Question about Kenmore 24032\24036 Top Load Washer
How do I fix my Kenmore washing machine?
Kenmore washing machine 110.82884100 won't start just buzzes
    Master:
  • 479 Answers
It could be many things.motor jammed or the bearings got loose. If your washer doesn't seem to work at all, check these:
No power
Lid switch
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
It won't drain If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
click the above link for more detailed help with parts required u can order here
http://www.repairclinic.com/0088_11_1.asp#Level1_1
Posted on Dec 13, 2008
    Genius:
  • 1,847 Answers
Unpluge from the wall and repluge back after 15 min and then retry.
  • Legin Varghese
    Legin Varghese Dec 13, 2008
    also try Press and hold the end of cycle signal button for about 5 seconds and it will reset
    let me know the status...kevin
My moms pipes froze to her washing machine. They thawed and the machine filled with water but they won't wash. She can hear a buzzing sound like the machine is trying to wash the clothes but nothi
Yes , I think the valves also must have jammed in the process and when the hot water filled up in due course it must have released.
It is best to switch off water supply to the machine in such times.
Jan 23, 2013 | Washing Machines
Kenmore 80 series washer won't spin just makes a loud buzzing noise.
Possible that the motor is not moving , could be a faulty capacitor to the motor. Also check for the free movement of the agitator, if the shaft is tight then it can cause a drag on the motor.
check this link:
http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Jun 28, 2012 | Kenmore Washing Machines
My Kenmore 80 series dryer won't stay on unless I
Aha!
You are going to make me guess!
I am guessing you have to hold the start button down.
So.
Try a new start button first.
If that does not fix it, replace the timer/control unit.
God bless your efforts.
Jan 05, 2018 | Kenmore Washing Machines
My washer fills up with water and quits after that, it makes a buzzing noise when it should start its cycle. what can i do to fix this? it is a kenmore series 80
This could be a capacitor, which gives the motor the 'spark' to start, or the motor itself. If you try to move the empty machine's basket by hand, is it hard to move or does it spin freely?
Joe
Aug 29, 2011 | Kenmore Washing Machines
Loud Buzzing Sound from Dishwasher
have you ever seen green led "Clean" light flashing? before or about the same time the buzzing sound started? and if so that would indicate that the control senses a fault in the temperature rise during the heating cycle and that the electronic control could be reset by initiating a service diagnostic cycle.(which is what you were trying to do) pls reread your manual there are times during that sequence that some buttons have to be pushed at the same time and within a certain amount of time..possible that your machine also has a bad timer which would give you a buzzing noise..if thats the case I would recommend replacing the cpu or control board..or the machin all together..The Kenmore Ultra Wash Quiet Guard name is sears but whirpool has the contract to produce all "kenmore products.hope that helps.
Jul 30, 2009 | Dishwashers
Series 70 fills wit water stops then makes a slight buzzing sound
The electric motor my have failed or a part called a capacitor could be the problem? The capacitor is part of the starting circuit of the electric motor, if this fails the motor will not start therefore the washing machine won't spin or agitate.
Jun 16, 2009 | Kenmore Washing Machines
Kenmore washer doesn't drain
This is likely a pressure switch issue.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 27, 2009 | Kenmore Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
21 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
