Question about Bosch 18 in. SRS55L02 Logixx Slim-Line Free-standing Dishwasher
Dishwasher only starts if I tip it, then it sticks during cycle and hums
When I switch on the dishwasher it won't start until I tip it (at which point some water comes out at the bottom), it then gurgles and suddenly starts pumping water. The digital display however tells me it will take 199min to do the wash and then stays on this or sometimes it moves through the cycle but then sticks and just makes a humming sounds. I then have to switch it off and open the door. Most times it's cleaned but still wet but with no water in the main compartment. It started on the one cycle and has gradually happened on all the cycles now. My dishwasher is just over 3yrs old...should I just buy a new one? I'm thinking this may be expensive to fix!
  • Rayleen Bidoli Mar 13, 2007
    Not sure what time fill? when I reconnected and switched on again I got water but now all over the floor! Still showing 199min to do a cycle that should take 30min!
    Novelist:
  • 116 Answers
The left side (behind the metal side panel)of your machine has a blue and yellow mechanism which regulates the level of water for your machine(if there is no big yellow disk at the top of the mechanism then your machine is time fill). It also has a built in safety that if water should enter the white pan on the bottom, the drain pump will activate and stay on. It sounds like the machine problem has to to with water and flow level. You can observe the filling and running of your machine with the side panel off. (the connections at the switches on the float assembly are live be careful)
Posted on Mar 11, 2007
  • Gavin Wolchina Mar 14, 2007
    The time fill is controlled by the machine board but it sounds like your machine is not this configuration. The inlet water should flow throught the float assembly and into the bottom of the stainless tank through a small clear tube. If water flows out of the top of the float assembly then you need an inlet valve. if water is entering the white pan then it is possible that it is shorting a sensor causing the long readout and cycle time. once the leak is sorted out try running a rinse and hold cycle which should take only about 19 minutes. It sounds like the problem may actually be in the main control but be sure to sort tout the water leak first.
My Kenmore Elite dishwasher just hums when we start it.Its not starting and no water is filling up
Ok so your dishwasher won't do anything... it justs sits there and "Hums" you can't make it respond to any controls, and the ONLY way to Stop it. is to unplug the unit, replugging back in it simply "Hums" again and will do nothing.
Now this happens because, the STOP Button, is pressed and the "Door Opened", during the Wash Cycle. This should NOT be done. You should NEVER TURN IT OFF MID-CYCLE. you should instead, Simply, pull on the handle, to Open the door, the system will take care of everything, after, you close it,and pick up where it left off. The turning OFF, makes the machine "Think" that a New Cycle, is going to be done, before the old one is finished, and resets itself to do it all again. But it still has water, that's not meant to be there so it must dump it out.
Now, the FIX. Take the Dishwasher, out, and tip over on it's side, tip to about a 45' angle. Water will come out from underneath, this is from a small "Overflow" reservoir. this reservoir has an "Anti-Flood" switch. The removing of this water will "Reset" this Switch, and allow the dishwasher to work again.
So what happens, is this, when the STOP button is pressed Mid-Cycle, the machine must "Dump" whatever water is still in the machine, into the "Overflow Reservoir". This water then causes the Anti-flood switch to jam, and this stops the machine, until it is reset,by the above method.
Aug 09, 2010 | Kenmore Dishwashers
Tip
So your Dishwasher sits and "Humming" cannot turn off, no response.
on Mar 27, 2010 | Dishwashers
On my Kenmore Ultra Wash Dishwasher model 665 the Normal Wash light is blinking even though the previous cycle finished successfully. Also I can't start the dishwasher -- it doesn't respond to any of the...
http://appliancejunk.com/forums/index.php?topic=2933.0
Hi. please find above your service and repair manual, below is a self help how to repair your dishwasher website, between the manual and the self help site, you should be able to isolate and repair your issue. You may have a blocked pump, or a faulty sensor, but there is no way of knowing until one performs the troubleshooting steps to isolate the problem.
http://www.acmehowto.com/howto/appliance/dishwasher/dishwasher.php
Sometimes this fix works below, it's always worth a try?
Now this happens because, the STOP Button, is pressed and the "Door Opened", during the Wash Cycle. This should NOT be done. You shouldNEVER TURN IT OFF MID-CYCLE. you should instead, Simply, pull on the handle, to Open the door, the system will take care of everything, after, you close it,and pick up where it left off. The turning OFF, makes the machine "Think" that a New Cycle, is going to be done, before the old one is finished, and resets itself to do it all again. But it still has water, that's not meant to be there so it must dump it out.
Jul 07, 2010 | Dishwashers
Dishwasher starts to work but after 30 seconds stops and two lights start flashing on pannel
So what happens, is this, when the STOP button is pressed Mid-Cycle, the machine must "Dump" whatever water is still in the machine, into the "Overflow Reservoir". This water then causes the Anti-flood switch to jam, and this stops the machine, until it is reset,by the above method.Service manual below, if the above doesn't help. http://appliancejunk.com/ge/dishwasher/31-9137.pdf
Jun 24, 2010 | Hotpoint 24 in. FDW60 Free-standing...
It has the green light lflashing where it start but nothing happens
Jun 01, 2010 | Dishwashers
Opened lid during wash cycle. Machine stopped but later restarted. The same thing happened two weeks later, but the touchpad has no function. It is getting electrical power to the dishwasher. Thoughts?
May 06, 2010 | Dishwashers
Hi, the 3 sec lock is on and won't turn off, we can't get the dishwasher to start....i tried holding cancel along with the lock but that doesn't seem to work...any thoughts
Ok, this below is worth a shot. Ok so your dishwasher won't do anything... it justs sits there and "Hums" you can't make it respond to any controls, and the ONLY way to Stop it. is to unplug the unit, replugging back in it simply "Hums" again and will do nothing.
So what happens, is this, when the STOP button is pressed Mid-Cycle, the machine must "Dump" whatever water is still in the machine, into the "Overflow Reservoir". This water then causes the Anti-flood switch to jam, and this stops the machine, until it is reset,by the above method. http://frigidaireservicetips.com/pdfs/486_5.pdf
Service and repair manual above. This is what the Engineers use to troubleshoot and repair.
Apr 19, 2010 | Frigidaire GLD2445RF Built-in Dishwasher
My dishwasher fills, but won't start running. it just sits full of water and just hums.
Apr 14, 2010 | GE 24 in. GSD1000G Built-in Dishwasher
Bosch dishwasher timer sticking
I have been told to replace the timer which I am looking to do the same to my machine!
Mar 24, 2009 | Bosch Dishwashers
Amana Dishwasher
sounds like something is jamming your wash inpeller start at the washer arm and go down till you get to the wash impeller and see whats sticking it like broken glass small peice of bone toothpick etc
Jan 19, 2008 | Dishwashers
Bosch 18 in. SRS55L02 Logixx Slim-Line Free-standing Dishwasher Logo
217 people viewed this question
Top Bosch Dishwashers Experts
shaun taylor
Carmen Mikulic
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
