Question about Texas Instruments TI-89 Calculator
I was ablto to solve for zeros in my ti-89, but know it will not
It gives me blank answers. Also when I type x as a variable it will not do it. Help!!!!
    Problem Solver:
  • 5 Answers
Type: F2,1,12=2x+4,x)
You should see: solve(12=2x+4,x) x=4
you need to make sure that there is an '=' and then you need to type ',x' at the end.
Posted on Mar 14, 2009
Solve() gives me wrong answer. -20^2=12^2+2X(-5-3). The answer is -16, But my TI-89 is giving me 34 during the solve funtion. my TI-83 is also giving me -20^2=-400 not 400.
Enter the first term as (-20^2), not as -20^2. Without the parentheses the calculator interprets it as
-(20^2), which is not what you want.
Also, make sure you use the (-) key just to the right of the decimal point and not the - key.
Aug 31, 2011 | Texas Instruments TI-89 Calculator
I want to know how to solve the Cubic equation on TI-89 Calculator
There are a lot of ways to do it. One is to write a program using the cubic formula. If you just want the roots, use the solve() or zeros() functions.
For example, to find the zeros of x^2-6x^2+11x-6, enter
solve(x^3-6*x^2+11*x-6=0,x)
or
zeros(x^3-6*x^2+11*x-6,x)
Note that solve() has "=0" in it while zeros() does not.
solve() will give you an answer of
x=1 or x=2 or x=3
while zeros will give you an answer of
{1 2 3}
which plainly are the same thing, just expressed differently.
May 09, 2011 | Texas Instruments TI-89 Calculator
TI 89 when solving equations or integrating a message appears:
With the ALPHA keyboard, Type in the NewProb command and press ]ENTER] It resets the one-letter variables to their default status.
Alternatively, you can use the CATALOG of commands to launch the NewProb command.
Another way is
In HOME directory, press the [2nd][F1] to activate the F6 key. In the menu list, press 1:Clear a-z and ]ENTER].
If you have to use the variable x multiplied by a function (sin, cos, tan, log, etc) do not used implied multiplication: enter the [*] explicitly.
Apr 14, 2010 | Texas Instruments TI-89 Calculator
Does a TI 89 have an advantage over a TI 84 in a 10th grade algebra class? My sons teacher won't let him use an 89. He says it does too much of the work for him. Is this right?
the 89 is in my opinion not need/ approriate for a 10th grade algebra class, or worth the extra money.
for example the 84 wont output variables it must output a number
so your son may be doing factoring, if he inserts (x^2+2x+1) the 89 will allow him to enter it and factor it as (x+1)(x+1) or (x+1)^2 the 84 will not.
the 84 will do pleanty as far as graphing, finding zeros,plotting, calculations, and should get him any answer that he seeks so long that he knows how to use the 84. It just wont give him the intermediate steps the the 89 is able to give.
hope this helps
Apr 05, 2010 | Texas Instruments TI-84 Plus Calculator
I can't differentiate a function and I'm quite
Clearly the x variable stores value zero. Press [F6] ( 1:clear a-z) [ENTER] and restart your derivative.
Hope it helps.
Sep 29, 2009 | Texas Instruments TI-89 Calculator
Steps in solving matrix on my ti 89 calculator.
I assume you are speaking of solving a system of equations with a number of unknowns. If not, please correct me. Here's an example in practice:
If you have a system of 3 equations with 3 unknowns, you would set up your matrix so that the coefficients of each variable for a particular equation are on one row. So, given equations x + y + z = 0, 2x + 3y - 4z = 1, x + -z = -1 you would type the following into your calculator: [[1,1,1,0][2,3,-4,1][1,0,-1,-1]] and press enter to make sure you typed it correctly. notice that in the third row there is a zero, since we have zero time y for the third equation. Then row-reduce the matrix (2nd > 5 > 4 > 4 or in the CATALOG as rref). You should get out the matrix [[1,0,0,-1][0,1,0,1][0,0,1,0]]. This says that x=-1 y = 1 z=0 since my first column contained the coefficients for the x variable, the second for the y variable, and the third for the z variable. The last column contains the solution, the part on the other side of the equals sign.
Hope this helps! For more reading (from someone else; I just made this one up), check out the Wikipedia articles on Gaussian elimination and Systems of linear equations
May 03, 2009 | Texas Instruments TI-84 Plus Calculator
Can you Factor on a TI-84? IF not, does the TI-89?
Well, to answer part of your question, yes... the TI-89 does factor like this. it is inputted like this:
factor(6*x^2+11*x+4,x)
Check the catalog in the TI-84 (which is 2nd-zero) and look under F for factor()
Jan 12, 2009 | Texas Instruments TI-89 Calculator
Plz help
Try not to set your first variable as zero
thats not a lot but thats what happened to me in my class
Jul 17, 2008 | Texas Instruments TI-89 Calculator
Solving multiple non-linear equations
Type it like this: solve( equation1 and equation2 and moreEquations, {list of variables to solve for})
Put all of your equations right after the opening parenthesis separated by the word and, then a comma, then within curly braces each variable you want to solve for each separated by a comma.
Apr 26, 2008 | Texas Instruments TI-89 Calculator
Texas Instruments TI-89 Calculator Logo
113 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
