Question about Canon Office Equipment & Supplies
Printer is only printing in lite gray. The color part is working. I have done everything...iuninstalled & reinstalled, cleaned nozzles, checked every aspect of printer out. Whatever the problem is, the test pattern in black is missing
    Master:
  • 461 Answers
Appears to be a problem with the black ink cartridge. Gray can be obtained by using the color cartridge only.
Posted on Dec 13, 2008
Cant get my Epson Workforce 633 to print. WILL NOT print black.
check if ink came out of the head or nozzles if not then first open the nozzles and head with warm water.
Feb 10, 2015 | Epson WorkForce 633 All-in-One Inkjet...
Tip
How to solve Print Cartridge Problems ?
One of the following messages may appear on your the control panel display
  • Color or Right Print Cartridge is not compatible
  • Incorrect Print Cartridge(s)
  • Print Cartridge Problem
  • Incorrectly Installed Cartridge(s)
  • Black or Color Cartridge(s) Failed
  • Color or Right Print Cartridge is not intended for use in this printer
Step one: Remove and inspect the cartridge
Step two: Make sure the cartridge is compatible
Step three: Clean the cartridge contacts
1. Open the printer lid and wait until the carriage stops moving, and then unplug the power cord.
2. Remove the cartridge and place it on a piece of paper with the nozzle plate facing up.
NOTE: If you are removing a tri-color, photo, or gray photo print cartridge, try to clean the contacts quickly enough that the cartridge is not outside of the printer for more than 30 minutes. The ink can dry and clog the nozzles if the cartridge is outside of the printer for too long.
3. Dip a clean cotton swab in distilled water, and then squeeze it to remove most of the moisture.
4. Clean the print cartridge contacts. Do not touch the nozzles.
5. Clean the contacts inside the carriage, inside the printer.
6. Either let the cartridge sit for ten minutes to allow the cleaned area to dry, or use a new swab to dry it.
7. Reinstall the cartridge, plug in the power cord, close the printer cover, and then try again to print.
Step four: Reset the printer
Step five: Replace the cartridge
Step six: Print in backup mode
Step seven: Service the product
on Jan 03, 2010 | Office Equipment & Supplies
MP530 all in one printer - bought Staples magenta & blue inks but printer won't print those colors but did print older Canon inks not needing replacing; bought new Canon magenta & blue inks but...
What you can do is take the ink cartridges out of the print head and remove the printhead. Hold the print head over a trash can and take some 409 cleaner and spray the little pads inside the print head til you start noticing the colors dripping into the trash can. You will them want to dry off the print head as much as possible and litely wipe off the outside and the bottom of the print head with a paper towel. Then reseat the printhead back into the printer and the inks. You will then want to run a nozzle check from your printer software or from the printer properties. If the inks still are not showing up run one or two cleanings. If the issue still persists then you might have to replace the printhead. If this is the case you can look up part number: QY6-0059-000 online to replace the print head.
Jun 30, 2010 | Canon PIXMA MP530 All-In-One InkJet...
How do you remove/clean/replace print head on pixma mp610 BK nozzle blocked.
Try this :
The gray-colored arm (it's not that small) is to the right of the cyan cartridge. It is the arm or extension of the gray-colored hinged cover. Remove all ink cartridges, lift the gray-colored arm up, and pull the print head out. Clean the print head with a cotton ball soaked with water or rubbing alcohol. Dry and re-install the print head.
Jun 16, 2010 | Canon PIXMA MP610 InkJet Printer
PRINTER COLOR PROBLEMS
o.k. I can give you a few tips that may be of assistance.
you need to run a printer alignment page like you do when you put in new cartridges.
unplug your printer plug it back in.
open door and take out print ink cartridges.
put them back in and then close the door.
It should now prompt you to do a test alignment page.
Also, Another thing to try is to hit file, top left of page, hit print, click properties. color tab.
make sure you are printing high quality on chose different color management options.
FINALLY TRY THIS:
When Printing Becomes Faint or Colors are Incorrect
When printing becomes faint or colors are incorrect, even if ink remains in
the ink tanks, the print head nozzles are probably clogged. Follow the
procedures below to maintain the print head.
