Question about Bernina 1008
I have a bernina 1008 and forgot where the arm on the walking foot goes. Do I attach it to the needle screw?
    Problem Solver:
  • 6 Answers
Well yeah, but the arm on the walking foot is like a fork with two tines. The needle clamp should be in the middle, between these two tines. On my machine, I need to loosen the needle clamp quite a bit before I can get the dang WF on there.
Posted on Jan 24, 2009
  • Bernina Master
  • 1,388 Answers
The arm on the foot goes above the needle clamp.
Posted on Dec 13, 2008
Walking foot is not feeding fabric.
hi can i ask you did your walking foot come with the machine cause if it didn't that could be your problem let me know so then we can check other avenues ;
Jan 02, 2018 | Bernina Sewing Machines
Why will the walking foot number 1/p60443 not work on my berina virtuosa160
Are you not able to attach it to your machine or does the walking foot not work properly once it is attached?
The number should fit your machine unless someone inadvertently sent you the wrong foot.
If it attaches but doesn't "walk" when you sew, then it is not installed correctly. Be sure the needle clamp screw is "inside" the C-shaped lever of the walking foot. Hint: it helps to tilt the walking foot when installing in order to get it in the correct position for attachment as well as getting the C-clamp around the needle clamp screw.
installing Bernina walking foot Google Search
Aug 07, 2017 | Sewing Machines
Cant get the bernina walking foot in position on the 1031 machine
The walking foot has a spring loaded lever that rides on the needle clamp screw. If you lower the needle into the hole on the walking foot it will remove the pressure and make it easier to attach the walking foot to the ankle.
Mar 07, 2016 | Bernina Sewing Machines
How do I keep the walking foot from unscrewing the needle holder on my bernina record 730
I don't know about bernina but I will take a shot at your problem. Make sure your needle is inserted in the needle arm with the flat part of the needle facing away from you. After it is for sure inserted in the crack in the arm tighten the needle down firmly. If the needle is backwards it will continue to come out. Your machine might sew but it will possibly make noise when the needle is in the down position. The problem isn't the walking foot.
May 22, 2014 | Sewing Machines
I purchased an Elna 7000 on E-Bay.Wonderful machine. I also purchased a 492000-20 walking foot for it. I can not find instructions on how to attach the walking foot to the machine.
I'm assuming that this is a generic style walking foot for low shank machines and it will fit your Elna?
To attach it, you will see a long lever arm at the front of the foot and the little curved bracket at the back of the foot.
Remove your usual foot and the clip on foot holder by undoing the thumb screw. Now fit the walking foot on instead by putting the lever arm around the needle bar and the curved bracket around the pressure bar and then putting the thumb screw back into place and screw up tight to hold the foot in place. Now lower the pressure foot and manually wind your machine forward a few stitches. As the needle bar goes up and down, it should move the long lever arm too which works the walking foot teeth gripping the top layer of fabric with each stitch.
Trust this helps.
Mar 24, 2011 | Elna 8007
Not really a problem. Just trying to attach the walking foot. I removed the shank and screwed the walking foot on. However, there is a white, plastic, two-pronged gadget on the right side of the foot that...
That would be the drive arm of the walking foot. It goes around the needle bar clamp and when the needle goes up and down it makes the foot work. Take off the presser foot screw, attach the arm around the needle clamp, and reset the screw. Many feet are made from plastic so be careful not to break when tightening. It needs to be fairly secure though, lots of movement when it sews. Use at 1/2 speed or less.
Derek
Jan 15, 2011 | Baby Lock Espire
How to attach a quilt guide
You have to unscrew the screw for the presser foot first. The walking foot will then fit. Use the same screw to attach the walking foot. Before you insert the screw, take the white handle on the walking foot and slide it on the screw arm for the needle. Now tighten the screw.
Mar 21, 2010 | Singer Sewing Machines
Bernina 1008 sewing machine making huge clumps of loops on underside of fabric. have tried moving screw on bobbin in two opposite directions without a sign of improvement.
Hi: You have threaded the machine incorrectly. Rethread the machine with the presser foot up to the needle, pull the thread (loose) and drop the presser foot while pulling thread, thread should get tighter, then thread needle and machine will work fine. Make sure the top tension is set at where you normally have it, probably about #4 or #5
Jan 08, 2009 | Bernina 1008
How do I attach a walking foot
Okay let's get started.
  • First let's look at the walking foot.
  • Turn the bulky body so that it's away from you.
  • On the left you see a groove that is going to be where you attach the foot to your machine.
  • On the right is a u-shaped arm which you can move up and down. It will go over the needle clamp
Now, let's remove your present foot from the machine and look at it.
  • Loosen the foot screw until it almost comes off. (if it does come off, screw it back on a bit.) The screw is on the left of the foot-bar.
  • On the right you'll see the needle bar with a needle clamp (what you tighten when you replace a needle) on the right of the needle-bar.
Okay the walking foot business.
  • slide the walking foot into position so that the foot screw is in the slot on the right and the u-shaped arm is over the needle clamp, with the needle clamp in the middle of the u-shaped opening.
  • Tighten the foot screw securely, it's going to be under more strain than normal.
  • While you're at it, check that the needle-clamp is nice and tight as well.
Okay, then! There you go... Happy sewing.
Are you happy? Than please vote
Here are a few helpful pictures.
Feb 01, 2008 | Singer 7436 - INGENUITY
Sewing Machines Logo
147 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
