PUT ON BLET
BELT CAME OFF WANT TO PUT BACK ON KD=491F KENWOOD
  • 515 Answers
The belt normally wraps around the bottom of the metal platter. Put the platter back on the turntable, and you'll see holes on opposite sides of the patter. Just pinch the belt out a little, and wrap around the motor shaft - should be a brass shaft assembly.
- OPTiC
Turntable Repair Expert
Digital Analog Therapy
Posted on Dec 13, 2008
Hello, I have an old SX-1600 stereo receiver that has a short in it. Shipped off once already to be fixed. It worked ok for about a year. Now, it's doing the same thing. Don't know where to send it...
Most current receivers no longer include a PHONO input. Perhaps what could be done is to purchase a phono to line level pre-amplifier to go along in your purchase for a new receiver.
Will scout around for receivers and post back additional information.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 29, 2008 | Audio Players & Recorders
Kenwood KD-491F belt come off How do I put it back?
You have got to lift the table on which the vinyl is placed underneath you will find the belt laying loose on the bottom of the table is a pulley on you fit the belt then on the right hand side or rear is the pulley on the motor which the belt also has to be fitted then carefully lower the so as not to let the belt come off again this should provided the belt is not stretched or snapped then it will have to be reaplaced
Oct 11, 2010 | Kenwood KD-291RC Turntable
I need to put the belt back on th KD 48F turntable
its likely that the belt has stretched and therefore will keep happening as its no longer http://www.needledoctor.com/Online-Store/Turntable the right size? go to this site for a replacement?
Aug 21, 2009 | Kenwood Audio Players & Recorders
Trying to get the belt around the gears of my
I know this isn't the same model as yours, however it shows what I would describe to you on page 7. Hope this helps.
http://www.kenwoodusa.com/UserFiles/File/UnitedStates/Home/Manuals/kd-491f.pdf
Jul 30, 2009 | Kenwood Audio Players & Recorders
PUT A BLET ON TURNTABLE FOR KEENWOOD KD-491F
- OPTiC
Dec 13, 2008 | Audio Players & Recorders
SX-1600 + KD-491F
Appreciate the additional information.
To recap what you need is a receiver that can accommodate:
4 - Pioneer S-DF1-K (15-100W, 8 ohms)
1 - Pioneer PD-F407 25 Disc CD Player
1 - Pioneer CT-300 dual tape deck
1 - Kenwood KD-491F turntable
Possible choices are (keeping in mind that the power output should be less if not equal to 100 watts and a turntable/phono input):
i. Onkyo TX-8522 Stereo Receiver;
ii. Yamaha RX-397 100 Watt Natural Sound AM/FM Stereo Receiver;
iii. Sony STR DE695 AV receiver;
iv. Teac AG-790 200 Watt Stereo Receiver;
v. Denon AVR 888 - AV receiver - 7.1 channel.
Some of the above also includes feature(s) to hook up to your video system. Some may even require a fifth speaker (subwoofer).
Incidentally, you can also choose another brand/model even without a turntable/phono input. As initially posted, a turntable/phone to line level pre-amplifier is only required. Here are some examples:
a. XP200 Turntable Preamp - Nano Series;
b. Pyle® Pro PP999 Phono Preamplifier;
c. Pro-Ject Phono Box Turntable Preamplifier;
d. Radial J33 RIAA Turntable Preamp Direct Box
Good luck with your project.
SX-1600 + KD-491F
Hi again,
It would seem that you posted the problem here also. With your kind permission, I will repost my excerpts of my responses that others may benefit on similar concerns.
A. Most current receivers no longer include a PHONO input. Perhaps what could be done is to purchase a phono to line level pre-amplifier to go along in your purchase for a new receiver.
I was made to understand that the Pioneer SX-1600 is prone to speaker output problems which could either be:
1. the speaker relay (protection); and/or
2. the amp, STK4191II Stereo Module.
Either should be relatively easy to work on and perhaps you can try the services of a locally available qualified electronic technician since the repairs would not be too specialized. The service manual may be of help (or at least a schematic , they may be downloaded from here and here).
B. To recap what you need is a receiver that can accommodate:
C. Possible choices are (keeping in mind that the power output should be less if not equal to 100 watts and a turntable/phono input):
Fixing a Kenwood KD 491F turntable
The reason why the audio is low, is that todays receivers do not have a phono input, and these types of inputs are differant then the ones of today. You will need whats called a phono preamp, and one should still be available from Radio shack. Or you can go here to find out more about them: http://www.phonopreamps.com/ To reseat the belt, take off the rubber mat on the turntabe disc. Install the belt around the inside ridge, there should be a couple of holes on the platter disc. Install the patter back onto the center spindle. Turn the platter around till you see the motor pully through one of the holes in the platter. Take the belt that is around the turntable platter, and pull it over to the motor pulley. Good Luck
Jun 15, 2007 | Kenwood KD-291RC Turntable
281 people viewed this question
 Grubhead
Grubhead
