Question about Bantam Interactive BA1000 MP3 Player
My BA1000 doesn't work
When I turn it on, there was an error "Unable to initialize your hard disk,please recharge the battery" and then I can't do anything, even if when I recharge, nothing happen. So what I have to do now?(My computer doesn't see the disk when I plug it in USB)
  • Thach David Mar 10, 2007
    I used it but still there was an error "Unable to initialize your hard disk,please recharge the battery".
    Problem Solver:
  • 7 Answers
To fix Bantam BA-1000 Battery Charging Error:
Find a pin or a paper clip. Insert the tip to the reset hole (locate next to USB). It will try to reset the system and test the system.
If you see the test / diagnose message, push the reset button again until you see the Bantam logo and the charging indicator.
Software to be used with Bantam BA-1000 Audio Jukebox:
A great tool you might want to look into is the HDDTool. It's for Philips HDD Audio Jukebox. However, I've used it successfully to refresh the database. You can find it at http://solonweb.free.fr/
It's a real nice little MP3 player.
Good luck with it.
Posted on Nov 05, 2007
Use a paperclip to reset the system
Posted on Mar 10, 2007
C0640
Hard disk drive problem
The hard disk cannot be accessed
the main PWB and the connector on the
hard disk. Repair or replace if necessary.
Defective hard
disk.
Run U024 (HDD formatting) without turning
the power off to initialize the hard disk.
Replace the hard disk drive and check for
correct operation if the problem is still
detected after initialization.
Defective main
PWB.
Replace the main PWB and check for correct
operation
Apr 17, 2014 | Kyocera Mita Km 3035, 4035, 5035 Fs9120dn,...
Unable to open Hard disk drive
try running a check disk to check for errors. In windows command prompt type chkdsk C (substitute C for the letter of the drive).
Has anything happened to these drives such as dropping that would cause it to not be readable? What format is the disk FAT or NTFS?
Hit us up at our techie forum:
http://forum.wasatchtechies.com/
Wasatch Techies Smartphone Tablet and Computer Repair in Utah
Feb 11, 2014 | Western Digital Computers & Internet
I have a problem Taskalfa 250ci eror code c0640 I think at Hdd problem. But I don't know how to hdd format
Maintenance
item No.
U021
Memory initializing
Description
Initializes all settings, except those pertinent to the type of machine, namely each counter, service call history
and mode setting. Also initializes backup RAM according to region specification selected in maintenance item
U252 Setting the destination.
Refer to *1 of the maintenance mode item list about the item initialized.
Purpose
To return the machine settings to their factory default.
Method
1. Press the start key.
2. Press [EXECUTE] on the touch panel.
3. Press the start key. All data other than that for adjustments due to variations between machines is initial-
ized based on the destination setting.
4. Turn the main power switch off and on.
For errors occurred, turn main power switch off then on, and execute initialization.
Error codes
U024
HDD formatting
Description
Initializes the hard disk.
In addition, the following settings are also initialized by initializing the hard disk.
System menu (user login administration, job accounting, address book, one-touch keys and document box
etc.), shortcuts and panel programs
Purpose
To initialize the hard disk when replacing the hard disk after shipping.
Method
3. Press the start key to initialize the hard disk.
Description
Codes Description
01 Configuration initialization error
02 Counter initialization error
20 Engine initialization error
40 Scanner initialization error
2JZ/2JX/2JV/2H7-5
1-3-23
Apr 15, 2013 | Kyocera Taskalfa 250ci Color Copier...
My hp laptop shows non system disk or disk error
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Apr 04, 2012 | HEWLETT-PACKARD MINI 5103 Netbook
Turned off raid, unable to access 2nd 160 gig hard
Right click on Computer in the Start menu. You should see manage.
click on manage and you will see some selections the left one called disk management. click that and you should see all your drives. If you disable the Raid you may have to initialize the disk for windows to use it again. right click on the drive and initialize or if it shows up you may have to create a partition and then format.
Mar 08, 2010 | Dell Dimension 3100 PC Desktop
I had a HDD failure. I replaced the HDD with a WD1600AAJB HD. I am running win98se on this unit and had reinstalled win98 and some programs after the initial boot. I am now unable to boot and have been...
The most common cause of checksum errors in CMOS is a battery that is losing its power. You should pull the cmos battery and check its voltage with a volt meter. (It should read no less than 2.6 volts DC though 3.0 is recommended). Or just replace the cmos battery altogether. Viruses can also affect CMOS settings.
After checking the cmos voltage and or replacement of the cmos and while the system is powered down. Remove the system memory for about 1 minute. Doing this will remove any possible memory resident virus’s.
