Question about Sanyo Cinematic Progressive Scan DVD Recorder
Screen displays "no play"
When I put a dvd into my Sanyo Cinema Progressive dvd player the display says "reading" for a long time and the displays "no play". It doesn't matter if it is a brand new never played dvd or an older one. I cannot find my owners manual and therefore cannot troubleshoot the problem. Any ideas or do I have to buy a new dvd player?
    Genius:
  • 1,074 Answers
The dvd is having a problem with the lens clean it ,if that does not work take it to a tech to adjust the lens or replace them there is also a flat strip that leads from the lens body to the circuit board this should be change.good luck.
Posted on Apr 04, 2007
SOURCE:
Does Magnavox mdv 2100/F7 dvd player have front panel display
Hello
This DVD player has no front panel display. Its front panel have ony two LED light indications, out of which, one is for power On indication and the other for p-scan [Progressive Scan] which will ight up when you select Progressive Scan function.
There are three push button switches, for Open/Close, Play & Stop.
It has only ON-Screen display system, which will be active only after connection the DVD player to tV. OK.
http://www.dataentryjobs.us/67948.html
Feb 02, 2012 | Magnavox Televison & Video
I have a Sanyo Cinema Progressive DVD player and the videos are playing back in black and white, rather than in color. What is the problem?
The output signal maybe set to S-video and the input connector does not have S-video capability. Change the output signal or use a HDMI cable. If the connection is via progressive cable (three leads), the colors maybe mismatched.
Apr 09, 2011 | Sanyo Cinematic Progressive Scan DVD...
I have a sanyo cinema progressive dvd player....lost the remote and am trying to program universal...what remote code should I use?
what kind of universal remote do you have???? it can vary sometimes from remote to remote
also, do you have the model of the sanyo system??? some models they make are made by other companies so you would have to use their code.
Aug 04, 2010 | Sanyo Cinematic Progressive Scan DVD...
Need manual for Sanyo DVD player, DVW 7100 Cinema Progressive.
You can download the required manual from:
http://www.retrevo.com/support/Sanyo-DVW-7100-DVD-Players-manual/id/311ag904/t/2/
On the page which opens, click on the GET MANUAL button and follow the instructions on the next page to download the manual.
Hope this solves your problem. Thanks.
Oct 06, 2009 | Sanyo DVW-7100A DVD Player/VCR
Progressive scan mode on screen
Your television probally does not support progressive scan mod. many do not.
Apr 12, 2009 | Zenith XBV342 DVD Player/VCR
Need to turn OFF progressive scan on Sony DVD DVP-NS57P
With the remote: While in STOP mode, press the DISPLAY button. Use up/down buttons to select SETUP. Press Enter. Use up/down buttons to select CUSTOM.Press Enter. Use up/down buttons to select SCREEN SETUP. Press Enter. Use up/down buttons to select PROGRESSIVE. Press Enter. The manual is a bit indistinct after this, but I think the prompts will direct you. Just turn Progressive OFF.
Owner's Manual page 61, link http://www.sonystyle.com/wcsstore/SonyStyleStorefrontAssetStore/pdf/DVPNS57P.pdf
Nov 06, 2008 | Sony DVP-NC85H Multi-disc DVD Player
LG DK 8621P DVD Player only play the audio (no video out)
how can off the progressive scan in my LG DVD player model 8680?
Nov 22, 2007 | LG DK 9411P DVD Player
How do I turn off Progressive scan?
Hi, follow the steps it may help !! Press STOP button. ? If playing a disc, press the STOP button twice so that ?STOP?, appears on the display. Press and hold P.SCAN button on the remote control for over 5 seconds. ? Pressing and holding the button for over 5 seconds will select "Progressive Scan" and "Interlace Scan" alternately. ? When you select P.SCAN, "P.SCAN" will appear on the display. ? To set P.Scan mode for DivX discs, press the P.SCAN button on the remote control for more than 5 seconds with no disc in the unit (?'NO DISC" on the display), then load the DivX disc and play. regards sreejith
Jul 17, 2007 | Progressive DVHE210 210 DVD Player
GOLDSTAR DVD/VIDEO PLAYER
Remove any discs from the unit. Make sure your tv is on the blue screen. It should say "Progressive Scan Mode"....After removing the disc(s) from the disc changer, close the changer, press and hold the stop button on the unit, not the remote, for 5 seconds or more and it will reset to normal playing mode. Progressive Scan is typically only for TVs that use Progressive Scan....most normal TVs do not use progressive scan mode. Hope this helps...It worked for me!!!!
Jan 20, 2007 | Goldstar DV7411N DVD Player
Televison & Video Logo
359 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
