Question about Whirlpool Accubake RF362LXTT Electric Kitchen Range
Whirlpool accubake oven will not heat after self clean cycle
We ran a self clean cycle on our accubake wall oven. A couple of days later we went to preheat the oven and the timer counted down and signal the ready chime yet the oven was not heated. Tried several times with the same results
Ron
  • Anonymous Mar 14, 2014
    where is the pilot light?
I had the exact same thing...thermostat..
Posted on Jul 11, 2009
I have a whirlpool oven. I ran the self cleaning cycle,let it cool down for a day and ride to open the door. It wouldn't open. I then cycled the circuit breaker and tied again. No good. There appears to be...
sad to say but way too many of us have gotten lazy , even I do at times but self cleanings ovens have always been a problem. the excessive heat required is costly and burns up many elements among other things
Oct 29, 2017 | Whirlpool RMC275PVQ Built-in Microwave...
My whirlpool double oven accubake GBD307PDS09 display went blank!!!! HELP!
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty. GBD RBD Whirlpool Oven Problems Causes and Solutions
May 03, 2017 | Whirlpool GBD307PD Electric Double Oven
Describe how to access the self cleaning feature on the accubake oven and how long does it take?
Press the "Auto Clean" or "Precise Clean" button depending on the control type of your range. Then press start. The oven should lock and start the self-cleaning cycle. The cycle is usually 3 hours from start to finish and cannot be stopped once it has started heating. The range gets extremely hot and causes the inside of the oven to act like a catalyst to burn the grease. It will create smoke and odor depending on how dirty the inside of the oven is. Make sure to leave the exhaust fan on above the range to remove some of the heat. And definently do not do the cleaning cycle on a hot summer day!
Feb 19, 2010 | Whirlpool Accubake SF362LXTS Kitchen Range
Whirlpool Accubake RBD306PDB - Fans won't stop + codes F2 E1
yes. E1 -F2- = the keytail (connector ribbon) that plugs into the control board is not making good contact. first unplug your range and then remove the two screws on the underside of the back-splash controls panel to access the back of the control board. now simply cut a slip of heavy paper such as a business card to the width of the ribbon and slide it into the slot along with the ribbon connector. that will help press the contacts on the other side together snuggly. screw the back-splash back in place, plug in your range, and the problem will vanish. if the error ever returns, try pulling out the connector, cleaning the contacts with a pencil eraser, reinserting it into the slot and repeat above with the paper. good luck.
Jan 21, 2010 | Ovens
I get a E0 -F2- error code on my whirlpool Accubake GR450LXH2 ran
That mean that the key pad is shorted,needs replaced
E0-F2 Shorted keypad Replace Electronic Range Control/Clock (ERC)
Or
E0-F2 Oven temp too high
1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor
Jan 13, 2009 | Whirlpool GR450 Electric Kitchen Range
Model # JKS06bof4bb wall oven has a fault f-7 dc Tried cycling power on/off didnt work still have fault
I have a whirlpool accubake oven model WFE364LVS. The screen is saying d79b. What does that mean? The oven door doesn't open either. My husband did the self clean and it worked fine for alittle while after and then I went to bake a cake and the door wouldn't open. Can anyone please help me?
Aug 20, 2008 | GE Kitchen Ranges
Whirlpool oven accubake system
I have a whirlpool accubake wall oven. Half-way through baking a pie ,unknown to me, the oven went to the self-clean mode , the door locked and the pie started to burn. I tried to turn the oven off but it would not cut off. I immediately ran to the house's main power and turned off the oven breaker. I waited for a short time to let the oven cool enough to open the door and get the burned pie out, then went back to turn my breaker back on and the oven (even though in the off mode) started heating again with the bottom unit turning red again. I had to then go back and pull the power. We tried this several times trying to push the off button but the oven will not go off until we throw the breaker. Help please!
Jul 01, 2008 | Whirlpool RBS245PDS Electric Single Oven
Cleaning cycle stuck whirlpool rbd245pdb1
whirlpool self-cleaning electric built-in oven #RC8400XAB serial # XD1301008. Self-cleaning lever locked. How can I release it???????
Jun 10, 2008 | Ovens
Whirlpool Accubake RF362LXTT Electric Kitchen Range Logo
3,607 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
