Question about Jenn-Air JMV8208A Microwave Oven
Sharp R1505 Same problem. On/Off button fell inside somewhere. We use a coffee straw stir to turn it on. Push it down and in the lower left corner of the hole. My friend and I both have this microwave with same issues. Time display will never work for more than 4 months. Had it repaired twice b4 I gave up. This microwave definately has prominant defects!!!!!!!
  • Anonymous Mar 24, 2009
    Came here looking for a solution/part to repair our "start" button, and read this... Our display also stopped working after a few months, I'll have to find a good sturdy coffee stirrer I guess.
  • Jenn-Air Master
  • 9,098 Answers
We have affordable solutions for both problems.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
What happens all too often is that a shop will replace your board with a board which has (what in my professional opinion are) built-in weaknesses in design and manufacturing.
Our repairs include our proprietary upgrades designed to repair and prevent future display failures.
Or you can order a fully-upgraded control unit to avoid being without your microwave during the repair period.
Our repairs also include a new and improved select button assembly, or you can order one here and install it yourself.
Details are at our Web site, and we also have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Posted on Dec 15, 2008
My Sharp R1505 over the range microwave probably has a door switch out of alignment. The door itself is level and aligned. The unit will show the heating time but will not heat. It will heat if I push the...
Assuming your hinges are tight, your bottom door switch is probably defective, or its mount is loose, misaligned, or broken.
This is usually caused by opening the door while it's cooking (instead of hitting "stop" first) or slamming the door.
I have the service manual at my site here. See my help file on door switches here.
More questions? Contact me directly here.*
* always include the full model number and FCC ID number from the label on / in your microwave (or a clear photo of the tag)
Jan 27, 2018 | Sharp Microwave Ovens
My over the stove Sharp Carousel Model # R-1505F turn table stopped turning. What part do I need to replace. Also, I broke the glass turn table plate. What size is that and where can I order another...
Sears Parts Direct has the parts diagrams and many parts for the R-1505 microwave. The glass plate is part 4-3 ($33.99) on this page: http://www.searspartsdirect.com/partsdirect/part-model/Sharp-Parts/Microwave-Parts/Model-R1505/0958/0123370/50019999/00001?blt=06&prst=&shdMod= .
Without more tests, I can't be completely positive but the turntable motor is the likely problem. That is part 1-4 on the list above. However, it could be a wiring problem with the wiring to the turntable motor.
Partstore.com has many of the parts as well: http://www.partstore.com/Model/Sharp/Sharp/R1505.aspx .
I hope this helps.
Jul 29, 2011 | Sharp R-1505 Microwave Oven
My Sharp R1505 Microwave's LED display is malfunctioning, with only minimal lighting of digital/number segments. Do I need to replace the entire control board with a new LED attached or can I just replace...
You can order a new control unit (part number CPWBFB075MRU0 which comes with a display) from Encompass here.
Or you can get yours repaired for $39.95. Details here.
Feb 10, 2011 | Sharp R-1505 Microwave Oven
Looking for sharp r1505 turn table motor No;rmotda252wrzz
The service manual is here for your convenience.
The original part number was RMOTDA211WRE0, but that was been subbed by part number RMOTDA264WRZZ, which was finally subbed by the current part number RMOTDA252WRZZ. (Please note the difference between ohs "Os" and zeros "0s").
Part number RMOTDA252WRZZ is in stock at Encompass here or you can call them toll-free at 866-779-5835.
Dec 18, 2010 | Sharp R-1505 Microwave Oven
Bottons on microwave do not work
HI, the touch pad board has failed. you will need to replace this damaged board asap. this will correct the issue.
Sep 27, 2009 | Microwave Ovens
On button is broken
My husband took the cover off and positioned the broken button where it will still push on the left corner. I dont know if we can buy just the button or what.
Jun 25, 2008 | Sharp R-1505 Microwave Oven
Sharp carolsel model r1505 on/off buttons broken
Unplug micro wave.
3 screws to remove top vent.
1-screw to remove touch panel from chassis.
tilts foward disconnect wires from board . I labeled for
reassembly .
1-screw holds the touch panel electrics to face plate.
There are 4-6 snap in plastic tabs holding it in place.
you have full access to the cheap plastic hinged buttons.
I hot glued mine once but they broke after 6 months.
I found this site:http://207.234.249.73/mwd/#brands
Good pics and you can see the buttons.
They sell a replacement button for $15 . There is also a
complete service manual for the Sharp 1505 for free download.
Did I mention to unplug the microwave before starting...
Rob H
Dec 17, 2007 | Jenn-Air JMV8208A Microwave Oven
Start button problem
You will need the new & improved select button assembly and you can order them through us if you like.
We have full details, plus *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
The order form is at http://207.234.249.73/mwd/btn_form.htm
Nov 25, 2007 | Sharp R-1501 Microwave Oven
Sharpd R-420LW
I always recommend that folks put food off-center on the turntable to assure more even heating.
It's a stirring action, so imagine how inefficient it would be to stir just by twirling a spoon in the center of your coffee!
Also, when you put your food off-center, you're not putting it in the same spot every time. That will help prevent repeated heating of the the same spot on the glass, which can lead to weakness and cracking.
The turntable generally replaces the stirrer, which actually scrambles and stirs the microwaves as they come out of the waveguide from the magnetron. But some models, notably GE's, have both.
So if you're placing the food properly and it's still burning, since it's under warranty, contact Sharp at 1-800-BE-SHARP (1-800-237-4277) to see about getting it checked.
Oct 21, 2007 | Sharp R-420DK Microwave Oven
Jenn-Air JMV8208A  Microwave Oven Logo
83 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
