Question about KitchenAid Architect Series KEBC107KSS Electric Single Oven
Superba oven- oven heat not consistent with settings
  • Anonymous Dec 25, 2008
    Set oven to desired temp and fails to heat up. Defaults to Lo. I have had the double convention ovens for 18 months. No problem until today.
  • diwoodman Dec 27, 2008
    AFTER 8 YEARS WITH NO PROBLEMS OUR OVEN IS ALL OF A SUDDEN TAKING A LONG TIME TO HEAT UP AND WE HAVE EXPERIENCED THE SAME 'DEFAULTS TO LO' PROBLEM. HAD AN APPLIANCE REPAIR GUY OUT TODAY. HE CONFIRMED THAT BOTH ELEMENTS ARE HEATING, THAT THE OVEN TEMP. IS READING CORRECTLY SO RECALIBRATION ISN'T NECESSARY AND THAT THE CONTROL PANEL IS FINE. SUGGESTED I CALL KITCENAID TO INQUIRE ABOUT STANDARD PREHEATING TIME AND ALSO SAID IT COULD BE THE SENSOR.
  • KitchenAid Master
  • 3,463 Answers
Several possibilities, faulty thermostat,faulty heating element,badly fitting door,etc, etc.
Cannot be more specific, as there are too many variables.
You need to call an engineer, if it is an old oven, probably better to replace.
Posted on Dec 13, 2008
Kitchenaid superba oven
check the igniter for oven and change
you may have a seperate igniter for the broiler
Nov 15, 2013 | Ovens
I set my kitchenaid superba self clean oven to clean mode. It cleaned it however now I cant get the oven to work. Stove top works but oven doesn't. What can I do to fix this?
Pyrolitic mode heats up quite hot. Might have tripped the high temp cutout.
Does the oven fan work? if so >> check element
Oct 17, 2013 | Ovens
My kitchen aid superba programable oven heats to the correct temp i set sometimes, and sometimes not,meaning if i set it for 375 it will heat to like 250 and then stop, i unplugged it for 1/2 hour to...
It may just be the thermostat going bad. The thermostat tells the oven temperature controller what the temperature is inside the oven. As they go bad they send back incorrect signals. They are relatively simple repairs.
Nov 22, 2017 | Ovens
I have a kitchenaid Superba convection oven. I be something else?
it sounds exactly like an ignitor, if u want the original ka part u will pay more,, you could use a 12400035 ignitor, or a sgr403, depends if its round or flat, go to repairclinic.com and enter those part numbers in to see pictures of those, or look up a ka ignitor and compare prices. hope this helps let me know whut u think
Feb 12, 2010 | KitchenAid Ovens
We put this unit on self clean and now it wont turn on nor open.
I had the same problem with a Superba wall oven. In my case, the bracket mount for the door lock warped due to the heat of the self clean cycle. We were able to open the door by inserting a coat hanger into the slight opening at the top of the door and sliding the lock lever to the left. It was a pretty easy self-repair - 1) turn off breaker 2) slide oven out 2-3" 3) remove oven front trim pieces 4) remove screws that mount control panel 5) this should give you access to the door lock mechanism.
good luck
Feb 01, 2010 | KitchenAid Ovens
Oven won't heat after cleaning
There is a thermal fuse on the back right next to where the element goes through. it's probably out. You have to remove the oven to replace it. Of course i'm assuming this is a wall oven. Greg
Jun 11, 2009 | Ovens
5 yr old Jenn Air Electric oven won't maintain oven temperature
Technician just left our house with same issue. Jenn-Air had issued a technical bulletin as the temperature probe is mounted directly to the heating element, and measures the heat of the element, not the oven. Their fix is a revised temperature probe that goes at a 90 degree angle away from the heating element.
If your temperature is consistent, just off by a set amount of degrees, there is an adjustment you can make at the control panel.
Mar 09, 2009 | Jenn-Air JJW8130D Electric Single Oven
KitchenAid Superba Microwave/Oven, Microway Door message
"I get a "Door" message when I try to start it. The Message only shows when I try to set the time with one of the function buttons, like and dosent work
Dec 20, 2008 | Ovens
Kitchenaid superba electric oven kebc107kss05
Did this with me twice now on self clean. It's the thermostat on the back of the oven. Set to trip when oven gets too hot which happens with self clean. Part is about $45 - $50 and pretty simple to install. Hardest part is pulling the oven out of the wall.
Nov 11, 2008 | Ovens
KitchenAid Architect Series KEBC107KSS Electric Single Oven Logo
145 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
