Back to:
Tags:
FEC RKMV5 Custom Rackmount Kit for JVC RKMV5
My DVD disc not recognized after loading, how can i... (by 42 users)
By Cornish - usenet poster
My DVD disc not recognized after loading, how can i fix it?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
41 Other Users Have The Same Problem
Comment by issarah2, posted on Oct 04, 2008
isee a bad disc display
same problem
Comment by steve-lewis0, posted on Aug 28, 2008
I have a brand new JVC DR-MV-78B DVD Video Recorder (Region 1). It will play everything except Region 1 store-purchased DVDs. IT will play VHS, dubbed DVDs, audio discs, etc. When I insert a purchased DVD, I get "NO DISC." I have cleaned the lens, unplugged/plugged the player, and everything else suggested. The player is two days old. It worked perfectly the first day, playing anything I tried. The next morning and ever since, I had this problem. The player is connected correctly to a 50" Hitachi HD Plasma TV.
Comment by Guest, posted on Aug 27, 2008
dvd will not load
Comment by Guest, posted on Aug 22, 2008
My dvd player was in the middle of a movie, when it became inhibited, after that it just registers loading, but never actually plays the movie anymore
pls let me know if a dvd clearner disk is all i need
thanks
Best Solution
posted on Aug 08, 2005
Helpful (85)
Phoebe
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
1. Check that disc is loaded the correct way.
2. Check that disc is encoded for your geographical region. A disc from Europe (Region 2) will not play in a North American (Region 1) player.
3. Turn off player with disc inserted, unplug temporarily from wall outlet, plug back in and turn back on.
4. If your player has a transportation lock (usually a plastic screw on the bottom of the unit), make sure that it is not engaged.
5. If you have an older player, check with the manufacturer to see whether an update to the firmware is available. Many newer DVD titles with lots of special features are famous for causing problems on older players.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on My DVD disc not recognized after loading, how can i fix it?:
I don't want to Accept this solution
Solution #2
posted on Sep 08, 2007
Helpful (85)
hattonhall
Rank:Master Master
Rating: 78%, 12 votes
Which DVD disk are we talking about?
Is it a prerecorded purchased DVD movie or one you have done or your PC?
(See my response to similar postings)
Does the disk play on another machine?
Is the disk surface Scratched or Dirty?
Have you run a laser lens cleaner disk through your player?(Available from most electronics and el-cheapo shops)
Assuming all that does not apply it could be caused by many things. See responses to other postings! Hope this helps - hattonhall
Thank You!
Solution #3
posted on Mar 31, 2007
Thanks for Trying (70)
biffo
Rating: 75%, 68 votes
biffo indicated that his solution for
DVD-S35 DVD Player Problem
is valid for all DVD Players
I had this problem on my Sony DVP-NS41P after about 1 year. After loading and after a long wait it would report something like " cannot read disc". After taking top off of player I noticed disc was not spinning and after some debugging I believe the spindle motor has failed. So I think this is one possible failure that might explain your problem. Unfortunately my player was a few months over 1 year old so the warranty had expired (my wife hadn't keep the receipt anyway, but in this case it wouldn't have helped). Sony was running a return and replacement with a refurbished unit program on this model number (for ~$75) so I am considering this but mostly I plan on not buying another sony.
Thank You!
Solution #4
posted on Aug 20, 2008
Not Rated (0)
ozwanker
Rating: 0%, 0 votes
ozwan... indicated that his solution for
DVD-2520 DVD Player Problem
is valid for all FEC DVD Players
I have model DP 3182. It too started having the problem of "No Disc" when the same disk plays just fine in my other DVD Recorder. When I finally opened it I noticed that the ribbon cable which goes from the board to the read head, was cracked near the connector at the read head.
In my opinion this is a design flaw as this cable should have had a lot of play to prevent just this problem. I am now in the market for this cable. I wonder if any one knows where I can purchase this part (22 conductors - 7.5" long and 0.5 " wide part number seems to be - P-TWO AWM 20696 E221612 80c 30v vw-1 - I am not sure which out of this is the part number and which are just specs).
Unfortunately other than replacing this cable, there is no other solution. All the symptoms like motor not spinning up etc are related to this as this cable sends the DVD/MP3/DiVX data back to the board.
Thank You!
Solution #5
posted on May 11, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
Take the cover off and clean the lens with a lens cloth.
Thank You!
Solution #6
posted on Feb 09, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
Get a different unit.
Thank You!
Solution #7
posted on Jan 14, 2008
Not Rated (0)
MsBelve
Rating: 0%, 0 votes
I got the Amphion Mediaworks m280 Portable CD as a gift. After 6 months, it stops reading any CD/DVD I put in the player. It seems I have the same issues as the 17 users in this site. What can you do to help?
