Question about Canon Cameras
Turn on camera and screen lights up with an image that seems permanent. Can't get into the menue or anything else. The zoom and picture taking button work but the viewing screen will not change from what looks like an image burned into the viewing screen. I can hear all the normal functions but no change occurs on the screen when trying the differnt options for the camera. Please help. My camera is Power Shot SD400 Digital ElPH. Sincerely
    Genius:
  • 3,422 Answers
Please replace the battery to solve this issue.
Posted on Dec 13, 2008
    Genius:
  • 1,847 Answers
The an option to reset the camera to factory setting where you able try that?
  • Legin Varghese
    Legin Varghese Dec 13, 2008
    Take the memory card and the battery off the camera and wait 10-15 min and then try restart and try the menu.
New batteries are not lasting longer than a day
Battery life can fluctuate greatly from day to day. It all depends on the type of photography you are doing. For example, on one day, you spent the day taking pictures outside in the sunlight, with no flash, and didn't use your camera's screen to review any of the pictures. The next day, you spent the day inside, taking lots of pictures using the flash, zooming in and out on people's faces and reviewing the pictures using the camera's screen.
Features like the flash, zoom, LCD screen and image stabilization (IS) use a great deal more battery life than if you were to not use any of those features. This could explain why it suddenly seems like the batteries aren't lasting more than a day.
However, if your photography habits have not changed enough to potentially affect battery life, there could be an issue with either the image stabilization hardware or the standby mode of the camera. If the image stabilization (a fully mechanical feature) is malfunctioning, it could be activating when it shouldn't be, such as when the camera is on but you aren't about to take a picture.
I would try testing the camera by taking pictures using different camera settings.
  1. Turn off the flash and image stabilization, use the viewfinder instead of the LCD live view mode, do not zoom in or out. Take as many pictures as you can before the batteries die.
  2. Keep the flash and image stabilization on, use the LCD live view mode, use the zoom frequently. Take as many pictures as possible before the batteries die.
With test #1, you should see much better battery life than with test #2. If you still experience decreased battery life either way, there may be a hardware issue with the camera. Should this be the case, contact Canon Support to find out whether or not your manufacturer's warranty covers this problem.
Mar 01, 2011 | Canon PowerShot SX20 IS Digital Camera
Canon A620 is taking black images/ Can't see images on screen
First try pressing the DISP or DISPLAY button on the back of your camera. If that didn't fix it... A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 28, 2010 | Canon PowerShot A620 Digital Camera
Can't get a picture on the screen - just shows black. When we turn the camera on the LCD screen displays the function choices and menu options, but will not display any image. If we take a picture using...
Check the SD card, they have sliders on them which lets you "lock" the card so nothing can be put on or taken off of it. Make sure that is off. Then go through the menu on the camera and try to format the card again. If the card is bad it should give you an error message when it tries otherwise you should be good :)
Aug 19, 2009 | Canon Powershot A1000IS 10MP Digital...
Lens problem, no zooming capabilities and blurry images
This would need to be serviced something is wrong with the auto focus and this is inside the lens housing. I would take it into a camera shop and have the examin the autofocus.
Jul 13, 2009 | Olympus FE-230 Digital Camera
My camera d580
First, make sure the batteries are fresh and installed correctly. Turn on the camera, if you get an opening screen, your camera should be OK. Press the menu button and navigate to screen options where you should be able to turn on the screen to take pictures.
If there is no opening screen when you turn on the camera (and you are sure the batteries are good and in properly), then try to take some pictures without the screen. If the camera takes good pictures, then the screen is dead. You can continu to take pictures with it in this condition. I do not think they are worth fixing, though.
If the camera does not take good pictures or no pictures then the camera has failed or dead. Your best solution is to replace the camera with a newer, better one, More pixels, greater optical zoom, quicker start time and so on.
May 31, 2009 | GE E1040 Digital Camera
When camera is switch on the menu shows but no picture/image
Your camera seems to have ccd chip problem. Image chips goes bad sometimes and when you play recorded image it is ok but when you want to turn on the camera to take picutures, you'll see scrambled image or no image at all. The remedy for this symptom requires a replacement of ccd chip. The average repair for ccd problem is $100-$130 in the repair market. -James
Mar 27, 2009 | Canon Cameras
Monitor screen lights up but no image or menu can be seen
If the screen won't show anything then you are going to have to send it in and have Casio look at it. More than likely the LCD is going out but just hasn't "gone" completely. Give them a call at 800-706-2534 and then option 2 and tell them that your lcd is going out and they'll tell you the closest place to send it.
Aug 01, 2007 | Casio EXILIM ZOOM EX-Z850 Digital Camera
The SMART ZOOM is not working - doesnt either come up in SET UP menu?
I fixed my problem myself. Simply read the top of the camera1.gif where it says TO USE SMART ZOOM SET IMAGE SIZE TO LESS THAN 2.8M
Then go to the very bottom button on your camera (there are three) and press it and reset your image size.Then your zoom will work.
Problem solved.
Jan 11, 2007 | Sony Cyber-Shot DSC-P32 Digital Camera
Image on the screen freezes and camera won't respond.
I require the software to enable to download pictures for my
finepix fuji f601z
Nov 17, 2006 | Fuji FinePix F601 Zoom Digital Camera
Cameras Logo
18 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
