Question about Acer Aspire 6920 Notebook PC
ACER Aspire 6920 Touch Media console is frozen !!
My laptop - Aspire 6920- is pretty new, and it's 1 month old.
The Touch media console for Arcade Deluxe is frozen... It lightens the mute and volumes(in full) at the same time and the others are all dark.
I pressed every single button but none of them worked..
I've looked for programs that solve this problem but i couldn't find one.
control panel doesn't even have a program for it ..:(
How can I get it fixed?? PLEASE HELP ME!!
  • 6 more comments
  • Anonymous Dec 17, 2008
    axactly the same problem here :(
  • gerryis Dec 25, 2008
    Same problem , Aspire 8930G, worked 1 week, purchased Dec 16
  • jleblanc17 Dec 26, 2008
    I have the SAME problem! Maybe their's a patch or something for it online?
  • lpetan Dec 29, 2008
    no way, same here! just one day when i turned it on it was exact same as yours
  • Anonymous Jan 07, 2009
    same as alex yoons
  • bearnc146 Feb 27, 2009
    the Media Console is frozen full volume and mute is lighted
  • Anonymous Mar 06, 2009
    My Acer Aspire 6920 Touch Media console is frozen, and I am looking for someone to help how to fix this problem, please I need your help.
  • Anonymous Mar 27, 2014
    ACER 9620G cine dash media console frozen on in high volume setting with mute button enabled
I found this solution on another support blog, its works....
i had the same problem but the answer is so freaking stupid. k tried installing all the software again and again but no cure. Then I read on a forum that i just needed to get the battery out for several second and it worked!!
Summary:
shut pc down,
remove battery (and if plugged in the power cord)
Replace battery, boot it up and all should be fine.
if i does not respond then open launch manager
Posted on Dec 25, 2008
  • dinos26 Jan 04, 2011
    I was trying for about 3 days to fix it through a program of Synaptics withough any change! You just saved my Acer Deluxe!! Thank you very much!!
Hey, ive had the same problem and you will never guess how simple the sloution is, all you need to do is shutdown your computer, take out the battery for about ten seconds, replace it and turn on your computer, wait for it to boot and it should be working
Posted on Mar 04, 2009
Thanks so much it fixed it. I have emailed Acer twice with no response. Next time I will buy something else
Posted on Feb 27, 2009
Thank you all, saved my day (and my laptop, as it was going out the window from the 6'th floor - BAD FALL)
Posted on Apr 28, 2010
OMG, so simple. Thanks heaps all, this worked successfully. I have been efn around with this for day to try and solve it!
Posted on Sep 11, 2009
THANK YOU SO MUCH. Genius!
Posted on Dec 26, 2008
Can not play cd's or dvd's
There is no need to use acer arcade, you can just use windows media player or windows media center (which is acer arcade just changed a little by acer). The only way to recover acer arcade would only be possible by using your acer program recovery disks.
Feb 09, 2010 | Acer Aspire 6920 Notebook PC
My 1 years old acer 6920 is will suddenly freeze without any symptom and will resume its function after few minutes. Sometimes blue screen show up after few minutes. Very unpredictable. Mostly happen when...
OS corrupted. dont worry. format your OS and reinstall it. YOu will find good service. i ahve my own acer aspire. i do formet every 6 month. i am not jocking. if done thumbs me.
Jan 06, 2010 | Acer Aspire 6920 Notebook PC
Media center keypad not working
If you are using windows, when the OS is booting, press F8 and select "last known good configuration" in the list of options. Most probably it'll work If it doesn't, try restoring the system to a previous state using system restore utility.
Thanks
Dec 19, 2009 | Acer Aspire 6920 Notebook PC
Start up stuck on Acer Arcade Deluxe screen
if you can boot into safe mode by pressing f8 at startup, check the startup folder for acer arcade and remove it if present.From your start button go to (start-programs-startup).
another option is to check the run key in the registry: one caveat though - please don't mess with things in the registry you don't understand. Deleting or changing unknown registry keys can result in a non-booting pc.
please stick strictly to my instructions and you will be fine. We're going to look and see if windows is calling the acer arcade to run at boot time:
click your start button and type 'regedit' (no quotes in the start search field. A window titled 'registry editor' will appear. Now, to expand a field in the registry, we left-click on the triangle on the left side of the field.
so, click the triangle beside HKEY_LOCAL_MACHINE
go down to 'software' and click the triangle beside it. go down to Microsoft and click the triangle, go to windows and click the triangle, go to current version and click the triangle, go to run and click on the run folder, not the triangle beside it.
Now look in the list of items in the run folder. these are all items that run when your pc boots. If you see an item with 'acer arcade' or just 'arcade' in the name, then delete it. DO NOT DELETE ANY OTHER REGISTRY KEYS....PLEASE!
if you found acer arcade and removed it then reboot and all should be better. if not, boot to safe mode again, click start button and type in 'msconfig' - no quotes. go to the startup tab, and again only uncheck anything with acer arcade in the name.
Hope this helps!!
Aug 09, 2009 | Acer Aspire 6920 Notebook PC
I have aspire 6920 the audio control panel on the left side of the keyboard is frozen. Can you help?
Mine froze once too, all you have to do is take out the battery for a few minutes, it resets the hardware...it is not a software problem like many people think it is, it has worked for many people and my touch pad has worked fine since and it has been almost 10 months.
Jun 21, 2009 | Acer Aspire 6920-6621 Notebook
Volume touchpad has frozen on mute
This happened to me.
Power down (shut down) and then remove battery for a few seconds.
This fixed my CineDash Media console.
Jan 17, 2009 | Computers & Internet
Frozen media tochpad on acer 6920
NO!!
bad idea, mine locked up, then i forgot my charger, battery died and stayed dead for a day or 2 then when i charged it again the touch pad was fine, all you have to do is reset your laptop, by removing the battery for a little bit, not sure how long is really nessicary but 1 hr should def. do it! hope its not too late!
Nov 01, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Acer laptop/all keys and buttons frozen after boot up in any mode.
try to repair the OS using the window xp media centre CD
thank you
all the best
zinja
Sep 07, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 6920 Notebook PC Logo
3,186 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