Important Before maintaining the print head, check the following;
􀁺 Open the front cover and make sure that the ink tank
contains ink. If it is out of ink, replace it.
􀁺 Ensure that all the orange tape of the ink tank has been
peeled off.
􀁺 Press "PUSH" on the ink tank and ensure that the ink tank
is installed securely.
􀁺 Increase the Print Quality setting in the printer driver
Printing the Nozzle Check Pattern
Print the nozzle check pattern to determine whether the ink ejects properly from the print
head nozzles, and to verify print head alignment. Use this function when printed results are
blurred or the color is incorrect.
1 With the printer on, load a sheet of Letter-sized paper in the printer.
2 Open the Printer Properties dialog box.
See "Opening the Printer Properties Dialog Box Directly from the Start Menu" on
page 25.
3 Print the Nozzle Check Pattern.
(3) When the confirmation message is displayed, click OK.
When the confirmation message is displayed after the nozzle check pattern has
been printed, click OK.
See "Examining the Nozzle Check Pattern" on page 52.
Note Nozzle check pattern printing can be executed also from the printer
itself. With the printer on, load a sheet of Letter-sized paper in the
printer. Hold the RESUME/CANCEL button until the POWER lamp flashes
Print Head Cleaning
Clean the print head if you suspect that the nozzles might be clogged. Cleaning the print
head consumes ink, so perform print head cleaning only when necessary.
The print head can be cleaned also from the printer itself. With the printer on, load a sheet
of Letter-sized paper in the printer. Hold the RESUME/CANCEL button until the POWER lamp
flashes once.
1 Ensure that the printer is on.
page 25.
3 Start Print Head Cleaning.
(1) Click the Maintenance tab.
(2) Click Cleaning.
(3) Select the print head to be
cleaned.
(4) Click Execute.
Print Head Deep Cleaning
If print quality does not improve by standard print head cleaning, try performing print head
deep cleaning, which is a more powerful process. Print head deep cleaning consumes ink,
so perform this procedure only when necessary.
page 25.
3 Start Print Head Deep Cleaning.
(2) Click Deep Cleaning.
deeply cleaned.
(4) Click Execute
Aligning the Print Head
This operation must be carried out when using the printer for the first time. Aligning the
print head positions allows you to print without shifts in the color registration.
Print head alignment is performed either automatically or manually. This section deals with
automatic print head alignment only.
page 25.
3 Print the pattern.
(2) Click Print Head Alignment.
(3) Check that paper is loaded in the
printer and click OK. If a message
warning you not to perform other
operations appears, click OK.
It takes about one minute to start
___________________________________________________
this covers everything you should solve the problem with my advice.
please give me a good rating for my time and effort! Thank You
Mar 28, 2010 | Canon i860 InkJet Photo Printer
Epson Stylus CX 4200 won't print color copies of anything
Uninstall the printer software.
Restart your computer.
Download the latest drivers and software for the printer.
Load the software.
Part of the software could have corrupted itself...
Jun 11, 2009 | Epson Stylus CX4200 All-In-One InkJet...
Epson 880 not printing in color
Was gone for the weekend.
Yes, the grayscale option gives you black and white or black tank printing only.
If you go to start menu, control panel, printers, right click your printer there is the option to print test page. In the upper left should be the windows logo in color. If you don't have that and you know you've removed the protective tape for the bottom of the color cartridges and when doing the nozzle checks "you have color?", then you probably need to reinstall your printer driver.
Is your printer connected via a USB cable, a thin cable with a flat connector at the PC and a square connector at the printer. Then, let me know. Send me your printer model from the back of the printer model sticker and I'll send you the instructions and a link to the current driver as well as a program link to download a system registry clean up utility that's free to use and can clean up from an uninstall of your printer.
Regards,
Worldvet
Aug 09, 2008 | Epson Stylus 880 InkJet Color Printer
Found the answer. For some reason, my computer accepted a Mac driver. It called the printer Epson Stylus COLOR 880 (M). I went back to the original installation disk; thereafter, I had two printers, one without M, one with M, and deleted the M printer. All is working fine now.
Shades of gray printing as brown
does the black do a complete nozzle test print.if not clean several times and try nozzle test again
Dec 26, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
26 people viewed this question
old marine
old marine