Thank You!
Solution #8
posted on Aug 27, 2007
Not Rated (0)
rjcromwell
Rating: 100%, 1 votes
take the outside cover off .and then remove the 4 screws from the inside drive cover.then slide the drive back some to clear front cover.then lift the drive out. then find the little white gear ont he bottom side and turn the gear so the disk tray slides out as far as it can go .check both ribbon cables on both ends. then with the disk tray still out plug in the unit to the ac outlet and hit the power button on the front. the drive should return closed after it boots you should the drive spin .then turn it off with power button on the front. then unplug unit from wall.then put drive back in unit.then place the inside cover over the drive and check to make sure not to pinch any wiers the hard drive power wiers is aginst the case.then tighten down 4 screws.then check if every thing works wright.if every thing works put cover back on . I did this to fix the drive the screen just said open and locked up before the fix
Thank You!
Solution #9
posted on Aug 21, 2007
Not Rated (0)
Guest
Rating: 0%, 0 votes
laser is dirty,or ribbon cable as cracked
Thank You!
Solution #10
posted on Aug 06, 2007
Not Rated (0)
Guest
Rating: 0%, 0 votes
hi i had similar problem,removed lower covers and inspected drive motor-ok,put back together and working fine
Thank You!
Solution #11
posted on Apr 24, 2007
Not Rated (0)
Guest
Rating: 0%, 0 votes
MY DVD PLYER IS NOT DISPLAY DVD DISK ON MY TV.IN DVD PLYER POWER IS OK,DIK MOVING IS OK.
Thank You!
Can you Help with these DVD Players problems?
FEC RKMV5 Custom Rackmount Kit for JVC...
Dear Sir, Often when DVD players get a bit old they stop...
I haven't used the mulitsession. I used no mulit session....
my dvd/cd-rw drive recognize empty CDs but did not...
The DVD-RW drive of my PC is failing to read any disc....
i am having a panasonic vcr .. i am putting audio and...
41 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Aug 04, 2008
dvd palyer doesnt recognize disc says no disc
Comment by peters1050, posted on Jul 25, 2008
Having the same problem and this was true the first time I ever used the DVD player - brand new out of box
Comment by Guest, posted on Jul 14, 2008
tries to read disc then says no disc
Comment by Guest, posted on Jun 28, 2008
DVD dose not recognise after loading.it shows no disc
Comment by CARLOC, posted on Jun 16, 2008
INCORRECT DISC FORMAT THAT'S ALL IT SAY'S
Comment by Guest, posted on Jun 12, 2008
my portable dvd player idm1731 when you put dvd in , it saids loading then no disc... help///
Comment by Guest, posted on Jun 02, 2008
Repeatedly displays NO DISC for CDs or DVDs. Suspicious that it may be an alignment problem, which was told me about 3 years ago ... after I had it about 3 years, about $135 as I recall.
Comment by Guest, posted on May 11, 2008
MY DVD RM Drive do not in a dvd player
Comment by Guest, posted on Apr 29, 2008
after inserting a disc, it says loading and then it says wrong disc. i have had this problem before and then after a couple of days/ weeks, it will work again. can anyone explain why this is happening.
Comment by Guest, posted on Apr 28, 2008
WHEN I LOAD A DVD IT EITHER SAYS UNKNOWN DISC OR NO DISC
Comment by Guest, posted on Apr 16, 2008
Comment by Guest, posted on Apr 14, 2008
whenever i put a dvd in it say "no valid disc". what do i need to do?
Comment by savcomgh, posted on Apr 03, 2008
nO RECOGNIZE ANY DISC AT ALL,(exept to play) I just followed the steps but the display said error always, the discs i try is the DVD-R. I shuld use X8 speed Disc?. There is a tiny label in back of the set 8x.
Thanks for you cooperation. I am spanish sorry about the writing.
Comment by flyingscot, posted on Mar 12, 2008
dvd media is Taiyo Yuden and the player says that the disc is iether scratched or dirty but the dvd will play in any other player have had the dvd drawer and board replaced but it still does the same any one any ideas how to solve this
Comment by Guest, posted on Mar 12, 2008
what can i do to fix this? i'm trying to load norton cd/ says no disc installed
Comment by very big o, posted on Feb 14, 2008
plays some burned discs & not others
Comment by Guest, posted on Feb 11, 2008
my player play cds but not dvds
Comment by ejay1070, posted on Feb 10, 2008
Having the same problem - DVD player does not recognize disc - They symbol for loading and the word, "loading' stays on the screen. How can I fix this?
Comment by dleblanc2, posted on Feb 09, 2008
put disc in and loafding sign comes up and thats it. will not load
Comment by sunja, posted on Jan 18, 2008
my DVD can not play any discs and my remote is dead.
