Question about HP Pavilion dv1000 Notebook
Upgrading my laptops memory
I want to up grade the memory on my HP DV1000 to 1 GB, do I need to put two 512 simms or one 1 GB simm card?
  • rdiaz_aci Dec 13, 2008
    h2h thank you for the excellent response. this sure helps us dummys
    Novelist:
  • 59 Answers
Hi rdiaz_aci,
The HP DV1000 has two slots for memory modules - you can either use one 1GB module and leave the other slot empty or use two 512MB modules. There should be no difference in performance, but I usually recommend having more than one memory module in your PC at any given time. Here's why:
It's true that the cost of a 1GB module is slightly less than the cost of two 512MB modules (only a $5-10 difference), but in the event of a memory failure or defect, if you have two 512MB modules, you can remove the defective one and run the PC on the other one. But if you have only one module and it fails, the computer will be inoperable. That means you won't even be able to boot up and figure out what's wrong.
I think that the extra $10 is well spent because it gives you the safety net (and avoids the headaches that you'll have if your only chip fails.
Having said this, the dv1000 should already have two 256MB modules installed. If you replace one of them with a 1GB module and leave the other one in place, you get the best of both worlds - the 256 will allow you to boot up in the event the 1GB fails, and the total memory will be more than the 1GB module would give you alone. FYI: the dv1000 can accommodate up to 2GB of memory.
For your reference, here is the link to the manual with instructions on how to replace the memory modules:
http://h10032.www1.hp.com/ctg/Manual/c00569409.pdf
I hope this helps - please let me know if I can be of any further assistance.
Regards,
H2H
Posted on Dec 13, 2008
    Scholar:
  • 113 Answers
If it has two simms slot available you can, but I suggest better use the 1GB
Camera won't take pictures. Everything shows it is working put when you put Simm card to check pictures no pictures on it. Re formated the card put a
Check the memory card to make sure that it is good and capable of storing picture data. Easiest way is to try another card and see if camera does the same thing. If so then the issue is with the camera's electronics.
Oct 23, 2015 | Cameras
How to get printing threw pos system
Sir/Madam
PRINTER ERROR CYCLE POWER
Control Panel Message
61.x PRINTER ERROR CYCLE POWER
Event Log Error
Service Message 61.0x.00
The printer encountered a parity error when accessing either internal memory (x = 0) or SIMM memory (x = 1-4).
Required Action
  1. Cycle power.
  2. If the message persists: Verify that the SIMM module is installed correctly.
  3. Turn off the printer, remove the SIMM module, and then turn on the printer.
  4. If the message does not display, replace the defective SIMM.
  5. If the message continues, turn off the printer and remove the next SIMM module, then turn on the printer.
  6. Repeat this step for the remaining SIMM modules until the problem is isolated.
  7. If the message continues without any SIMMs installed, replace the Formatter PCA.
If you Still Having Hp Printer Problem Then Visit official HP Printer website Below Link URL:
http://h20565.www2.hp.com/portal/site/hpsc/template.PAGE/public/kb/docDisplay/?sp4ts.oid=25474&spf_p.tpst=kbDocDisplay&spf_p.prp_kbDocDisplay=wsrp-navigationalState%3DdocId%253Demr_na-bpl70117-1%257CdocLocale%253D%257CcalledBy%253D&javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken#N10C53
Or
If You Still Facing Problem Then Follow Us For HP Printer Online Help On: HP Printer Support
Feb 12, 2014 | HP (EY023AA) Thermal Printer
Compaq Presario CQ56-115DX bluescreen
wwats happening is you may have 1 of your simm memory chips that are bad theres a small cover on back of laptop that is about 3.5 x 3.5 inches square take off that plate and youll see 2 memory simms take out 1 and reboot if problem persist try removing other and putting first one back then reboot if problem persist put simm back in again then reload windows using your disk and reinstall windows that will fix this issue your having your lcd sounds like its fine though
Feb 27, 2013 | Compaq Presario CQ56-115DX Laptop
I have one printer lj 2420 68.0 permanant storage full error
Error 68 is simm memory problem.
68 Error / Service / Cold Reset
All printers
  1. Temporary error. Cycle power to printer
  2. Bad formatter PCB
LJ4, 4+, 4P
  1. NVRAM not initialized.
68 Memory
IIISi, 4Si, 4V
  1. Bad SIMM memory. Check and replace SIMM's
Feb 05, 2011 | HP LaserJet 2420n Printer
Service 960 memory error- r for my Lexmark C532n printer
A 960 RAM MEMORY FAILURE message indicates a failure of the RAM MEMORY that is soldered onto the printer's main controller/system board.
If the printer is displaying a 960 memory error.
1. Power off the printer.
2. If you have any extra memory SIMMs or code SIMMs installed in the printer, remove them.
3. Power on the printer.
4. If the 960 error continues, the main controller/system board will probably need to be replaced.
5. If the 960 error does not return, try printing a few documents.
6. If these documents print correctly, the cause of the 960 memory error is probably one of the SIMMs you just removed.
To confirm this, do the following:
1. Turn off the printer and reinstall each SIMM one at a time.
2. After you install each memory card, power the printer back on and try printing. If the error returns as soon as you install a particular SIMM, that SIMM is probably the cause of the error message.
Nov 08, 2010 | Lexmark C530dn Laser Printer
My hp ipaq hw6515 does not read my Afghanistan's sim card
The IPAQ 6515 will only work with GSM Simm and network. It is also NOT 3G compatible.
You can verify that the 6515 is working with another network SIMM, then it is likely that your Simm card is not compatible and may in fact be design on Afghanistan's 'Analog' network.
Incidentally, the 6515 will also not work in Japan even with a working 'roaming' SIMM as the Japanese Mobile Network is also not compatible!
Hope it helps!
Dec 15, 2009 | HP iPAQ hw6515 Pocket PC
Brothers Hl 1440 memory upgrade
Assuming that you have the Brother HL-1440, your printer comes with 2MB installed. You may upgrade it up to 32MB maximum. However, your printer appears to use SIMM memory modules. The specs for the printer should be:
Speed: 60-80 nsec
Pin: 72-pin
Output: 32 or 36 bit
To install the memory:
1. Turn off the printer an dunplug the power cord from the AC outlet. Disconnect the interface cable from the printer.
2. Open the rear cover by unscrewing the two screws that secure the access cover and remove the cover.
3. When handling your SIMM modules, pay close attention to static electricity discharges, so be careful and hold the SIMM by the sides.
4. Install the SIMM into the slot at an angle, and then push it gently toward vertical alignment, it should click when it goes into place. DONT FORCE IT IN, be careful
5. Re-install the access cover and secure it with the screws.
6. Close the rear cover
7. Reconnect the interface cable, power cable and turn on the printer.
If all goes well, that should do it.
May 22, 2009 | Brother HL 1440 Laser Printer
Intel D915GUX Memory Upgrade Problem
You should Know that, none of the 32 bits Windows can detect more than 3 GB of ram. I think, compatibility cam be a fact but dont forget this one.
Dec 21, 2008 | Intel D915GUX Motherboard
Problem with start up
are you using ac adaptor? remove everything external and remove battery and try it.
Feb 21, 2008 | HP Pavilion dv6000z Notebook
HP Pavilion dv1000 Notebook Logo
83 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
