Question about HP Photosmart C3180 All-In-One InkJet Printer
I turn my printer off at night. When I turn it on it prints a test color page every time. How can I stop this? Thanks, Narcie
  • 4 more comments
  • Anonymous Dec 22, 2008
    every time i turn my printer on a black and white test page prints
  • Anonymous Jan 03, 2009
    Every time I turn the printer on it prints a test page. I turn it off from the power button only, so that is not the issue. This problem started when I put in a new printer cartridge.
  • Anonymous Jan 27, 2009
    Same. Really annoying and wastes inc too.
  • mahbub_shahi Jan 27, 2009
    I installed a black carttiage, and when I turn on everytime I get test page.
    Please send solution.
  • Anonymous Mar 06, 2009
    Same problem. Wish there was a way to turn it off. I didn't see anything in the manual though.
  • pjtcmi Mar 07, 2009
    Using power button on printer doesn't correct the problem. Power off the printer, power it up, prints a test page (that uses a LOT of ink). No way that I can find to cancel the print job or a setting to stop this annoying feature. This didn't always work like this.
    Master:
  • 461 Answers
This does not sound normal. Are you powering it down using the power button on the printer? If you are disconnecting the power without turning the printer off first it could be leaving it in a confused state.
Posted on Dec 13, 2008
HP PSC 1400 test page
Cartridge calibration pending in your printer. Put printed align page in to scanner and scan it.. ensure that mono & color cartridge should be in good healthy condition..
Dec 28, 2011 | HP PSC 1401 All-In-One Printer
Hi, Wonder can you help my printer keeps printing off test page everytime it is turned on. this is only happening since i changed the cartridge, never did this before. thanks
Your printer is printing alignment pages, because the cartridge alignment was not completed since you replaced them. Follow the below steps to complete alignment.
  1. Turn the printer OFF and then turn back ON.
  2. Wait until the alignment sheet prints out fully.
  3. Place the alignment test page over the scanner glass.
  4. Press start color scan button.
  5. The printer "power" light will start flashing, indication the alignment process.
  6. After the printer stops flashing, turn off and then ON the printer.It will not print any test pages further.
We need to run alignment test every-time while we replace ink cartridges.
Regards
Riztech
Nov 27, 2010 | HP Photosmart Premium C309A All-In-One...
I have an hp 3150 all in one printer. Every time I turn it on to print a document it prints a test page. I am out of color ink so it doesn't print the additional numbers and lines to align the printer. I...
I know your problem and i want to know that have you changed or refill your cartridge?.
if yes
place one plain paper in the tray.
it will print the test paper
print it and place it on the scanner with the printed side down.
press the scan button from the printer
printer will blink the light for some time and stop blinking
now it didn't print test print every time you print
thanks
Jun 26, 2010 | HP PSC 1315 All-In-One InkJet Printer
Printer prints test page every time i turn it on how do i stop this
It wants to align the cartridges so you have to have both color and black ink installed, and it needs all of the colors to do the alignment. Until it passes alignment it will keep printing that page.
Oct 29, 2009 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1315 Prints test page every time printer is installed
Hi Jay,
This is mike, actually the problem is that that printer has not completed the aligning process, as a result the printer is printing the test page (Alignment page) every time when you turn it ON. So, I would suggest you to let the printer prints the alignment page and check whether the printer prints the page with all colors and it printed fine, once it is done, disconnect the USB cable behind the printer and then place the alignment page on the scanner glass by facing down the printed page downwards and press the scan button. This start the alignment process and the scanning process will be completed once the ON light is stop blinking. This will complete the alignment process.
Once done try to turn off and turn on the printer and check for the result. This should resolve the issue.
However, if the issue persist, then please revert back to me. Be sure that you use the HP genuine ink cartridges, not refilled nor re-manufacture.
Jun 20, 2009 | HP PSC 1315 All-In-One InkJet Printer
Hp C3180 printer prints test page every time i turn it on
You were being cheap when you ran out of ink and replaced only the Black Ink Cartridge.
Replace the Color Cartridge and the test page will stop printing when you turn it on.
Dec 24, 2008 | HP Photosmart C3180 All-In-One InkJet...
In starting 1 page print
I believe that after changing the ink cartridge you havent completed the alignment process.This Alignment test page will print everytime you turn the printer ON.To Complete the alignment follow my steps.
1.After turning the printer ON, wait untill the printer prints the Alignment test page.
2.Then place the alignment test paper on the scanner, facing down in a correct position.
3.Then press the Scan button(color) and wait untill the printer ON light stops flashing.
4.After the light stops flashing, take the paper out and the alignment process is completed.
Turn OFF and turn On the printer, it will not print the Test page again.try it and please let me know.Would really appreciate your rating for my solution.
Thanks
Riz.
Apr 15, 2008 | HP PSC 1315 All-In-One InkJet Printer
Keep printing test sheets
A lot of HP printers print a page to enable the print head alignment and calabration. This normally orcurs when a cartridge has been changed. If the alignment page fails then it will reprint alignment page until it can align.
So, you need to get that page it prints and place it on the glass and press scan, then it will complete alignment and be ready to rock.
See Here
Cheers
Jan 19, 2008 | HP PSC 1510 All-In-One InkJet Printer
HP Photosmart C3100 series
I just got off the HP help line.  After changing my black ink cartridge a test page was printing each time I turned the machine on.  This is very costly, in both time and ink as the cartridges themselves for this machine hold very little ink.  I tried to learn from HP tech how to turn off the test-print while keeping my color cartridge empty.  It turns out that you cant do it.  HP requires you to keep buying and using cartridges whether you need them or not.If you buy the color ink it will use it up in its testings.  And if you dont buy the color cartridge it will use up your black ink by printing the test each time you turn on the printer.  The printer was inexpensive sure, but I'm paying for it in wasted ink.
Dec 26, 2007 | HP Photosmart C3180 All-In-One InkJet...
Test page
I had the same problem and being helped by HP operator.
first take the USB cable out of your computer, then put it off and then on again...it starts to print the test page again...then after the printer stops printing, put the just printed testpage face down on the scanner(glas) and press scan manually...after the scanning(you wait till that is finnished) and then put the printer off and on again....then connect the USB cable to the computer and that will stop the printer from printing the testpage every time you startup your printer....
hope it wil solve your problem, it did for me...
Dick van den Broek
The Hague
The Netherlands
Feb 23, 2007 | HP PSC 1510 All-In-One InkJet Printer
HP Photosmart C3180 All-In-One InkJet Printer Logo
60 people viewed this question
Seeker5211
Seeker5211