Can not set progressive scan
Comment by dmaeb, posted on Jan 02, 2008
New Rush Hour 3 disc would not play, but movie Next played. Took the Rush Hour back got a different plus "Shoot 'Em Up" and neither one would play. We use this DVD player quite often and haven't had this problem before. Any solutions?
Comment by R0b1n, posted on Jan 02, 2008
Did not load in the dvd/vcr combo player. Tried my computer dvd reader said that I did not have a decoder installed to read the dvd. Used a newer laptop and windows media player to watch dvd. So the dvd is good no scratches brand new but the Sylvania dvd/vcr player can not read the special feature interactive software on the disc. Is there a updated decoding software for this player. Has happened with 2 new released movies. Others work fine. Must me the software on the dvd unrecognized.
Comment by techdad, posted on Jan 01, 2008
After 6 months the player will not play ANY DVD's bought or burned. The message is Incorrect Disc. Took unit apart and reseated power and data cables and still no dice. Cannot locate a replacement DVD drive either.
Comment by Pramod Gupta, posted on Dec 30, 2007
I have a Philips model no. DVDR3455H/97 .For sometime I am having this problem. When I load a properDVD+RW disc and press DVD on the remote, the response is "not supported disc type". Other pre-recorded discs get the same response with the result that I can neither play discs nor record on them. HDD is ok.
Comment by IowaLynette, posted on Dec 30, 2007
Samsung DVD-VR335 get the disk error screen, and then all of them eject. I've tried store bought movies, DVD-RW, DVD+-RW and so on and so forth. Was told by Samsung customer service to clean the system. Did that, guess what, still doesn't work. Of course, after warranty, and purchased from Dell, so no one was willing to help. Pretty costly problem.
Anyone know if there is some kind of update, or support?
Thanks in advance.
Comment by phenomfan_05, posted on Dec 27, 2007
My player will not recognize certain discs. I've experienced this problem with my WWE Wrestlemania 23 DVD set and just recently, my WWE Raw 15th Anniversary DVD set. I know the discs aren't dirty because I just bought the 15th Anniversary Set today. The first disc in the set played perfectly. But when I put in the second disc, a little red 'circle with a slash through it' symbol appeared in the top right corner of my tv. I've also had the same problem with my Wrestlemania 23 DVD set. The second disc will play perfectly, but the first and third discs won't play at all.
Comment by ronalda, posted on Dec 22, 2007
DVB216 tray opens, accepts a DVD and closes fine. Motor is then heard spinning and a spinning disc is shown on the display. After several seconds, the display shows "Disc Error".  Help, where do I start??
Comment by Dog leg, posted on Dec 18, 2007
After putting in a disk the display reads loading and the disk spins, the laser comes on and focuses but the laser doesn't track. after about a minute the display reads "no disk".
Comment by Leis, posted on Dec 15, 2007
I have just put a disc in and my player says cannot operate in this region.
How can I fix this?
Comment by lucy1234, posted on Dec 05, 2007
we just purchased the Sony DVP-NC85H and even when we put a cd in it it says no disk
Comment by BarrySR, posted on Dec 05, 2007
My DVD's have been the DV-F07 and played successfully for a long time ... so I know nothing is wrong with the DVD's. When I tell the system to "PLAY" a DVD it begins ... rotates ... the DVD number appears in the display and sometimes "000" appears ... and then the system starts all over and may try to load the same DVD again (with same results) or go to the next DVD and try to load that DVD (with same results).
It almost seems the unit has "lost its tranport mind".
Any thoughts or solutions greatly appreciated.
Oh, I've tried turning it OFF for a long time ... even unpluged it for a long time ... neither helped.
Thanks, barry cooper, sr.
Comment by Chrisluvstat, posted on Nov 28, 2007
The Problem is When burning movies you need to know what format the dvd player plays movies in. So does anyone know what format the Hitachi DV-P533U dvd player plays in is it SVCD, VCD or even divx
Comment by Guest, posted on Nov 17, 2007
my player will play cd's, but will not play dvd's, responds with no disc?
Comment by Oalph, posted on Nov 15, 2007
During loading a window appears with the message the disk may not play back and stops the load. Was using DVD-R 4x.
Used a faster disk but it would not work. Funai parts sent a upgrade?? disk. Now even a -RW 4x won't load. I don't have any -R 4x to test.
Comment by gimmiesome, posted on Nov 13, 2007
i burned a disc from my computer on a dvd-r my player could not read it?what can i do to solve this problem?
Comment by Guest, posted on Nov 05, 2007
i want to searh dvd cleaner to solve this problem
Loading problems.
Repair Service
Find DVD Player Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
