Question about Sharp Aquos LC-37GD6U 37 in. LCD HDTV
No sound on Sharp LC-37D6U
I've seen posts elsewhere regarding this, I get a ''tick'' as it powers up and no sound. I found a LC-45D4OU but have no idea whether the sound board is a separate item or part of the main board. I'm hoping it will interchange. Has anyone here torn down a Sharp LCD TV? If so, where is the sound board?
Thanks, Jon.
  • dbe3 Dec 18, 2008
    We had a guy come out and put a piece of tape between the wires and the board. He said "this was a problem they company was experiencing". It lasted about 6 weeks and now the sound is off again. As it was intermittent we may have let it go to long and the board was damaged. We have a call into the guy now for more info.
  • 208 Answers
SOURCE: Sharp Aquos LC 37D6U
Please be aware that this a big problem on this unit. The insulator material used by sharp to between the IC's on the AV board both on top of the boards and underneath the the AV pcb is failing. This insulator is mounted to the IC and under the metal heat sinc. Remove the back and pull the AV Board out of the unit. Use zylene or alcohol and clean all of the grey insulator from between the pins on the ic and order the replacement insulators from Sharp. Most times this will correct the no sound problem. Sometimes this has also damaged the AV pcb and it will have to be replaced. The parts that should be replaced come in a kit with sharp part # PSPKIT663WHZZ. If the kit is not available the 2 parts needed are PSPAZA663WJKZ AND PRDARA216WJFW.
Posted on Feb 05, 2008
SOURCE: No sound on Sharp Aquos 37' LC-37D4U
I had the same problem on my 37" Aquos. Sound went out about 8 months ago after 4 years. Technician said it was the Sound Power Supply. Total cost to fix was $440. $250 for the power supply and $170 for labor. Has worked fine ever since. When I asked for the old power supply he said he had to give it back as a trade in. I don't believe that so I don't really know if the power supply was the real cause.
Now I've lost sound on 4 channels on my 20" Aquos. Great picture, but wouldn't buy another Sharp product.
Posted on Dec 24, 2008
dsacco86
  • 1077 Answers
SOURCE: Sharp LC-37d6u audio problem
Have you tried the reset buttons on the back of the TV?
It should be right below your Cable IN port.
If that doesn't work, you may have to take it into a repair shop for the main unit board to be replaced. The part # is KD352
It's $99.59 at Shopjimmy.com
So, don't let the repairman rip you off.
Posted on Apr 01, 2009
  • 4 Answers
SOURCE: Missing LCD Stand Screws for Sharp Aquous 46" LC-46D62U
am not sure on size service manual doesnt say but there 2 1/2 long.
Posted on Jul 22, 2009
satavlad
  • 405 Answers
SOURCE: Sharp AQUOS LC-46D85U green LEDs blinking, no picture, no sound
Sharp warranty is the way to go.
Posted on Oct 25, 2009
Our sharp LC-37D6U does not turn on. The opc/dl light keeps flashing green X3 then every second or so. and the blue power button flashes also. What might we have to do to solve the problem? thank you
The main tv Tuner signal board it is dead or it have problems,but tv still usable.Tries push the remote power switch off/on again everytimes OPC/Power LEDS lights flashes.Have to do this maybe 3 or 4 times for the tv to have a lite up LCD screen panel backlight to make the tv Tuner signal board to work again,for the tv to work.If still have same problems after 3 or 4 times power switch pushes off/on still have OPC/Power LEDS lights flashes.Mean the main tv Tuner signal board it is dead and can not be trying to save it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv Tuner signal board for the replacement.This solution 100% will work,if ur tv main Tuner signal board still have life left in it.I do this every few days out of a week for my 46" Sharp Aquo LCD tv set,tv it work all the times.
Jun 12, 2011 | Sharp LC-37D6U 37 in. LCD Television
I need some information on buying a ac adapter or power cord for the Sharp Aquos Model LC-22SV2U.
Cord: http://www.newremotecontrol.com/catalog/dyn_accy_data.php?catnum=QACCD3097CEPA
Adapter: http://www.newremotecontrol.com/catalog/dyn_accy_data.php?catnum=UADP-0243CEPZ
On the adapter: I've seen them a LOT less expensive just recently. Google it and choose "shopping" to narrow results. There won't be many, but I think you'll find one at better price in just a few minutes. Try ebay as well; that's where I found repair parts for the same model. Good luck!
Dec 20, 2010 | Sharp Aquos LC-22SV2U 22 in. LCD...
Can fix the audio problem myself or is there a place that willing to buy my Sharp LC-37D6U TV with no audio? I would prefer to make some off it than recycling it away.
Actually there is a service bulletin on this television. Sharp will repair the no sound problem for no charge. Call 800-237-4277. Please remember to provide feedback here if this helps you.
May 07, 2010 | Sharp LC-37D6U 37 in. LCD Television
Mar 31, 2009 | Sharp LC-37D6U 37 in. LCD Television
Call Sharp. They are fixing my 18 month old LC40C32U for free.
Jun 10, 2008 | Sharp Aquos LC-32D40U Television
Sharp aquos LC-37D6U
the goop under the heat sink is thermal compound and some of it is toxic so please be careful.
Mar 28, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Sharp LC 37 D6U
When you turn the tv on, do you hear a faint “pop” noise from the speaker? If so, the problem is with the heat sink under the audio IC. Over time, the heat sink will lose its consistency and start to melt, thus shorting out the audio circuit. To fix, you’d need to clean off the melted residue on both sides of the audio IC as well as replacing the heat sink with a newly redesigned Sharp Heat Insulation Pad. It’s a pretty complicated fix, I suggest calling your local authorized sharp service center to fix this problem. The part is inexpensive, so you’re most likely looking at a labor charge (maybe around $200ish) for the repair if they are not marking up the price too much.
Sep 04, 2007 | Sharp LC-37D6U 37 in. LCD Television
Sharp Aquos LC-37GD6U 37 in. LCD HDTV Logo
78 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
