Question about Sylvania 6842PE 42 in. HD-Ready Plasma Television
Switches off will power up but powers down after a minute.i dont understand how this problem is occuring. Could i fix this problem myself. Thanks
    President:
  • 3,130 Answers
You have a power supply problem ,most likly the main board will have to be replaced, My best advice is to call out an authorized Sylvania dealer because if you make a mistake on what board is bad, they will not take it back. Play it safe. Good Luck
Posted on Mar 23, 2007
Location of fuse for power windows
Probably not fuse but more likely switch or wiring. If failure occurs from switch in driver's door, try switch in the door where window is not working. If it works from there, driver's switch is bad or wiring in door hinge area has a break which comes and goes.
May 27, 2015 | 2003 Jeep Grand Cherokee
How do i fix this, i turn my game on the nintendo five seconds later this thing comes up it says an error occurred
Look at the console lights around the power button. If the lights go all red or there are just a couple lit then you need to have unit fixed. I have fixed this problem a couple times myself but the fix does not last long.
Dec 25, 2014 | Nintendo Video Game Consoles & Games
Eco power turn off
That is because it is a clock radio with a sleep function.
Apr 01, 2017 | Philips Audio Players & Recorders
I dont know how to fix the Front Panel Audio Connector. And I dont understand what is ATX power switches. I'll tell you what wire i have: H.D.D. LED, POWER LED +, POWER LED -, RESET SW and POWER SW....
Hi!
You have to make make the four Front Panel Connection as shown below: -
(IDE LED is the same as HDD LED and Ground means negative '-')
Hope it helps! Good Luck!
Thanks for using Fixya!
CreativeTECH
May 31, 2011 | ASUS P4VP-MX Motherboard
My 89 suburban tailgate window will not go down with either toggle switch or key. Have had different problems in past, such as intermittently window goes up but not down especially in warm weather, and...
sounds like a problem with the motor. I would check to see if there is power at the motor and how much if there is than try applying power directly to the motor and see if it will work.
Jun 01, 2017 | Chevrolet Suburban 1500 Cars & Trucks
Passenger side power window inop. Possibly a switch, fuse? Can I fix myself? What parts are required? Thanks
Try removing the door panel, and then feeding direct power to the motor using two wires connected to power (positive) and ground (negative). Connecting the wires one way will make the motor move the window up, and reversing the connection will make the window go down. If the motor works ok when you do this, then you have a wiring or switch issue, likely a switch. If the motor doesn't work with direct power and ground, then you have identified the problem. Good Luck!
Sep 23, 2010 | 1994 Ford Explorer Limited
SELL INSPIRION 1470 IS NOT STARTING UP LED LIGHT IS SOLID WHITE
try safe mode. if still freezes, perform diagnose on your hard drive
Feb 27, 2010 | Dell Latitude D810 Notebook
Delay on printing
Power the printer on then unplug the power lead. PLug the power kead back in while pressing OK and Cancel. Hold the buttons down until the printer turns off. Unplug the power lead for 30 seconds. Plug the lead back in and run through the set up process and try again
This should clear your problem
Nov 09, 2008 | HP Photosmart 2575 All-In-One InkJet...
RCA D52W20 52" TV SHUTS DOWN AFTER A FEW MINUTES
this is the filment circuit having a problem. i think you will find it is a loose connection on a solder joint. Goodluck
Jan 16, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sylvania 6842PE 42 in. HD-Ready Plasma Television Logo
103 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
