Question about Hotpoint Aquarius WF000 Front Load Washer
Hotpoint my Hotpoint fw740 is displaying f-08 can you help please.??????????
    President:
  • 373 Answers
F08 is - Static heater relay with contact welded closed.
The door might had been opened with the dryer not cooled.This leads to a heat relay.
Posted on Dec 13, 2008
My washer (hotpoint ultra silent wf840) is displaying f-08 on it's digital display, can anyone help please.
The meaning of F08 is that the heater relay is stuck or cannot be activated for some reason, this has the effect of stopping the water heater from working.
In order to resolve this the only thing you can do is to test the heater, and see if it is o/k.,if it is , then you there is not much else you can do, except call an engineer.
Feb 23, 2011 | Hotpoint Ultima WF840 Front Load Washer /...
I have a code on the display f-08
hotpoint washing machine WT740 1400 code erroe F-08 flashing machine stops working after 20 minutes please help
Jan 19, 2011 | Hotpoint Aquarius WD640 Front Load...
Hotpoint washing machine - WF865 showing F-08 fault
F08: Heater control or NTC (Thermistor) temperature sensor problem.
Jan 23, 2010 | Hotpoint Ultima WF865 Front Load Washer
Hotpoint wt960 keeps stopping and displays F-08, any ideas, Thanks
  1. F08 is a sticking heater relay.
  2. Check connections on pressure switch
  3. Check heater connections.
  4. Check module connections.
  5. Check pump filter is clear.
Please rate my solution.
Thanks.
Nov 16, 2009 | Washing Machines
Screen display reads f-08
  1. Error code F08 indicates heater relay stuck
  2. Check pressure switch connections
  5. Check pump and or pump filter for blockage.
Please rate ,my solution.
Thanks.
Nov 15, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima Wt761 is displaying F-08 what can I do any ideas please
First, try turning off the mains power to the machine for 30 minutes and switching it back on to see if the error persists. This indicates a problem with the heater relay or heater. This usually means that the relay cannot be operated due to a heater fault and that the heater will need replacing. A service call to replace it will be the quickest option.
Oct 25, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wd645 flashing f-08
The manual says F08 - Heater relay cannot be activated.The dryer might be having difficulty with this.It is not something that can be fixed.Heater Relay equipment might be damaged.Might have to call a repairman to set this right.Good luck.Do post comments for more help.
Jan 10, 2009 | LG WD-14124RD Front Load Washer / Dryer
Test
Hi i have a hotpoint wd 860 washer dryer the display is showing f 08 heater relay cannot be activated.can you please tell me how i can fix this problem myself.Thank You
Jan 04, 2009 | Hotpoint Ultima WF860 Front Load Washer
F-08
F-08 is the code for ' Heater relay not activated ' ( The heater is coming on) The things to check are the Pressure switch or heater and module connections.
May 31, 2008 | Hotpoint WF645 Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
190 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
