Question about Acer TravelMate 244LC Notebook
Acer Travelmate 244lc
Hi i have a problem with my laptop the screen will not light up and activity on the screen is barely visible. it did once light up but on power up the light was gone. Fn + F5 will allow another screen to work ok. The computer is clean and is otherwise working ok.my guess is the backlight has a loose connection or needs replacing ? can you help me repair it what parts will i require? Thanks Indy
  • indy singh
    indy singh Mar 10, 2007
    Thanks John . Il try it out.
  • Anonymous Nov 19, 2008
    Exact same problem as above.
    Sergeant:
  • 310 Answers
Hey Mate, replacing the backlight aint too difficult, instead of me describing it all heres a website giving you details on what you need and how to do it. http://www.lcdpart.com/doc/ccflinstallation.html all the best John
Posted on Mar 10, 2007
Cant read the menu. Is backlight broken.? I can see the word garnin when I turn power on. But the menu is difficult to read- Is it konfigutation for dark or light screen?
It depends on the model - but CCFL tubes are used by Garmin to light the screen of GPS devices. A CCFL tube comes with a high voltage inverter to power the tube. Meaning either the CCFL Tube or the Inverter can be dead.
Symptom is a barely readable screen and becomes a bit more visible when looked at from an angle. No light comes from the screen at all.
The inverter can be tested by holding oscilloscope leads close to the screen. A sinus waveform of about 50 - 60 Khz should be visible when the device is powered at full screen intensity.
Jul 10, 2011 | GPS
When i plus up my laptop the power lights come on but it doesnt post or screen comes on.
Check the hard drive activity light; if it is active at power on, look at the display from an angle to see if some ghosting of images is visible. If so, the back light for the display or its inverter may have failed.
If you have a friend you can borrow a monitor from or use briefly, connect it to the VGA (D-15 connector) to see if you have any video output. If you still see nothing, turn off the power and access the memory in the laptop. Remove and return any memory cards and try it again.
If you still have no boot, it will need technical help since this could indicate a failed motherboard or CPU.
Nov 15, 2010 | Toshiba Satellite L455DS5976 Notebook
DIM BACKLIGHT TOSHIBA L305D-S5924 LAPTOP
There are also another reason , the Back light lamp might be damaged also!
May 11, 2010 | Toshiba Satellite L305D-S5895 Notebook
MacBook 13" starts but screen is barely visible. Tried System Preferences - already on brightest setting. Works fine otherwise. Any ideas? Capt. Dave
could be your inverter board, whitch controls the backlight. I could very well be the backlight as well, but that is less likely. Inverter boards are not all too expensive, and if you are knoledgable with laptops, i would say doit yourself, but if you have any doubts, take it to apple, sur it will cost more, but it is the safet bet.
Jan 16, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
SCREEN IS BARELY VISIBLE WHAT IS WRONG??/
Oh no the replacement of the back light is a complex process and is not advisable for you to open up the LCD for its replacement as the LCD might get damaged in the process and might void you warranty. It is always advisable to contact the manufacturer or a service person to get it changed.
Aug 04, 2009 | Acer Aspire 3680 Laptop
Screen is dark and barely visible
the lcd back light is dead
replace lcd
sorry hardware fix :(
Apr 10, 2009 | Acer Aspire 5610-4648 Notebook
When powered up, the desktop is barely visible.
You probably need a new inverter or a back light replacement for the screen. Any good techie can do that for you, and not all that expensive.
Mar 16, 2009 | HP Compaq Evo n610c Notebook
Barely able to see screen.
Your screen or the inverter underneath it which controls the power to the screen is bad.
Feb 04, 2009 | HP Compaq Presario V2000 Notebook
Easynote R4 no screen visible and nothing from an external monitor either.
graphics chip blown.
are you getting any lights flash at startup, or any beeps for the bios errors ?
Mike @ compurepair.
Apr 04, 2008 | Intel Celeron -D 2.26Ghz Computer System...
Hp laptop
when u switched on the computer,screen will be Black then That is in RAM problem.Better to u change it RAM and check it.
Feb 28, 2008 | Computers & Internet
Acer TravelMate 244LC Notebook Logo
191 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
