Question about Akai LCT2701AD Television
RCA Colortrak 2000 remote control will do everything except change channels.  I have Insight coax cable, just having disconnected from Direct TV satellite connection--only because new apartment does not allow satellite connections.   Now that I have to revert to the RCA remote, it's not changing channels.  Please advise.
I called RCA's 800 number on the back of the owner manual--got a response that said to replace the unit since only the up-down channel changer buttons were not working. Using another remote (universal) now--cost only $5.
Posted on Dec 15, 2008
How do I hook up my ps3 to my rca colortrak?
would be best to get a old vcr, then with a cable you hook it to the vcr and play it thru the vac
Mar 03, 2015 | RCA Colortrak 2000 Tv Large Tube Screen Tv...
RCS colortrak f20352sf: Can't view video source (Wii). I've wiggled the cables, cables are hooked up properly, Channel 91 doesn't work. In the setup menu, next to channel 91, it says clear.
I just bought the same TV second-hand and had the same problem. Solution: Use remote to change channel to 00. You can't display channel 00 using front panel - a remote is required. I have a very basic RCA universal remote, & it does the trick.
Dec 07, 2010 | RCA F20352SF TV
I can't get channel 3 to show satellite channels. They only show up on Video 3. I need channel 3 to work for surround sound. I checked wiring diagram and it looks like everything is hooked up the way it...
Hi there Guest, what you will want to check is what type of cable is hooked up to the TV. To broadcast on channel 3 it needs to be connected from the receiver by a Coax cable instead of RCA/HDMI/Component cables.
Tommy Faust
DISH Network
May 15, 2010 | DISH Network IR Remote Control
How do you connect to a direct tv box
1st, what kind of Tv Box ? with SCART Connector? or RCA Connector?
2nd, the recoder has a Scart connector or Females Rca connectors.
check for Video IN and L/R input Rca Connector
then use a Scart/RCA cable to connect DVD to TV Box.
Nov 07, 2009 | Philips Magnavox MWR10D6 DVD Recorder
TV channel sound from a different channel
I just unplugged the tv from the power source and disconnected the cable connection and then reconnected them back after sometime. The TV started auto programming after turning on and that resolved the problem.
Oct 18, 2009 | RCA Televison & Video
Need 1992 Remote Control For RCA ColorTrak TV Set
Tries 1-800-Factory remotes originals Website.
U get same as the original remote.
Aug 17, 2009 | RCA F27450 27" TV
Direct tv on universal remote
For this type of problem you will need to call the RCA customer support at this telephone number 1-800-645-4994. Give them the model number of your remote control and ask them for assistance with your problem. Thank you for using FixYa and have a nice day!
Apr 04, 2009 | RCA 3-Device Universal Remote with...
How do I hook up a daewood vcr to a TV through a Direct TV
If you are trying to connect a VCR to your television and still have Directv, this is the way to do it. Disconnect your Directv receiver from your television, Then connect the VCR to the television either through coax or RCA cables. If using the coax cable connect the out to tv on the VCR to the television. If using RCA cables connect the RCA OUT to the television AV1 connection. Once that is done, connect tha Directv receiver to the VCR using either coax or RCA cables. the Directv receiver only has RCA outputs so, if using RCA cables connect to VCR in. Remember that in order to see the Directv the VCR needs to remain on and it must be on the channel line in. If using coax cable connect to the VCR where it says in from antenna. Remember that if using this method your VRC does not have th remain on to view Direct. If you're trying to record Directv, then your VCR need to be on the same channel as the Directv output channel either channel 3 or 4. If trying to record Directv using RCA connections the VCR needs to be on the AV settings. If you have any futher questions please feel free to call me at (361)510-0339
Jonas Lopez
Jag Satellites/ Directv
Installer and Technician specilist
jlopez.jagsat@sbcglobal.net
Mar 02, 2009 | Daewoo DV-T47N VCR
RCA rcr311w remote won't change tv channel to Video 1 or Video 2 channel
my universal unit won't change the tv channels, everything else works except the channel changing. Does anyone have a solution., The company is only open during the week.
Feb 08, 2008 | RCA RCR311B Remote Control
Akai LCT2701AD Television Logo
1,383 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
