Question about RAD Data Communications RAD RIC E3/ETH (RIC-E3/ETH) Bridge
Restoring the configurations to factory default
I had one working setup of Airmux 200, yesterday one unit(ODU and IDU ) stoped working(probable due to power flactuation) I decided to replace a complete set(I changed only IDU and ODU by removing from the fault link and replaced with the one from the working link from one of our site). The devices failed to establish the link(I do not know why because i have not re-aligned the dishes), I thougt because of configurations , I decided to reset the configurations but the Airmux200 ODU do not accept this operation so what should I do to make these devices in factory default so that I may reconfigure the devices? ot what is the solution in this case? Fred
  • Anonymous Mar 01, 2009
    techienick
    your link is broken!!!!
    in UserManual i don't find any solution :-(
Visit Link below : https://shop.invictusnetworks.com/pdfs/AirMux-200%20User%20Manual%205-06.pdf all da Best techienick
Posted on Mar 25, 2007
My AC model is Blue Star 1.5 ton 5 star inverter split AC. ODU is switching off when temperature reach its setpoint, but not the IDU. Does any one help me why it is so?
You likely are running a constant fan. Fan should be set for auto, this means it turns off when compressor turns off.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Apr 14, 2017 | Star Heating & Cooling
How do I restore my router to the factory setting? I have no Wi-Fi service.
Restoring the Default Configuration and Password
  • Use the restore factory settings button on the rear panel of the router. Use this method for cases when the administration password or IP address is not known.
  • This is how to restore the factory default configuration settings that reset the router's user name to admin, the password to password, and the IP address to 192.168.1.1.
  • To use the restore settings button:
    1. Locate the restore factory settings button on the rear panel of the router.
    2. Use a sharp object such as a pen or a paper clip to press and hold the restore factory settings button for about 5 seconds, until the Power light begins to blink.
    3. Release the restore factory settings button, and wait for the router to restart, and for the Power light to stop blinking and become solid green.
    4. The factory default settings will be restored so that you can access the router from your Web browser using the factory defaults.
      Then you can go through the setup procedures to setup your wireless
      Here is the link to the documentation so you can set it up again
    WNR2000 Manual Table of Contents
    hope it works for you
    Sep 10, 2014 | NetGear WNR2000 Wireless Router
    12 communication error between IDU - ODu
    Look for the lines that run through the wall out to the outdoor unit. Turn off the power and then check the electrical connections at the outdoor unit. Inspect for broken wires. If no broken wires, remove the wires one wire at a time and then re-land the wire and tighten. Check for proper operation after performing this operation at both the indoor and outdoor unit.
    Nov 04, 2013 | Hitachi Heating & Cooling
    Lg multi v
    I didn't see a ch but both 5 and 11 point to high pressure. 5 is a liquid temp sensor short, 11 is high pressure error. Sounds like a bad sensor. Best Wishes!
    Aug 17, 2017 | Heating & Cooling
    How do i perform a cold reset on a laserjet 2600n printer
    Via the Control Panel: The Resets menu makes it possible to reset factory settings, disable and enable Powersave, and update the printer after new supplies are installed. Configure device menu The Configure device menu makes it possible to change the printer's default print settings, adjust the print quality, change the system's configuration and I/O options, and reset the printer's default settings RESTORE FACTORY SETTINGS :Makes it possible to clear the page buffer, remove all perishable personality data, reset the printing environment, and return all default settings to factory defaults. Press Menu or (Select) to enter the MENUS.
    1. Press (Down Arrow) to highlight Configure device menu .
    2. Press (Select) to select Configure device menu
    3. Press (down arrow) to System setup menu
    4. Press (select) System setup menu
    5. Press (select) Resets menu
    6. Select RESTORE FACTORY SETTINGS.
    I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
    Dec 03, 2010 | HP LaserJet 4600dn Color Printer
    My acer aspire 4315 stuck at boot with white screen, when using external monitor it show acer boot screen and stuck there. I can press F2 for setup but nothing happen.
    http://tim.id.au/laptops/acer/aspire%204715z%204315.pdf
    Above is a link for your Service manual, inside is everything you need to know to troubleshoot and repair your machine, this is the manual that us engineers use to repair these units.
    This could be your HDD, failed. Work through, the troubleshooting procedures.
    Anyway try this below first. Run Acer eRecovery Management Copy the Acer factory default backup disk Image Create backup of the system Create a complete backup Creating an incremental backup Erase a backup point Using the option ‘‘Burn Disk’’ Burn a backup disc with the factory default settings Burn a backup disc with the parameters of user Copy the current system configuration to disc Burn a disc backup software Restore the system Restore system to factory default settings Restore system from backup user Recover the system from CD / DVD Re-install applications / drivers Other means of System Restore No Restore CD / eRecovery / password / ALT + F10 or F10
    May 14, 2010 | Acer Aspire 4315 Notebook
    RAD AIRMUX 200 NO Communication
    You didn't say what rev. level you have, but if they were manufactured after 2006, your problem is most likely a lost SNMP read/write community string. The default read/write community string is 'netman', and the read only community string is 'public'. When attempting to connect to the ODU with Airmux Manager, type in the username and password but before clicking OK, click on the Options button which will expand the login dialog window. There you can enter the default read/write community string 'netman' (assuming someone hasn't changed it). If that doesn't work, you can contact RAD tech support who can generate a new community string with the MAC address from your ODUs.
    Apr 15, 2009 | RAD Data Communications RAD RIC E3/ETH...
    Bios problem
    you need to go into bios and set the ide drives correctly.
    May 18, 2008 | Intel Motherboard
    Airmux 200
    Depending on the current rev. of software you have in your Airmux, you may have to upgrade to an interim rev. before upgrading to the latest. I have successfully upgraded some of the very oldest Airmux's dating back to 2005 with the latest software (1.750 and above) by first upgrading to version 1.300 reboot the units, then version 1.500 followed by another reboot, and then finally version 1.750 followed by another reboot. The reason for the reboots in betwen version uploads is that when you load a new version of software to an Airmux, the new version is copied into temporary flash ram. When you reboot, the Airmux sees a new (valid) version of software and will load it. Hope this solves your problem. Incidentally, you can get the software from RAD tech support.
    Jan 31, 2008 | RAD Data Communications RAD RIC E3/ETH...
    RAD Data Communications RAD RIC E3/ETH (RIC-E3/ETH) Bridge Logo
    1,078 people viewed this question
    Top RAD Data Communications Computers & Internet Experts
    Alun Cox
    k24674
    Are you a RAD Data Communications Computer and Internet Expert? Answer questions, earn points and help others
