can get to the bolts that you need. Let me know if you need more help
Sep 30, 2009 | Clarke Floor Sander Floor Sander Orbital...
Clarke FM1700 buffer-sander, problems with using it
what is the condition of the felt pad on the driver?? The sander should not be that hard, usually you need to lift up or slightly bear down to get the machine to move left or right. Are there any exposed nails in the area you are sanding and check the grit for the sanding conditions
Aug 23, 2009 | Clarke Floor Sander Floor Sander Orbital...
I have a du-8r clarke floor sander, i need a schurter switch, swiss made, a146f160u4-azm11, 120v, 16 amp. do they still make this part.
I can't find anything on Clarke's website for this tool. But if you have the switch out I would take it to a local repair facility or electrical supply house and have them match it up. There is usually nothing that special about the switches. Let me know if you cant and I will try and dig deeper.
Jan 21, 2009 | Sander Industrial Original Clarke Floor...
Sander Industrial Original Clarke Floor Drum  Du-8r Logo
802 people viewed this question
Top Sander Tools & Hardware - Others Experts
gbob59
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Sander Tool and Hardware - Other Expert? Answer questions, earn points and help others