Download Western Digitals; Data Lifeguard Diagnostic for DOS (Floppy) or Data Lifeguard Diagnostic for DOS (CD)
WD's web site;
http://support.wdc.com/product/download.asp?modelno=WD1600AAJB&x=6&y=7
Use this software to setup you're hard disk drive.
You can also test the drive for errors and much more. Both of the above, floppy or CD are bootable and work in DOS mode. (Keep in mind all data will be erased). This is the best way to setup you’re hard disk drive before installing windows on it.
Cheers'
Mike
Feb 07, 2010 | Computers & Internet
I have a printer it is modle is Hp LaserJet p4015n, when i start it give me this error: (49.00FF ERROR To continue turn off then on). when I turn off then on it give me agane this error. thanks for help,...
HP 4015 NVRAM & hardrive initialization
Solution
A hard disk initialization will erase and reformat the printer's hard disk. Perform hard disk initialization only if an error code displays on the control panel indicating a disk error. Always try initializing the hard disk before replacing it.
1. Turn the printer on.
2. As the printer performs its power-on sequence, press and hold the Menu button until all three lights on the control panel are lit.
3. Press the back arrow . The message INITIALIZE DISK displays on the control panel.
4. Press OK. The printer initializes the hard disk and continues the power-on sequence.
CAUTION: Initializing NVRAM resets the serial number, the model number, the event log, the page counts, and the EIO card. Use the SERVICE menu to restore the serial number and page counts. You also need to reconfigure any computers that print to this printer to recognize the printer. Initialize NVRAM only when absolutely necessary. In most situations, use a cold reset to return printer to factory defaults but still retain the needed values in the SERVICE menu.
 NVRAM initialization
Before initializing NVRAM, print a configuration page and a supplies status page to gather the service menu values
1. Turn the printer on and watch the control panel display.
2. When the display shows the memory count, press and hold the down arrow until all three lights on the control panel are lit
3. Press the up arrow .
4. Press Menu . The message SKIP DISK LOAD displays on the control panel.
5. Press the up arrow until NVRAM INIT is highlighted, and then press OK. The printer initializes NVRAM and then continues its power-on sequence.
daca aceasta procedura nu reuseste, atunci va trebui sa inlocuiesti formatter-ul. daca nu exista hard disk
Good luck
Dec 12, 2009 | HP LaserJet P4015N Printer
Ford edge 6 disk cd changer cd error will not initialize. screen displays OOOOOO . This happened after battery went dead and was recharged. I have tried removing battery cable to reset system but still...
According to the tow truck that just came to pick up my Edge, the cd player killed the battery. He jumped it, turned the radio on and said to let the car run for at least 20 minutes. He says that if you leave the radio ON when you turn the car OFF, it should correct itself. Good luck.
Dec 03, 2009 | Car Audio & Video
Printer takes ages to process
NV RAM and HD
To initialize NVRAM
1. Remove any installed accessories (for example, a stapler/stacker).
2. Turn the printer off.
3. Hold down the DOWN ARROW ( ) button, and then turn the printer on. Continue holding
down the DOWN ARROW ( ) button until all three printer control-panel lights flash once and
then remain on. This might take up to 10 seconds.
4. Press the UP ARROW ( ) button.
5. Press the PAUSE/RESUME button. The display should show SKIP DISK LOAD.
6. Press the UP ARROW ( ) button until NVRAM INIT is highlighted.
7. Press the SELECT ( ) button. The printer initializes NVRAM and then continues its poweron
sequence.
Hard-disk initialization
CAUTION A hard-disk initialization erases and reformats the printer hard disk. Perform a hard-disk
initialization only if an error code on the control panel indicates an EIO disk error. Always try
NOTE Before performing a hard-disk initialization, print a menu map and a configuration page (see
Menu map and Configuration page). Use the information on the configuration page to reset
any customer-set printer configuration values that the hard-disk initialization procedure
changes.
1. Turn the printer off.
2. Hold down the PAUSE/RESUME button, and then turn the printer on. Continue holding down
the PAUSE/RESUME button until all three printer control-panel lights flash once and then
3. Press the BACK ARROW ( ) button. The display should show INITIALIZE DISK.
4. Press the SELECT ( ) button. The printer initializes the hard disk and continues its power
Mar 12, 2008 | HP LaserJet 2420 Printer
Bantam intereactive BA1000
Ignore the error.
Another tool you might want to look into is the HDDTool. It's for Philips HDD Audio Jukebox. I've used it to refresh the database successfully. You can find it at http://solonweb.free.fr/
Good luck with it.
Apr 13, 2007 | Bantam Interactive BA1000 MP3 Player
Bantam Interactive BA1000 MP3 Player Logo
200 people viewed this question
Top Bantam Interactive Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Bantam Interactive Audio Player and Recorder Expert? Answer questions, earn points and help others
