Question about Maytag MMV1153A Microwave Oven
Fans runs when door closed, light always off
Maytag MMV5207BAS.
When door closed, fan runs and internal platter continues to move. Internal light off with door open or closed. Control panel seems to function normally otherwise, will cook Local repair tech says the board needs to be replaced, at a cost of $400. Help!
  • ualfly1 Dec 29, 2010
    Your comments were right on, and two years later, the microwave is still working well after your repair. Thanks again!
  • Maytag Master
  • 9,098 Answers
The first thing to replace is your technician. *grin*
You have a shorted main relay (lamp relay) on the control circuit board and a burned out light bulb.
You do not need a new board.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
Page 24 of your owner's manual shows you how to replace the light bulb. Be sure to unplug it first.
If you don't have your manual, you can download it here.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Dec 15, 2008
All controls,lights,fans are normal. Turntable, microwave, convection do not work. Internal fuse?
There typically is an internal ceramic fuse. It is usually near where the power cord enters the oven, or behind the control panel (on over the range units).
The problem you are describing, though, sounds like it may be an open thermal protector on the cavity. Most are diamond shaped, with two wires. Unless the cavity is extremely hot, it should show continuity.
May 10, 2016 | Microwave Ovens
Open door and internal fan engages.
One of the door interlock switch could be bad.
Nov 14, 2014 | Samsung 1.8 cu ft Over-the-Range Microwave...
How do I get my emerson microwave to turn off after the timer is finished?
There are a couple of microwave ovens out there where after it has finished cooking, the light and fan continue to run until you open the door. Then the fans shuts off, but the light remains on. When you close the door, then the light shuts off. If the light and fan go back on when you close the door, then you have a bad door switch.
Oct 20, 2014 | Emerson Microwave Ovens
Frigidaire gallery microwave light stays on and internal fan stays on
Good Afternoon Friend, thank you for your post!
I see that the internal light and fan continues to run on your Electrolux microwave with the door close. This sounds like the issue is related to a faulty door switch. I am fairly confident that an authorized service agent will be able to restore your microwave to its normal operating condition. You can often locate a qualified service technician on the manufacturer website. Hope this helps! - Z
May 20, 2014 | Microwave Ovens
Maytag microwave MMV4205BAW interior fan continues to run when door is closed
One of the micro switches has malfunctioned, and must be replaced for normal operation.
Apr 02, 2012 | Maytag Microwave Ovens
Maytag mmv4205bab continues to run after time is up. The fan does not circulate, but it continues to heat.
Our microwave in office won't shut off. It continues to heat and fan is running as soon as we close the door. Tried everything, unplugged, canceled everything. Please let me know what to do.
Oct 04, 2010 | Maytag MMV4205 Microwave Oven
My Dacor DMT2420 fan, light and turtable motor run continuously when the door is open. I have unplugged the unit to reset it with no help, another on-line forum expert suggested checking the door switches...
If the cooling fan, light and turntable run continuously when the door is open, but not when it is closed, your secondary interlock (bottom door switch) is shorted (always on).
Even if it's shorted, the actuator button (usually red) will still move up and down when you open and close the door.
It will need a new door switch.
See the service manual here. See our file on door switches here.
Jan 04, 2010 | Dacor DMT2420SS Microwave Oven
Control panel seems to be responsive, internal
Make sure the glass platter is correctly seated on the plastic drive. Now gently press down on the platter and see if it resists turning. If the platter turned easily, the plastic drive is spinning on the motor shaft and needs replaced. If the platter resists movement, the motor under the floor needs to be replaced. If you found any of these suggestions helpful, please rate my solution. D. Lange
Apr 25, 2009 | Sharp R-930AK Convection/Microwave Oven
Parts
I don't seem to be able to find a Door Handle for my Maytag microwave Model #MMV5207BAS can any body help me. I have tried numerouse sites but the handle does not seem to be available.
Apr 23, 2009 | Maytag Microwave Ovens
Maytag MMV1153A Microwave Oven Logo
218 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
