Question about Fuji FinePix S3 Pro Digital Camera
Display panel shows "Err"
I have a "finePix S3". Since I didn't put the Memory card straight. Display Panel shows 'Err". Camera doesn't work anymore. Can you tell me what I have to do for fix? Where can I send my camera for fix? Which Fuji Camera place is close to my area? ( I live the Hartford Area CT 06033)
It sounds like maybe the pins in the back of the memory car port may have gotten damaged when you did not get it in straight, I don't know of anyplace in your area to have the camera serviced, but I think it will be a costly repair.
Posted on Jul 18, 2009
Why is the finepix games s2900 camera saying I should turn off the camera and put it back on again
I recently got this camera and it did the same thing to me. I found this site and did what quido777 said to do, smacked it on my leg, didn't work. But then I decided to check the memory card and took it out and put it back in, and now its working. I'm guessing it didn't detect the memory card for whatever reason. Before all of this I called tech support and they didn't know **** and wanted me to send it in. I'm glad I decided to fix it myself before going through all of that. But one thing is fore sure, after this camera, I'm never purchasing from Fujifilm again.
May 19, 2012 | Fuji FinePix Cameras
Keep getting card error was working fine took card out to download pics on to my computer and when i put card back in i keep getting card error
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. Another common cause is card corruption from the card never being formatted in the camera. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Sep 29, 2011 | Fuji FinePix S2000hd Digital Camera
I have not used my Fuji Finepix 6800Zoom for many months so I charged it up and now when I turn it on 'ERR CARD' is displayed in the round screen. If I press Menu and then Back !card not...
May be you inserted a memory card formatted with your PC. Format the memory card using the Format function in the camera menu. Format function can be found in the setup menu of the camera.
If this does not work, try replacing the memory card.
Sep 02, 2011 | Fuji FinePix 6800 Zoom Digital Camera
Hi, using my new ac mains adapter, the camera does not work, shows err in the top display screen, if you try to take an exposure the camera clicks, any help would be appriciated
Is it an original Fuji part, your new AC adapter?
It sound like it's not powerfull enough. The ERR error is normally related to low batteries.
Mar 21, 2010 | Fuji FinePix S3 Pro Digital Camera
All of a sudden my fuji s3 pro isn't recognising the memory card. why is this? the card works fine in another camera.
That's the problem. It works fine in another camera so the card is optimized for that camera. To optimize it for your Fuji S3 pro, you need to format it in the camera. This will erase it so download any pics first.
Feb 20, 2010 | Fuji FinePix S3 Pro Digital Camera
Even with a new 4GB card my counter shows that I
Does your camera have an internal memory? If so, format it with your memory card out of the camera. Then, format the new card in the camera.
Dec 08, 2009 | Fuji FinePix S3 Pro Digital Camera
Err message appears on the display of my D80.
This may be due to the aperture ring in your lens. Try the following:
1. Turn off your camera
2. Move the aperture ring clockwise then lock
3. Turn on your camera and try again.
If this does not work, do the same thing again but turn the aperture ring counter-clockwise.
Nov 08, 2009 | Nikon D80 Digital Camera with 18-135mm...
Err message
This problem is caused by the plastic memory card door.
There is a door that hides the memory card on the back of the camera.
The door has a small plastic part on the left side that when the door is closed fits inside the camera.
When the door is open this part is exposed. It is right next to the "^" in "^ PUSH TO EJECT"
If you place one drop of superglue on the top of this little plastic part of the door(when open) and let it dry overnight(LEAVING THE DOOR OPEN OVERNIGHT.)
This will slightly build the plastic up about .05-1mm.
The problem is caused by the plastic part being about 1mm too small, liking resulting from normal wear.
I have tested this, and it seems to have resolved my issue with the S1 Pro I bought on e-bay
John C. Vincent
yellowcaseartist.com
May 01, 2008 | Fuji FinePix S1 Pro Digital Camera
S3 pro and studio flash
I have Fuji S3 pro and One body locked up during a reception and ERR displayed. 1st i turn off and on . it is work ok. 2nd time it happen again and still show ERR on dispayed. no way to reset. my camera out of warranty. estimate cost for repair 400$ per manifacture.
Dec 26, 2007 | Fuji FinePix S3 Pro Digital Camera
Fuji FinePix S3 Pro Digital Camera Logo
528 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
