Question about Kenmore Oasis HE 27082 Top Load Washer
When machine is spining a loud noise has started
When the machine starts its spin cycle a loud noise starts as it spins faster then as it slows down so does the noise it sound like a bearing going bad if so how and were is the bearing or what else could cause the noise.
kenmore oasis he top loader 2yrs old
  • sberner1959 Dec 16, 2008
    basket was clean no wires
  • 116 Answers
Sounds to me like the belt from the motor is loose or worn is it a loud screeching noise?
Posted on Dec 13, 2008
  • 479 Answers
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. top load washers seem very common to this happen! If the tiny cloth  is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary
also click the link for all the further help
Washing machine makes loud knocking noise
drain or drain pipes blocked
bearings gone
Aug 18, 2014 | Washing Machines
My washer started by spining faster then normal and then it started makeing a loud knocking noise and now sounds like metal rubbing metal. Everything else works fine just can't spin anything.
Jan 24, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Motor runsbut drum very slow to spin in spin cycle
The motor could be on its last leg of working. You can also check to make sure that the belt is not binding against anything under the drum. You may also want to make sure that the conterbalance weight is not hitting the belt. Make sure that your machine is lever and that it does not walk during spining.
Nov 28, 2009 | GE Washing Machines
WHIRPOOL WASHER LSQ9564MQ0 Started making loud
judging by the description i would say more likely the coupler
its a three peice part that sits between the mototr and transmission, kinda like a clutch,
anyway it is easily repaired
and available on
type in your model number.....
look for motor coupler
Oct 13, 2009 | Washing Machines
Spining makes noise and machine vibrates a lot
its a simple solution just remove the brown colour clamp at the bottom of the machine with a screw driver
Jun 03, 2009 | Whirlpool Washing Machines
Washer machine makes noise each time the tub stops spinning
theirs a brake that slows the tub down .Ive fixed 2 thousand off these washers and its not a normal a repair man i would remove traine,inspect clutch,brake and spanner nut and drive block area
Dec 31, 2008 | Kenmore 24032\24036 Top Load Washer
Spin cycle doesn't work with loud noise
yea sounds like a bad motor coupling ( this machine equivelent to a belt).
Mar 06, 2008 | Whirlpool LSR7333 Top Load Washer
Loud cliunking noise in beginning of spin then won't spin
get a flashlight and see if a foreign object has fallen down through one of the tub holes and is jamming the tub you have to look real close
Jan 11, 2008 | GE WJSE3110A Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
334 people viewed this question
Sal De
 Brian Main
Brian Main
